POV-Ray : Newsgroups : povray.off-topic : World Community Grid Server Time
30 Apr 2026 11:36:09 EDT (-0400)
  World Community Grid (Message 14 to 23 of 103)
Subject: Re: World Community Grid
Date: 9 Mar 2009 03:57:00
Message: <49b4cbcc@news.povray.org>
> Switch to compact fluorescents. A 26W one should provide as much light
> as a 100W one.
LEDs are the way forward, they are more efficient (and getting more
efficient the whole time) and more environmentally friendly (they don't
contain mercury) and fix almost all of the disadvantages CFLs have.  Just
wait...
Date: 9 Mar 2009 05:35:08
Message: <49b4e2cc@news.povray.org>
>> as a 100W one.
> Just wait...
I don't know about CFLs, but our house has several "energy saving"
lighting units. The problem is, there's a 20 minute delay between
turning them on and being able to see where you're going...
LEDs are indeed efficient, but the main problems currently seem to be
making "white" light with them, and illuminating large areas.
Date: 9 Mar 2009 05:37:37
Message: <49b4e361@news.povray.org>
andrel wrote:
> Are you cooking electric? How do you heat your house?
Both of those are gas.
The microwave oven, however, is electronic. I haven't measured it, but
it's rated at 900W. (I have no idea whether that means it uses 900W of
juice, or just that it produces 900W of microwave energy.)
> Anyway, there is this problem that your PC may be on for periods much
> longer that the washing machine.
Like I said, playing CSS (which you're presume is a reasonably intensive
task) for 2 hours solid used a fraction of one kWh. I don't know what it
uses if I run the computer for an entire day (presumably it varies by
the task I set it to do), but I imagine running the washing machine
several times per day - or accidentally leaving the lights on - uses far
more power.
Date: 9 Mar 2009 06:29:10
Message: <49b4ef76$1@news.povray.org>
> lighting units. The problem is, there's a 20 minute delay between turning
Yup, and not having studied them carefully, I hear they make a slight
buzzing noise which can be annoying in a quiet room (eg while trying to
read).
There's no problem with making white light, the most efficient way is just
to put a mixture of different coloured LEDs in one "lamp" to give whatever
white temperature you want.  The other way is to put a yellow phosphor
infront of a blue LED, but that's not as efficient electrically (it means
you can get white from a single LED though).
The biggest problem is keeping the LED temperature low enough during use,
the designs I've seen have been mainly heat sink, but they seem to have
overcome that for 60W and 100W equivalent bulbs:
http://www.metaefficient.com/leds/led-light-bulbs.html
Date: 9 Mar 2009 06:41:00
Message: <49b4f23c$1@news.povray.org>
> read).
I haven't found that to be a problem yet.
The main problem for me is that they're just not bright enough. I
actually can't tell what colour my clothes are in the morning because I
don't have 20 minutes to stand there waiting for the thing to get bright.
> just to put a mixture of different coloured LEDs in one "lamp" to give
> whatever white temperature you want.  The other way is to put a yellow
> phosphor infront of a blue LED, but that's not as efficient electrically
> (it means you can get white from a single LED though).
OK, I rephrase: I personally have yet to see a "white" LED that wasn't
actually pale blue.
> use, the designs I've seen have been mainly heat sink, but they seem to
> have overcome that for 60W and 100W equivalent bulbs:
Well, I'm sure the technology won't stand still. IIRC, my dad has some
small LED ligth fittings illuminating the stairs. But they're not very
bright. (Despite containing about a dozen LEDs each.)
Date: 9 Mar 2009 07:35:10
Message: <49b4feee$1@news.povray.org>
> actually pale blue.
That's because you're used to "normal" light bulbs that are very very yellow
(just try taking a photo indoors with the camera on "outdoor" setting and
you'll see what I mean).  It's not that LED manufacturers can't make this
colour, it's just there is no demand for it (backlights for LCDs need a much
bluer white than normal light bulbs).  If you want to make a yellower colour
yourself then you can make your own yellow phosphor to put on a blue LED, or
just place some yellow LEDs around the white ones :-)
Date: 9 Mar 2009 07:42:25
Message: <49b500a1$1@news.povray.org>
>> actually pale blue.
> yellow.
How about sunlight? Is that yellow too? (I mean, by the time it reaches
the ground.)
> can't make this colour, it's just there is no demand for it (backlights
> for LCDs need a much bluer white than normal light bulbs).  If you want
> to make a yellower colour yourself then you can make your own yellow
> phosphor to put on a blue LED, or just place some yellow LEDs around the
> white ones :-)
Heh. The trouble is the light in my room ("energy saving bulb") gives
off such a pinky yellowy colour that I can't actually tell whether an
item of clothing is blue or black. :-P
Date: 9 Mar 2009 08:23:20
Message: <49b50a38@news.povray.org>
> the ground.)
It's really difficult to say, as everything to do with "white" is relative
and your brain does a really good job of filtering out changes in white
balance of your environment.
Here's a chart I found detailing the sunlight spectrum:
http://org.ntnu.no/solarcells/pics/chap2/Solar_Spectrum.png
You tell me if that's "yellow" or not :-)
> Heh. The trouble is the light in my room ("energy saving bulb") gives off
> such a pinky yellowy colour that I can't actually tell whether an item of
That's not so much to do with the absolute colour of the white light, but
with the spectrum.  If you have two monochromatic light sources from a
yellowy-red laser and a blue laser you can make white light.  THe problem is
when you try to illuminate something with that white light, the only thing
you will see is how well the object reflects those particular two laser
wavelengths.  On the other hand, white light from a black body gives you a
much better impression of the "colour" of an object because it consists of
visible light from all wavelengths.  There's a thing called "colour
rendering index" (CRI) that describes this quality of white light.
Date: 9 Mar 2009 12:55:38
Message: <49b54a0a$1@news.povray.org>
"Saul Luizaga" <sau### [at] netscapenet> wrote in message
news:49b40bc4$1@news.povray.org...
> http://www.worldcommunitygrid.org/about_us/viewAboutUs.do
> http://www.one.org/
> If you have any spare core(s)/CPU(s) please help to help, is for
> Humanity sake, thank you.
"Humanity's sake" is all nice and good, but if these grid projects are to
achive better success, they should consider some minimal payment, to
compensate for energy usage at least. Nothing is free, and in the end, that
anti cancer drug you help discover (albeit in an extremely minor way) will
be sold to you at hundereds or thousands of dollars a pop if and when you
need it. An alternative is to make such research and end products public
domain and patent free.
Date: 9 Mar 2009 13:00:01
Message: <web.49b54ab8e57dbb08a45f86ff0@news.povray.org>
If the concern is really over electricity usage, consider that a supercomputer
center is always climate controlled, year-round. Whereas leaving my home
computer powered on (with monitor off) 24hrs a day is helping reduce my usage
of propane to heat my home during the winter months. All while helping
scientists learn how they will cure me of cancer when I reach that stage in
life.
To build a supercomputer center requires many years, and committees, and who
decides what runs on it? And who will fund the construction? Who funds the
ongoing operations? What does the machine do when it would otherwise be idle?
Sometimes all the bureaucracy that surrounds such projects gets in the way of
good fundamental science.
Learn more about Rosetta@home. Helping do the research with my home computer is
something that can be done today. No need for a government approval or
committee meeting. I've got it running right now, in the idle time between
keystrokes. The cost of the power used by a computer is minimal compared to the
cost of trying to treat someone with cancer using today's methods. Think of it
as an insurance policy. Or a savings plan with compound interest.
http://www.youtube.com/watch?v=GzATbET3g54
http://boinc.bakerlab.org/rosetta
