POV-Ray : Newsgroups : povray.off-topic : Ok, who didn't know, or at least guess this? Server Time
5 Jul 2026 02:49:11 EDT (-0400)
  Ok, who didn't know, or at least guess this? (Message 109 to 118 of 218)
Subject: Re: Ok, who didn't know, or at least guess this?
Date: 30 Jan 2009 05:30:13
Message: <4982d6b5$1@news.povray.org>
>> No. But you make it sound as if all M$'s problems are because computer
>> hardware is unreliable.
> IME, every time I am called because of a friend/family computer "not
> working", it is nothing to do with MS.  I can give you a long list of
> reasons, mostly due to other software, hardware malfunction or drivers,
> but none MS.
Most of the problems I get to look at aren't due to M$ either - but a
significant number of them are.
>> This is manifestly not the case. M$'s problems are because they
>> produce poor quality products.
> I use MS products daily on 3 or 4 machines and cannot remember the last
> time one of them crashed or when MS Office behaved badly.
Actual OS crashes are fairly rare, assuming you use your computer in a
sane mannar.
But I'm not just talking about complete crashes of the entire OS, or
even crashes of a single application. I'm talking about the whole
quality equation - how M$ products in general tend to be unecessarily
complicated, poorly documented, resource-inefficient, insecure, and so
forth.
> You mention corrupted Word documents, but IIRC we decided that was due
> to everyone using the same template/file that was corrupted and
> spreading this corruption through all your documents.  This is not
> really a fault of MS Office, especially when you didn't even use the
> "Open and Repair" command which would have probably fixed the problem.
Let's suppose that a particular Word document is corrupted. Why should
that make Word crash? Shouldn't it just pop up a message saying "I can't
read this file, it seems to be corrupted"? Isn't that what "graceful
failure" is all about? But no, Word just crashes outright.
I opened the same file in OpenOffice, and it just opened up as if there
was nothing wrong with it. I saved it again, and it has worked in Word
ever since.
Why is it that Word, a premium product designed and produced by the
richest software company on earth, cannot do something that OpenOffice
can? The people developing OO didn't even have access to a description
of the file format; they had to reverse-engineer it. And yet, they
somehow did a better job than the people who *designed* that file
format. How can that be right??
(Let us not go into the fact that Word costs almost infinity times more
than OpenOffice to start with...)
Date: 30 Jan 2009 06:07:19
Message: <4982df67@news.povray.org>
> how M$ products in general tend to be unecessarily complicated, poorly
> documented, resource-inefficient, insecure, and so forth.
TBH I've found MS products to be really well documents, in fact I would say
better than any other software I've used.  Really, even if you have a
complicated thing you want to do in Excel, the documentation usually has the
answer.
Yeh, they should just use the code from "Open and repair" for the normal
"Open" operation, and if there were no faults just act silently.  OTOH maybe
load times would increase significantly for large documents?
> can? The people developing OO didn't even have access to a description of
> the file format; they had to reverse-engineer it. And yet, they somehow
> did a better job than the people who *designed* that file format. How can
> that be right??
I think you've answered your own questions there anyway, MS has to make
money so they have all sorts of constraints that OpenOffice doesn't.  If an
OpenOffice update is delayed by 6 months because they are fixing the
loading-corrupt-files code, nobody can complain. But if MS attempts to delay
Office 2013GT by 6 months because they want to fix the loading-corrupt-files
code, they will likely be forced to release it anyway by the financial
people.
Date: 30 Jan 2009 06:13:38
Message: <4982e0e2$1@news.povray.org>
> say better than any other software I've used.  Really, even if you have
> a complicated thing you want to do in Excel, the documentation usually
> has the answer.
Well, there are plenty of open-source projects that have *no*
documentation at all. OTOH, most of what M$ provides leaves much to be
desired. (E.g., I managed to find a KB article explaining how to use the
Recovery Console. Except that, actually, it just duplicates, word for
word, the terse command help built into the Recovery Console...)
In general, if you're trying to do something simple (e.g., how do I
change the IE start page?), the documentation tells you. If you're
trying to do anything moderately nontrivial, the documentation tends to
not help at all... I guess this says something about their intended
target audience?
>> can't read this file, it seems to be corrupted"? Isn't that what
>> "graceful failure" is all about? But no, Word just crashes outright.
> maybe load times would increase significantly for large documents?
I don't know, but you'd think they could at least install an exception
handler around the load routine so that if it fails, it doesn't crash
all of Word, just the document load engine. Or *something*...
>> more than OpenOffice to start with...)
> an OpenOffice update is delayed by 6 months because they are fixing the
> delay Office 2013GT by 6 months because they want to fix the
> loading-corrupt-files code, they will likely be forced to release it
> anyway by the financial people.
OTOH, OO is developed by a bunch of bored boffins in their spare time,
whereas M$ can afford to hire the brightest people in the business and
pay them to work on the problem 9-5 every single day. Given the hugely
superior resources available to M$, you'd *think* they could produce a
product that works properly under forceeable circumstances...
Date: 30 Jan 2009 06:23:45
Message: <4982e341$1@news.povray.org>
> In general, if you're trying to do something simple (e.g., how do I change
> the IE start page?), the documentation tells you. If you're trying to do
> anything moderately nontrivial, the documentation tends to not help at
> all... I guess this says something about their intended target audience?
Dunno, I've found lots of quite detailed articles before.
eg googling "windows recovery console" give me
http://support.microsoft.com/kb/314058
which tells me that you can use bootcfg without the /scan to avoid spending
hours scanning all your drives.
> handler around the load routine so that if it fails, it doesn't crash all
Maybe the load routine works fine, it just loads some corrupted data so when
another part of the program comes to use it that bit crashes?
> whereas M$ can afford to hire the brightest people in the business and pay
I think you overestimate how many people MS has working on such things.  The
main difference is MS can't just go and recruit 20 more people to work on
something, unless it is going to be *profitable* for them to do so.  If the
bored boffins at OO want to spend another 1000 man hours perfecting things,
they can, they don't have to worry about profit.
Date: 30 Jan 2009 06:32:35
Message: <4982e553@news.povray.org>
>> to not help at all... I guess this says something about their intended
>> target audience?
> spending hours scanning all your drives.
The command descriptions given here are a word-for-word reproduction of
the interactive command help. It does not explain anywhere, for example,
that bootcfg is merely a programatic way of editing BOOT.INI. (Also, it
seems that /scan, /add and /rebuild *all* scan your disks for hours -
I've tried it.)
*This* article explains it properly:
http://support.microsoft.com/kb/291980
> when another part of the program comes to use it that bit crashes?
Thinking about it, the load routine probably does just dump a bunch of
pointers directly into Word, which probably then trips the rendering
engine over or something. (I've seen Word go into in infinite loop
instead of crashing also. That, at least, you'd think would be
detectable quite easily.)
Uh... they're the largest software corporation on the face of the Earth?
(And the richest too.)
> The main difference is MS can't just go and recruit 20 more people to
> work on something, unless it is going to be *profitable* for them to do
> so.  If the bored boffins at OO want to spend another 1000 man hours
> perfecting things, they can, they don't have to worry about profit.
Well, if M$ doesn't consider "making our products work properly" to be a
"profitable" thing to do, then there's your answer. :-}
Date: 30 Jan 2009 07:14:19
Message: <4982ef1b@news.povray.org>
But still they cannot hire or steer extra employees onto projects without
justification.  That's the main point.  It's simply a matter of economics -
if MS pushed more resources onto fixing every little bug they'd run out of
money pretty quickly - it's just not feasible when you have to pay people to
write/debug your code.
Date: 30 Jan 2009 07:37:08
Message: <4982f474$1@news.povray.org>
>> Earth? (And the richest too.)
> without justification.  That's the main point.  It's simply a matter of
> economics - if MS pushed more resources onto fixing every little bug
> they'd run out of money pretty quickly - it's just not feasible when you
> have to pay people to write/debug your code.
Fixing every tiny bug might be infeasible, but you'd think they could at
least fix the huge ones.
Anyway, somebody asked why people hate M$. And I gave an answer: because
M$ does not consider performance or reliability to be "important" enough
to make any attempt to improve them.
Fortunately, the makers of safety-critical hardware and software are
bound by *laws* which prevent them from not fixing bugs just because
it's "not profitable".
Date: 30 Jan 2009 07:51:29
Message: <4982f7d1$1@news.povray.org>
> Fortunately, the makers of safety-critical hardware and software are bound
> by *laws* which prevent them from not fixing bugs just because it's "not
> profitable".
And as a result their software is orders of magnitudes more expensive, not
exactly something you could sell to the masses...
Date: 30 Jan 2009 07:55:07
Message: <4982f8ab$1@news.povray.org>
> And as a result their software is orders of magnitudes more expensive.
I'll grand you that.
OTOH, M$'s products aren't exactly "cheap", by any stretch of the
imagination. I think what most people really object to is paying vast
sums of money for a product that isn't actually all that good. Let's
face if, when you run KLogic and it crashes for the 18th time, you think
to yourself "oh well, it least it didn't cost me anything". If you paid
£400 for a piece of software and it behaved the same way, you'd be
pretty upset.
Date: 30 Jan 2009 08:10:09
Message: <4982fc31$1@news.povray.org>
> imagination.
I don't think paying 2x-3x the price of a game for your OS and Office suite
is expensive, and I guess most other people don't either.
> I think what most people really object to is paying vast sums of money for
> a product that isn't actually all that good. Let's face if, when you run
> KLogic and it crashes for the 18th time, you think to yourself "oh well,
> it least it didn't cost me anything". If you paid £400 for a piece of
> software and it behaved the same way, you'd be pretty upset.
Agreed, but my Windows or Office doesn't crash 18 times, and I didn't pay
400 pounds for it :-)
However we did pay 10 thousand pounds for some CAD software, and that
crashes occasionally (which is infinitly more often than the OS!).
