POV-Ray : Newsgroups : povray.off-topic : Random: FFT, Organ, Blahblah.. Server Time
28 Feb 2026 23:12:25 EST (-0500)
  Random: FFT, Organ, Blahblah.. (Message 1 to 9 of 9)
Subject: Random: FFT, Organ, Blahblah..
Date: 30 Jan 2009 09:12:35
Message: <49830ad3$1@news.povray.org>
Heh, neat... when messing with the FFT toy in polar mode (I've now fixed
phase so it actually allows edits from π to -π You can actually see the
phase of the waves change.
Silly, I know. The scaling seems right, but just sort of. Editing in the
frequency domain makes the time domain really big.. :/
I really need to add my waveform/function feature now so I can play with
different waveforms.
Next: write an FFT filtering algorithm and export the resulting wav.
Now...
I was playing around with the tone generator in Cool Edit, and
discovered something that's probably smackingly obvious. If you set the
   tones to the fundamental, then 1x 2x 4x etc ... it sound exactly like
an organ. if you do 1x 3x 5x 7x setting each subesequent to half, you
get an approximation of a square wave. 1x 2x 3x 4x, again half each, you
get an approximation of a sawtooth wave.
Now I did know that would be a likely outcome, but it was kinda neat
that I could hand make a square wave.. :)
~Mike
Subject: Re: Random: FFT, Organ, Blahblah..
Date: 30 Jan 2009 10:17:03
Message: <498319ef@news.povray.org>
If you add lots of waves together, the resulting wave is very large.
Normally waves containing lots of frequencies have very little energy at
each specific frequency, because it's so spread-out.
Good luck! ;-)
> If you set the
> an organ.
Yes. I myself have in fact used this in a musical composition. I wrote a
small BASIC program that generated various waveforms, and then used
OctaMED to play tunes with them.
Thinking about it... one technique frequently used in real organs is to
play several stops at once, each tuned to some octave of the
fundamental. (I.e., a power of two of the frequency.) If you assume the
tone of each pipe is approximately a pure sinewave, this is what you get.
Assuming the amplitude is the reciprocol of the frequency, yes. This is
the Fourier series of that waveform.
> 1x 2x 3x 4x, again half each, you get an approximation of a sawtooth wave.
Again, yes.
Also, if you take the square wave, make the amplitude the reciprocol of
the *square* of the frequency, and make every other wave shifted 180°
out of phase, you get a triangle wave.
Date: 30 Jan 2009 10:43:17
Message: <49832015$1@news.povray.org>
> Good luck! ;-)
Heh. Thanks. I'll post the program (and the results) when I'm done ;)
I'm doing all of this in C#. You should give C# a try, really. It
doesn't bite. :) I promise... ;)
You seem to think this will be exceedingly difficult?
>> If you set the tones to the fundamental, then 1x 2x 4x etc ... it
>> sound exactly like an organ.
So, combining square waves?
Yep. I was actually attempting to seek out the organ sound. I knew the
frequencies were related, I just couldn't figure out the relationship
till I tried 4 frequencies spaced an octave apart.
Odd how all sounds are some fundamental frequency + a combination of
related frequencies (either harmonic or aharmonic)
>> if you do 1x 3x 5x 7x setting each subesequent to half, you get an
amplitude was 1/harmonic * 100. It was darn close. Interestingly the
right channel was 90° out of phase, which produced an interesting
looking but identical sounding wave.
>> wave.
> Again, yes.
It should be possible to generate a Fourier series by using an iFFT to
get a band limited saw/square/triangle, no?
... rather than iteratively combine the waveforms (which takes forever
... the DOSBOX MT32 used that technique. it would generate the waves and
save the resulting wavetable to disk after the first run. Yes, the MT32
emulator was part wavetable/part pcm sampler, the real thing was part
pcm/part subtractive)
It seems this would be a much quicker way to generate the proper waveforms.
~Mike
Date: 30 Jan 2009 10:56:54
Message: <49832346$1@news.povray.org>
> You should give C# a try, really. It doesn't bite. :) I promise... ;)
Well for a start I'd need the hated .NET runtime first... :-P
>> a small BASIC program that generated various waveforms, and then used
Well, I wrote a program that would sum sinewaves together in various
ways to produce different waveforms. It sounded a bit like a filter
sweep. (Back when I was 12, I didn't know how to perform a *real* filter
sweep!)
Er, no... Actually it's a basic consequence of physics, and that's why
the human auditory system is turned to detect it. ;-)
As an aside: You can use waveshaping to add new *higher* frequency
components, but never *lower* frequency ones.
>> is the Fourier series of that waveform.
Yes. The human ear is insensitive to the relative phase between
frequency components. (Lossy compression algorithms frequently take
advantage of this.) Note that nonlinear systems that the waves pass
though might respond differently though (e.g., your speakers).
Yes.
Depends how many waves you want, at what sampling frequency. But yes, at
some point FFT becomes faster.
Date: 30 Jan 2009 11:06:24
Message: <49832580$1@news.povray.org>
Whats the difference between .NET and, say, JRE? Why so against the .NET
framework?
> sweep!)
of course... For some reason I pictured you generating the sounds
through the PC speaker, recording them recombining them.
What amazes me is how the ear detects sounds. It literally works in the
frequency domain. :)
Right.
> Yes.
I wonder in this case. I'll have to grab the source again and look at
how it was done.
~Mike
Date: 30 Jan 2009 11:13:35
Message: <4983272f$1@news.povray.org>
About 400MB. *rimshot*
> Why so against the .NET framework?
Java I just about put up with because it allows you to write software
that will (easily) work on more than one platform. And because it has
libraries which (just about) allow mere mortals to do things like
multithreading, database access, graphics and sound, which would
otherwise be impossible.
The .NET framework, on the other hand, it a vast sprawling mass of
inefficiency which is more or less Windows-only. It has all the
downsides of Java, without the advantages. And, obviously, it's made by
M$, which everybody hates. ;-)
Millions of years of evolution, my friend. ;-)
Actually, it wouldn't surprise me if the ear itself doesn't do a very
good frequency analysis, but the brain post-processes it. Do you have
*any idea* how crap the image data from your retinas is?? It's amazing
humans can see at all...
Date: 30 Jan 2009 11:32:47
Message: <49832baf$1@news.povray.org>
.NET is big, but it's hardly inefficient. I'm the opposite. I don't care
for Java. every Java-based application I've come across feels like its
on the verge of total collapse. .NET apps on the other hand feel rather
stable.... and mono allows cross-platform development.
.NET has similar libraries. I'd hazard a guess and say that its easier
to do such things as graphics and sound under .NET
The 2.0 framework is 22M, Granted, 3.5 is a whopping 200MB o_0
But I could easily retarget to 2.0...
>>> why the human auditory system is turned to detect it. ;-)
>> the frequency domain. :)
Hmm, each hair is at a length that resonates with a certain frequency.
I'd imagine there would be a lot of crosstalk, hairs tuned for harmonic
frequencies may also vibrate. Yep. a ton of post processing work to be
done. :)
Well, a very tiny spot in the middle of the field of view is quite
sharp, but other than that ... For fun. Look at a JPG file that appears
"perfect" separate the chromiance from the luminance. Luma will always
be nice and sharp. Chroma is likely extremely blocky. We don't notice
because we don't see color as well as we would like to believe we do. :)
~Mike
Date: 31 Jan 2009 03:37:14
Message: <49840dba@news.povray.org>
498319ef@news.povray.org...
> play several stops at once, each tuned to some octave of the fundamental.
> (I.e., a power of two of the frequency.) If you assume the tone of each
Not only octaves but even 5th , or better said 13th (octave+5th)  with a 2'
2/3 stop added to a 8'
When you press C1 key, it plays G2
That fakes the 3rd harmonic.
In French it is called "Nasard" because it gives sound a 'nose' colour.
In English 'Quinte flute'
Marc
Date: 31 Jan 2009 05:07:49
Message: <498422f5$1@news.povray.org>
Yes, that too...
(Although I must say, on the only organ I've ever played, the Mixture
III didn't sound very pleasent to my ears.)
http://blog.orphi.me.uk/
