![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> and wireless connectivity. The surprising thing about it is that it's
>> really, really damned FAST. I've never seen an inkjet so fast!
> Yeh they're pretty fast now, especially for black&white text mine really
> pumps out the pages at an impressive rate. Printing photos on maximum
> quality is another matter though.
Even pictures seem to print pretty fast on this thing. But then again,
that's not at photo-quality...
(My mum's inkjet takes about 20 minutes per sheet if you want
photo-quality on gloss paper.)
>>> MS Word offers it too AFAIK.
>> I don't think it allows you to select odd/even pages or print them in
>> reverse order. (I could be wrong, of course.) It allows you to select
>> ranges, but I don't think it does more than that.
> Hmmm, I just checked, my MS WOrd 2003 gives you the option for even/odd
> pages, but nothing to reverse them.
OK, well it does slightly more than I thought then. But still not enough
for manual duplex. (Unless you fancy sorting the pages by hand...)
> My inkjet printer driver offers a "print from last page" option though.
Yeah, some print drivers give you basically nothing, while others let
you print N pages per sheet, do manual duplexing, collate pages, and
make a cup of tea...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible schrieb:
>> When I first discovered POV-Ray, I printed out the entire help file. I
>> don't think it was 2000 pages, but it was a big stack nevertheless :S
> Duplex?
I'd rather have guessed sprocket-feed...
(*Nnjeeeeeeegh! Nnjeeeeeegh! Nnjeeeeegh!*)
Those were the times when you /would/ print out documentation, because
otherwise you'd have to close your work, fire up the text viewer, try to
find the diskette with the documentation file, and ultimately wonder
what you forgot to remember what it was that you wanted to... darn!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible schrieb:
> Heh. *My* laser printer at home doesn't even have a duplexer. If you
> want to do this, you have to ask Acrobat to print the odd-numbered pages
> in reverse order, feed the stack of pages thus generated back into the
> beast, and tell Acrobat to print even-numbered pages in forwards order.
> Or is it the other way around? I can never remember...
... and make sure that you print an even number of pages!
> Notice that *only* Acrobat actually offers the ability to do these
> things, as far as I can tell. If you want to print from some other
> program... good luck!
Heh, *my* laser printer doesn't have any duplex printing hardware
either, but the driver is smart enough to do the even/odd
forward/reverse trick by itself, and give clear instructions how to
insert the printed stack back in the paper tray :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Let me guess: That's the printer you gave to her at about the same time
when you bought a new one because your older one was too slow :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible schrieb:
> For viewing stuff on-screen, PDF isn't such a hot choice. HTML has the
> advantage that the text can be reflowed to any screen resolution and
> window size. It's specifically designed for on-screen display.
*Designed* for on-screen display? Well, I'd rather say it is a case of
evolution rather than intelligent design :-P
Anyway, I see the reformatting as a disadvantage. PDF does give more
control over how the information is presented, which can help the help
author to make the text formatting more consistent as well as avoid some
layout mishaps, which in turn allows the reader to grasp the information
more easily.
I'd say HTML is a great tool for a bunch of semi-related and inherently
unordered but heavily interlinked pages (I'd say Wikipedia is /the/
killer application for HTML, and actually that's /exactly/ what HTML was
originally invented for), but a poor tool for a coherent and inherently
ordered set of pages like a software documentation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, some print drivers have a crapload of helpful options like that,
and others have absolutely nothing. It varies...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> more easily.
I disagree.
> I'd say HTML is a poor tool for a coherent and inherently
Go spent three hours trying to figure out the 8-page railroad syntax
diagrams in the Oracle PDF manual, then come back to me. Now of course,
if this was HTML, it wouldn't be split across multiple pages. And you
could just directly to the part you're interested in instead of wading
through the irrelevant parts of this "coherent and inherently ordered
set of pages". :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Even better than plain HTML is the HTML Help format used by POV. Because
it comes with a table of contents, index and search feature (though I
rarely use the last one).
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You didn't actually look, did you? :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Under "options". Indeed, you can tell it to reverse order for just the odd
pages, the even pages, or both.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
