POV-Ray : Newsgroups : povray.off-topic : The chaos continues Server Time
15 May 2026 22:11:23 EDT (-0400)
  The chaos continues (Message 11 to 20 of 20)
Subject: Re: The chaos continues
Date: 21 May 2009 02:05:46
Message: <4a14ef3a$1@news.povray.org>
Kenneth wrote:
> Here in Virginia--near the 'buckle of the Bible-belt' in the USA, and
> ultra-conservative--head shops are a definite no-no.  Even selling something
> that looks like it *might* be used as a bong is now against the law!!
As far as I remember from high school, that seems like it would include
just about everything.
Date: 21 May 2009 02:10:56
Message: <4a14f070$1@news.povray.org>
Nicolas Alvarez wrote:
> Invisible wrote:
>> Only in America... o_O
> No, go read "This term has always bothered me" thread.
> Only in the *United States*!
Would listening to "I am not an American" by the Arrogant Worms suffice?
http://blog.orphi.me.uk/
Date: 21 May 2009 03:23:58
Message: <4a15018e@news.povray.org>
Invisible wrote:
> So today I finally got around to modifying my program to the point where
> you can *change* the arrangement of magnets without having to recompile
> the program. (The colouring scheme, however, is still hard-coded. In
> particular, if you move the magnets around, the colouring does *not*
> adjust to match.)
> The attached image shows what happens if you change the green magnet
> from 1/r to 1/r^2 attraction, while leaving everything else the same. As
> you can see, pretty mental stuff ensues...
How about colouring it differently ?
The primary colours are obvious - Hey I have three attractors, I'll make
them R, G, B !  The outcome is hardly pleasing though.
I think it might look much better with more subtle choices.  Yellow (or
Gold) and Blue through Purple mixes perhaps.  Make two of the attractors
similar and the third one a contrasting colour.
Hopefully you can keep the calculation already done and just render it
quickly to try different schemes.  Make a render front-end with colour
sliders.
This from someone who spent ages in FractInt playing with colour schemes
and colour cycling.
Date: 21 May 2009 03:28:09
Message: <4a150289@news.povray.org>
  Yes, pure color components never look very pleasing to the eye. Even if
you want to use red, green and blue, always mix a bit of the other components
into them as well! Rather than pure red, use a red with a slightly orange
tint in it. Rather than pure green, use a green with a slightly yellowish
tint. And so on. When you mix a tiny bit of pastel tints into your primary
colors, they immediately become more pleasing to the eye.
Date: 21 May 2009 04:00:08
Message: <4a150a08$1@news.povray.org>
What can I say? I suck at choosing colours...
Show me a set of colours, and I'll tell you whether it looks good or
not. Show me a blank screen, and buggered if I can think of a set of
colours that might look good.
(I have the exact same problem with writing music, by the way. Show me a
piece of music, and I can tell you exactly why it's cool. But given a
blank score, I can't write something that sounds cool.)
Date: 21 May 2009 04:16:29
Message: <4a150ddd@news.povray.org>
  That's why you should use a color picker, such as the ones in image
manipulation programs (the Gimp, if you don't have anything else).
Choose a color which looks good, and then look its rgb values (the picker
will show them) and use those in your program.
  If you want to go really fancy, you could *test* the colors before using
them, such as by creating a gradient between two of the colors you chose,
to see how well they blend together.
Date: 21 May 2009 04:37:03
Message: <4a1512af$1@news.povray.org>
I actually quite like the effect. But sure, there's no harm in trying
alternatives.
> sliders.
I've designed my program so that the integration engine dumps its state
to a file, and a seperate program reads that back and produces a PNG
file out of it. That way I can easily reprocess it to get different
colourings.
The only problem is... if you try to render at high resolutions, you
quickly reach a point where the computer spends more time nailing the
harddrive than actually running computations. Still, for the purposes of
trying different colourings, this doesn't matter too much.
Date: 21 May 2009 05:55:06
Message: <4a1524fa@news.povray.org>
> sliders.
  Actually if he used a pure color component for each of the three
magnets, he *already* has the necessary data to re-color the resulting
image. This data is in the image itself: Each color component of each
pixel tells how much the corresponding magnet contributes to that pixel.
Doing a color remapping from this is trivial.
Date: 21 May 2009 12:13:02
Message: <4a157d8e$1@news.povray.org>
Or learn some color theory. That's the sort of stuff they teach in first
year art classes.
http://www.tigercolor.com/color-lab/color-theory/color-harmonies.htm
   There's no CD like OCD, there's no CD I knoooow!
Date: 21 May 2009 12:50:54
Message: <4a15866e$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4a150a08$1@news.povray.org...
make
if
components
orange
yellowish
primary
If that's the case, easy:
1. Pick a random colour.
2. Pick another random (*) colour, place it beside the first (using a couple
of different patterns).
3. Remove the last colour and goto 2 if the combination doesn't look good.
4. Goto 2 until you have enough number of distinct colours.
Do this a few times, and you will eventually be able to remove the random
selection by intuition/heuristics.
(*) Random is the key. Novices tend to be bad at being able to chose random
colours, and will almost always pick fully saturated colours. Best is to
code a test program.
Unfortunately, above algorithm doesn't work for music.
