POV-Ray : Newsgroups : povray.off-topic : Why is defragging so slow? Server Time
25 May 2026 17:55:49 EDT (-0400)
  Why is defragging so slow? (Message 11 to 20 of 61)
Subject: Re: Why is defragging so slow?
Date: 2 Jun 2009 15:15:48
Message: <4a257a64$1@news.povray.org>
Warp wrote:
>   Question: Assuming fully defragmented data, which is faster to read data
> from a few big files: FAT32 or NTFS?
If you're reading the entire file, I would guess it's roughly equal. If
you're seeking around a lot, I'd guess it's NTFS.
Why?  FAT uses a linked list of clusters, with the first cluster pointed to
be the directory entry, as the allocated clusters of the file. (That's the
File Allocation Table: the linked lists.)
NTFS just stores the first cluster and number of clusters in the file table,
so calculating what cluster a given block of the file is on is probably
easier and requires fewer trips back to the start of the disk. I.e., you
don't have to read the disk to seek in the file.
You can even hear this if you have a floppy drive. Copy a 1 meg file to a
floppy, and you can hear the seek back to the FAT every handful of tracks
written.
This is just a guess, mind. I wouldn't think there's a whole lot of
difference on a machine with enough memory to hold the whole FAT in kernel
buffers.
   There's no CD like OCD, there's no CD I knoooow!
Date: 3 Jun 2009 19:02:11
Message: <4a2700f3@news.povray.org>
Invisible wrote:
> Warp wrote:
>>   I can't understand why defragmentation takes such humongous amounts of
>> time. There were something like 40 or 50 GB worth of fragmented data,
>> but if you calculate how many times you can copy 50 GB inside a modern
>> SATA disk, I think that in 35 hours you could copy it over and over
>> thousands of times. (Assuming it would take 1 minute to copy 50 GB of
>> data, you could copy it over 2000 times in 35 hours.)
>>   Why does it take such a humongous amount of time? I can't understand.
> Defragging is limited primarily by how fast you can thrash the heads
> back and forth, not by the maximum sequential transfer speed for the drive.
> I bet solid-state drives would defrag a lot faster. (But then, why would
> you bother defragging a solid-state drive in the first place?)
SSD also has limited "write" times, so, defragging the thing would end
up re-writing the data, and thus hastening the death of the media. Its
why most OSes that use them are "tweaked" so they never, if possible,
write the same file back to the same sectors each time, they way you
would on a HDD.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 4 Jun 2009 02:46:39
Message: <4a276dcf@news.povray.org>
I don't understand the problems I'm getting defragmenting.
  I'm trying to defragment my primary Windows partition, which is NTFS.
It's failing to defragment one big file because there's "no space" for it.
The file is about 1 GB in size, and there's over 9 GB of free space in the
partition.
  The problem is that while defrag is defragmenting all the other files,
for some reason it's only compacting *some* of the files to be at the
beginning of the partition, but not others. The free space is scattered
with tiny small files which the defragmenter is not compacting, even though
it compacted other files just fine. The majority of the contents were nicely
packed to the beginning of the partition, except for these hundreds of tiny
files. And no, the tiny files are *not* marked as "unmovable". They are
marked with the same color as all the other movable files.
  The other, lighter defragger is behaving the exact same way: It's just
refusing to move these small files, and consequently failing to defrag the
one huge file. No reason is given in either the visual representation of the
drive (all these tiny files are colored as regular, movable data) nor the
analysis reports for this.
  As a consequence, I simply *can't* add any file bigger than a certain size
to this partition without it becoming fragmented. There isn't enough
contiguous free space because of all these scattered tiny files.
  I can't understand why both programs are doing this.
Date: 4 Jun 2009 04:10:56
Message: <4a278190@news.povray.org>
> partition.
Buy a new hard drive with more free space?  Seriously, lots of people fail
to factor in how much their time is worth when trying to fix stuff.
Date: 4 Jun 2009 04:39:35
Message: <4a278847@news.povray.org>
> > partition.
  So because Windows is unable to defragment a big file I should buy a
new hard drive? Exactly how is that going to help? It's not like a hard
drive is going to defragment the file.
Date: 4 Jun 2009 06:03:57
Message: <4a279c0d$1@news.povray.org>
> new hard drive?
If you really want the file defragmented, then yes, this might be the
cheapest way if you consider how much your time is worth.
Well just the act of copying it over to another hard drive will probably
defragment it, and having more than 9GB of free space on a new hard drive
will likely make your life easier in terms of fragmented files in future.
Date: 4 Jun 2009 06:25:03
Message: <4a27a0ff@news.povray.org>
> defragment it
  Copying what over? The entire Windows installation?
  I'm not exactly sure XP survives such a transfer while still being fully
bootable from the new drive. Does it?
  (I know from experience that a linux system can be fully transferred from
one disk to another with a simple "cp -ax", and it will then work identically
when the disks are swapped. However, I have got the impression that with
Windows it's not that easy.)
  Anyways, it's just one fragmented file. It's not such a big deal. I'm just
wondering *why* the small files are not being compacted to the beginning of
the partition in order to create a larger contiguous empty space.
Date: 4 Jun 2009 07:14:30
Message: <4a27ac96@news.povray.org>
>  Copying what over?
Just the 1GB file that is fragmented so badly.  If the destination drive has
enough non-fragmented free space the file should be defragmented as it is
copied.  If your original drive has enough non-fragmented free space you can
then just copy it back and it should be in a much better state.  Note that
if this file is a windows system file you might need to do this outside of
windows for obvious reasons.
I don't see any big reasons why it wouldn't survive, you might have to
fiddle with a couple of things before it booted though (like MBR and the
boot.ini file).  There are also lots of 3rd party programs that will do this
automatically for you, I'd be surprised if there wasn't a freeware one.
Date: 4 Jun 2009 07:53:27
Message: <4a27b5b7@news.povray.org>
> partition.
That's pretty random - and dissapointing.
A few things to consider:
1. I wonder if this is related to the MFT reservation area?
2. You might try using the "contig" tool free from System Internals. It
can be set to run during the boot sequence, so it has more or less
exclusive access to the disk.
3. Having a 1GB file split into (say) 3 fragments probably won't have
any measurable performance impact. It's when you have millions of 4KB
fragments that you have a problem.
Date: 4 Jun 2009 07:53:35
Message: <4a27b5bf@news.povray.org>
> >  Copying what over?
  But that's the problem: There *isn't* enough contiguous space for the
large file to be stored unfragmented because there's a bunch of small files
scattered all over the free space, and the defragmenter is refusing to move
those files to make space, for an unknown reason.
