![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 11 Feb 2009 11:56:50 -0800, Darren New wrote:
> Jim Henderson wrote:
>> Ouch indeed. Kinda the reverse of what nearly everyone I know who
>> learned to drive a stick went through when not timing the clutch
>> properly when shifting.
> Oh, I did that too. This was years after I learned to drive a stick. I
> just wasn't really paying attention to the controls as such. Just, you
> know, drivin'.
Yep, I managed it when I tried driving a stick for the first time in
years myself. Takes a few tries to get the hang of it again.
At least when I drove in England, I was driving an automatic. I don't
know that I'd get used to shifting with the lever on the wrong side (Yes,
Stephen, the left side is the WRONG side <g>).
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Of course it is, it isn't the American Way ;)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>(Yes, Stephen, the left side is the WRONG side <g>).
<Grumble> I shoulda expected THAT. ;-)
(Haven't you noticed my spelling?)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Um, no, the brakes don't do the same - if you have disc brakes, the
> brakes stop the wheels when fully engaged
Of course, because through the brakes you are applying more torque than the
tyre/road surface can provide, so the wheel locks.
> Conversely, by downshifting, you increase the
> engine revs and the wheels are not locked - they still turn.
Only because *usually* the negative torque applied from the engine is not
enough to overcome the grip between the tyre/road. Try downshifting on ice
or even on wet tarmac violently (eg 4th to 2nd at 40mph) and you will lock
the wheels (certainly audible on wet/dry tarmac).
BTW the two effects add up, so if you are already braking hard with the
pedal, downshifting hard at the same time will likely lock the wheels
easily, this is why racing drivers always "blip" the throttle while braking
and changing down, to avoid the engine braking that could lock the wheels.
> Now, when you're on dry pavement, the wheels normally don't lock because
> the car's momentum overcomes the friction on the brakes, bringing you to
> a gentle (or sometimes less-than-gentle) stop. On ice, though, it takes
> less friction of the brake pads against the wheel to stop the wheels
> because it takes less to overcome the friction of the wheel against the
> ground.
> So it's easier to lock the wheels up and skid.
Yes, and the same applies to engine braking. Next time it's wet or snowy
try changing down (a couple of) gear(s) and letting the clutch out quickly,
you'll hear/feel the driven wheels lock until the car slows enough for the
wheels to grip again. Obviously on snow and ice this happens easier.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No, you are asking a dyslectic about spelling? :)
Anyway I am used to reading American spelling now and translate into proper
English, automatically. It is BTW one way. :)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> the tyre/road surface can provide, so the wheel locks.
Exactly my point.
>> Conversely, by downshifting, you increase the engine revs and the
> not enough to overcome the grip between the tyre/road. Try downshifting
> on ice or even on wet tarmac violently (eg 4th to 2nd at 40mph) and you
> will lock the wheels (certainly audible on wet/dry tarmac).
I wouldn't do 4th to 2nd. Always one gear at a time, otherwise as you
state, you can cause the wheels to lock up. What you're looking to do is
*gradually* slow down, so doing things that work contrary to that goal
like downshifting two gears are obviously going to not achieve that goal.
> braking and changing down, to avoid the engine braking that could lock
> the wheels.
Well, see my above paragraph. Sure, if you do things that are contrary
to the goal of gradually slowing the vehicle down, you're going to wind
up in trouble.
>> because the car's momentum overcomes the friction on the brakes,
>> bringing you to a gentle (or sometimes less-than-gentle) stop. On ice,
>> though, it takes less friction of the brake pads against the wheel to
>> stop the wheels because it takes less to overcome the friction of the
>> wheel against the ground.
> snowy try changing down (a couple of) gear(s) and letting the clutch out
> quickly, you'll hear/feel the driven wheels lock until the car slows
> enough for the wheels to grip again. Obviously on snow and ice this
> happens easier.
I've used engine braking enough that I don't need to "try it", and like I
said, of course you can *make* it do it, but that's not the goal. The
goal is to use the tools available in a way that is appropriate to get a
gradual slowdown in speed, not a sudden change that's going to send you
out of control.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
LOL, arguably, the question comes up if a dyslexic person wouldn't in
fact describe themselves as "lysdexic"....?
> proper English, automatically. It is BTW one way. :)
So all my automated typing of things into UK English (I usually have to
correct for an American audience, in fact, because it is automatic for me
99% of the time) has just gone right past?
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No.
I often type it dislyxic, I know that there is a "y" in there somewhere. I can
see that it is not right but have never been able to remember the spelling.
Yes.
Occasionally I notice as I know that you are an American but generally I just
read it and think nothing of it. Actually since you mention it, why and what do
other Americans think of you writing like a limey?
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> No.
Well, I was making a joke - if it touched too close to home, please
accept my most sincere apologies.
> I can see that it is not right but have never been able to remember the
> spelling.
I could see that. I often will spell something the way I think it's
spelt and it doesn't look right. In my newsreader, of course, it doesn't
look right because of the squiggly red line underneath the word.
>>me 99% of the time) has just gone right past?
> Yes.
I guess since it's normal spelling for you, it would - that makes sense.
> just read it and think nothing of it. Actually since you mention it, why
> and what do other Americans think of you writing like a limey?
I occasionally get grief from people about it, or light joking about it.
One of my coworkers noticed it a few years ago and asked me about it -
not because he was anything other than curious, though - his background
is linguistics.
I don't know why I started using Queen's English spellings, though - just
became a habit. Possibly because I spent a lot of my time writing to
brits. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> No.
No you didn't, I'm long past caring what people think 'cause I can't spell or
read big books. :)
I do get pissed off with people who don't take the trouble to check their
spelling especially when they know they can't spell. I even use "Word" when I'm
writing a hand written note or letter. But then I'm from a generation where it
was considered important U no wat I meen?
>> spelling.
I've switched that feature off in my newsreader. It would drive me mad seeing
other posts :lol:
>> Yes.
It does :)
>is linguistics.
>brits. :-)
If you can't beet them, join them ;)
Did you know that the term "Brit" used to be offensive? It was used by the Irish
republicans during the troubles and was not complimentary ;) Nowadays the word
is in favour.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
