POV-Ray : Newsgroups : povray.off-topic : Who says .NET is slow...? Server Time
16 May 2026 03:32:19 EDT (-0400)
  Who says .NET is slow...? (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Who says .NET is slow...?
Date: 21 Feb 2009 23:30:57
Message: <49a0d501$1@news.povray.org>
Darren New wrote:
> I would think there's relatively little need to be slow in a program
> like this, where it's all manipulation of fundamental structures. As in,
> I would think the speed of a program like this in .NET wouldn't
> necessarily be any slower than a similar program in plain C, unless the
> JIT is just really bad.
But, that's sort of my point. :) You don't need to be down to the wire
to get fast performance out of the system.
> Was there really any reason to use the unsafe pointers?
There was. There are 2 ways to access the bitmap data. One by using the
setpixel and getpixel functions. This is very slow. essentially every
access to the pixel data requires a conversion to and from a color
structure.
The other way is to access the buffer directly, hence the unsafe pointers.
Date: 22 Feb 2009 12:48:24
Message: <49a18fe8$1@news.povray.org>
>> in, I would think the speed of a program like this in .NET wouldn't
>> the JIT is just really bad.
OK. I'm just saying ... what makes you think it's not "down to the wire" in
this case?  It doesn't look like you're doing anything in the inner loops of
the tick that you couldn't do equally well in C, so why wouldn't the JIT
generate equivalently efficient code?
> structure.
Cool. I've only done large-scale manipulations, not drawing pixel-by-pixel,
so I guess I never ran into that problem.
   My fortune cookie said, "You will soon be
   unable to read this, even at arm's length."
Date: 22 Feb 2009 13:10:30
Message: <49a19516@news.povray.org>
Mike Raiford wrote:
> 1024x768 frame buffer...
I estimate I'm getting 0.5fps.
Date: 22 Feb 2009 14:32:52
Message: <49a1a864@news.povray.org>
Wow... are you running Vista, by any chance..? On my WinXP machine, I
was getting about 20fps..
I found that on my Vista machine it runs significantly slower.
Date: 22 Feb 2009 14:39:55
Message: <49a1aa0b$1@news.povray.org>
Darren New wrote:
> in this case?  It doesn't look like you're doing anything in the inner
> loops of the tick that you couldn't do equally well in C, so why
> wouldn't the JIT generate equivalently efficient code?
Maybe it is, but everything is still managed code. The JIT should
produce efficient code, for sure, and it does. I was just happy to see
that an effect like this can be achieved, and with a relatively large
frame buffer. That's all I guess. Some seem to think that the .NET
framework, or that JIT environments are too slow for these sorts of
tricks, or effects.
I think, didn't someone port Quake to Managed C++?
> pixel-by-pixel, so I guess I never ran into that problem.
Right, the GDI+ functions are generally pretty good for most drawing
situations.
Date: 22 Feb 2009 15:48:46
Message: <49a1ba2e$1@news.povray.org>
> tricks, or effects.
True. People who never really think about the issues tend to just listen to
the FUD.
Yes, but I'm not sure they ported the "hard parts". As in, it was something
like a few hundred lines of code written over the course of a handful of
hours to "port" it. I don't think they (for example) moved all the data
structures into managed space, other than perhaps the screen and keyboard I/O.
> situations.
I thought the transformation matrix approach to color control was pretty
cool. Probably pretty common across toolkits, I'd guess, tho.
Date: 23 Feb 2009 02:35:45
Message: <49a251d1$1@news.povray.org>
Running Vista here, I estimate about 10-20 fps (assuming it goes up one line
per frame).
It's only using 1 of my cores though .... :-)
Date: 23 Feb 2009 02:37:00
Message: <49a2521c$1@news.povray.org>
> I would think there's relatively little need to be slow in a program like
I think the GPU would be faster at this sort of program than the CPU :-)
Date: 23 Feb 2009 06:56:14
Message: <49a28ede@news.povray.org>
> line per frame).
Then why the hell is my Vista box always so freaking slow?!!
Yeah, I didn't get all fancy and multi-threaded.. I suppose it could be
easily parallelized, though.
Date: 23 Feb 2009 07:16:20
Message: <49a29394$1@news.povray.org>
>> line per frame).
Ooh I just tried it on my XP laptop, and by the time the red has got to the
top it's only 80% of the way there on Vista.  My Vista box is about 10x
faster than my laptop so who knows what is going on.
Does it make a difference under Vista if you take out the
"ControlStyles.OptimizedDoubleBuffer" flag?
Also you are locking the bitmap for quite a long time (relatively), you
should literally lock, memcopy, unlock. Any processing should be done
outside of that on a separate buffer.  Maybe it is holding up Vista somehow
when it's trying to copy the bitmap to the graphics card?
