Darren New wrote:
> Gilles Tran wrote:
>> 2 GB is enough,
> 1 GB is "enough" if you keep a clean install and you don't use it for
> memory-sucking programs like POV-Ray.
POV-Ray is memory-sucking? I haven't checked recently, but IIRC last
time I looked, Explore.exe uses about 30MB to POV-Ray's 2MB. (Depending
on what you're rendering, obviously.) IE or Firefox also drinks RAM like
it's going out of fashion...
> The laptop will probably come
> loaded with all kinds of "helpers" that for some reason try to replace
> (poorly) what Vista does for you anyway (display controllers, NIC
> controllers, etc).
Yes. Acer especially seems to like to do this. It's usually easy to
remove all that stuff.
(I *really* hope this laptop comes with propper restore CDs. I got an HP
a while back, and rather than give you a restore CD, they make you go
through the initial Windows setup process, and then order you to burn a
drive backup to [several] CDs/DVDs. In other words, *you* pay for the
cost of something to restore from, and you can't restore to factory
condition.)
> But 1G leaves about 450M comfortably free on my
> wife's machine, so it only thrashes around a little when she has five or
> six programs open. Of course, a laptop is probably going to have a
> slower disk, too, so...
Yes, 5200 RPM disk. (Like it matters...)
The laptop comes with 2GB, and I've ordered an additional 2GB because it
was cheap.
It does if you programmatically build scenes with lots of stuff in them.
Aren't there regular complaints about running up against the 2^32 memory
space in POV?
> (Depending on what you're rendering, obviously.)
Of course.
You're unlikely to use as much RAM with a Word document as you are with a
Menger sponge. :-) And your paging is likely to be much less with Word, even
if you do, due to the way you access memory in the two programs.
Or, more generally, it's not hard to write your own program that will use up
much more memory than you can use up using non-user-programmed software.
That's cool.
> condition.)
The restore CDs one makes this way are usually factory-condition CDs, not
just a backup. They're actually generating a CD based on the files on the
disk, not just making an image backup.
The more advanced versions of Vista have a "complete PC backup", which is a
very nice drive-image backup that will very simply do a full restore from
the boot CDs.
> was cheap.
Oh. The link you gave (with the Italian) said it came with 3G. Extra RAM
never hurts, tho. :-)
There's no CD like OCD, there's no CD I knoooow!
> space in POV?
Don't look at me. I've never had that trouble.
> a Menger sponge. :-) And your paging is likely to be much less with
> Word, even if you do, due to the way you access memory in the two programs.
> use up much more memory than you can use up using non-user-programmed
> software.
Well, yeah.
I do recall attempting to use volumetric photon maps and being unable to
do so because POV-Ray swallowed several times the amount of physical RAM
on the machine, and then attempted to destroy my harddrive.
Seriously, has *anybody* ever rendered something using volumetric
photons and had it work??
>> HP a while back, and rather than give you a restore CD, they make you
>> go through the initial Windows setup process, and then order you to
>> burn a drive backup to [several] CDs/DVDs. In other words, *you* pay
>> for the cost of something to restore from, and you can't restore to
>> factory condition.)
> not just a backup. They're actually generating a CD based on the files
> on the disk, not just making an image backup.
Well, we'll see.
I still dislike having to pay for the restore CDs myself. :-P
> is a very nice drive-image backup that will very simply do a full
> restore from the boot CDs.
It looks like that's what my mum's Acer did. Does a complete backup of
your harddrive - although I think you have to run the restore program
from the PC. (So, if your HD dies, the backup is no use until you
reinstall the restore program. Nice...)
>> it was cheap.
I just hope the laptop has more than one RAM slot...! o_O
That's the sort of thing I was talking about, yes. :-)
> Well, we'll see.
Well, that was for HP. Others may do it differently. My Motion Computing
laptop came with CDs that were the bog-standard XP install CD with a script
tacked on the end that prompts for the second CD full of laptop-specific
drivers and patches.
Probably cheaper than Dell manufacturing and shipping them. I.e., you'd pay
for them anyway, but it would be included in the higher price of the laptop.
Ick. That's silly, considering there's a full-backup program in Vista and a
restore program on the Vista CD they could have used.
It said it has 1x1G and 1x2G included. You *did* read the chart, didn't you?
Is that the one you ordered?
scott wrote:
> Will it make me more likely to buy it because of those stickers,
If some corporate dude needs to buy 8000 monitors, it might.
> I ALREADY BOUGHT THE LAPTOP! How is sticking an advert to it going to
make me buy it even more?
You bought it mail order. When you go in a store and look at the floor
models, it's built-in advertising they don't have to rely on the store to
provide.
> It's sitting in my house,
So peel it off when you get it home. :-)
That is a PITA. The sticker comes off and you spend three weeks removing all the
glue. If you don't take it off it slowly uncurls and irritates your hand.
The seventh tier of hell for these guys.
Regards
> Now, if the laptop is sitting in a shop window, that's another matter.
> But it isn't. It's sitting in my house, where nobody except me will ever
> see it. Go figure...
Two more things to what Darren said: They want you to be satisfied - just before
you go through the headache of personalizing a new system. Something along the
lines of the "thankyou for purchasing our quality product" like in a user
manual. Also I'm sure they wouldn't want you to think it looked 'plain' after
you open the box ;)
Charles
>> OK people, so I've found a laptop I like the look of. Trouble is, it's
> Damn it. You know what? I'm just going to buy the thing. Dr Pepper?
The parcel just arrived. Muhuhuhu! >8-D
So, will be be seeing an OrchidNotebookVista on here, now?
~Mike
I very much doubt it. But it's possible...
