POV-Ray : Newsgroups : povray.off-topic : Acer Aspire 5000 Server Time
8 Feb 2026 22:57:12 EST (-0500)
  Acer Aspire 5000 (Message 1 to 10 of 63)
Subject: Acer Aspire 5000
Date: 7 Jan 2009 11:52:50
Message: <4964dde2$1@news.povray.org>
OK, so here's a question...
My sister has an Acer Aspire 5000 laptop. It used to work just fine, but
recently it has developed some disturbing symptoms - basically random
freezing.
The utterly weird thing is, it behaves perfectly under [several
different variants of] Linux, but continues to randomly freeze when
running under Windows. [I have reinstalled Windows several times now.
Interestingly, it always seems to hang at the same places in the
installation sequence.]
The symptoms:
- Laptop no longer responds to keyboard or mouse. (Mouse pointer won't
move, Ctrl+Alt+Del is no-op, the capslock light doesn't function when I
press the key, etc.)
- On every laptop known to man, holding down the power button will
forcibly power down the laptop. This does not work while the laptop is
frozen. (Fortunately the battery typically dies after ~5 minutes or so.)
- The laptop *does* respond to some things though. Unplugging the
Ethernet cable still pops up that retarded "a cable is unplugged" message.
- The fans seem to spin up while the laptop is hang, suggesting an
infinite loop in the software somewhere.
- I am reasonably sure the laptop is not overheating. It seems cold to
the touch, and it repeatedly hangs at *exactly* the point in Windows,
and has never done this even once under Linux.
- Repeated memory tests reveal no problems of any kind.
- I have reinstalled Windows multiple times, without any Internet
access, so I'm downright certain it's not a virus or a software
configuration issue.
To reiterate, when the laptop was new, it had none of these issues.
(Although it was dissapointingly slow.)
Does anybody have the slightest clue what the *hell* is causing this
frustrating behaviour?
Subject: Re: Acer Aspire 5000
Date: 7 Jan 2009 12:07:31
Message: <4964e153@news.povray.org>
Invisible wrote:
Are they any devices/gizmos/etc that don't work on Linux? WLAN?
Bluetooth? Card reader? Anything?
-Aero
Date: 7 Jan 2009 12:54:25
Message: <4964ec51$1@news.povray.org>
Wow. I was under the impression this was built right into the power
supplies. Maybe not on a laptop, tho.
I have a friend who was designing motherboards for specialized systems like
disk array servers. He told me he spent three days trying to figure out why
the system would power off seven seconds after he plugged it in each time.
Turns out it took three seconds to initialize the board enough that the
signal from the power supply could be read, and he'd wired that wire
backwards, so four seconds later it would turn off again.
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 7 Jan 2009 13:09:11
Message: <4964efc7$1@news.povray.org>
Here's a thought. See if you can configure the BIOS to turn off APCI stuff?
The "advanced" power control? Linux tends to handle this differently, and
perhaps Windows is confused by some problem being caused by this.
No idea why it would crop up after a while, tho.
Date: 7 Jan 2009 15:53:29
Message: <49651649$1@news.povray.org>
What are you using to do the memory tests?
Jim
Date: 7 Jan 2009 17:16:50
Message: <496529d2$1@news.povray.org>
memtest86
http://blog.orphi.me.uk/
Date: 7 Jan 2009 17:48:17
Message: <49653131$1@news.povray.org>
> memtest86
86, or 86+?  ISTR that 86+ is more thorough, but 86 should be sufficient.
Jim
Date: 8 Jan 2009 02:54:58
Message: <4965b152$1@news.povray.org>
> The utterly weird thing is, it behaves perfectly under [several different
> variants of] Linux, but continues to randomly freeze when running under
> Windows. [I have reinstalled Windows several times now. Interestingly, it
> always seems to hang at the same places in the installation sequence.]
Sounds to me like it is one particular piece of hardware/driver
malfunctioning.  Under Linux it either has a different driver or is just not
used at all (as already mentioned).
I would try booting Windows in safe mode and seeing if that is stable.  If
so then I would reboot normally and disable all non-critical hardware in
device manager.  If it is still stable then selectively restart hardware
until it you find the culprit.  If you are really lucky a driver update
might fix it...
Date: 8 Jan 2009 04:11:37
Message: <4965c349$1@news.povray.org>
> malfunctioning.
This is my feeling also. It used to work just fine, and now it doesn't,
despite multiple reinstalls, which suggests a hardware issue. (But I
have no idea which bit of hardware.)
I did think perhaps it was the audio - my sister mentioned the sound
suddenly stopped working a while ago, and sure enough the machine locked
shortly after I installed the audio drive.
...but then I reinstalled without the audio driver, and it still
randomly hangs. *sigh*
Ah, the joy of intermittent faults. Is it *really* gone? Or is it just
not happening right now? :-/
> If so then I would reboot normally and disable all non-critical hardware
> in device manager.  If it is still stable then selectively restart
> hardware until it you find the culprit.  If you are really lucky a
> driver update might fix it...
Well, currently I have installed Windows plus every update that Windows
Update will give me. I haven't *seen* it crash since that time, but.....
Date: 8 Jan 2009 04:51:55
Message: <4965ccbb@news.povray.org>
Ah, the joy of *extremely* intermittent faults :-)
Have you looked in the Event Viewer (I think it's called that in XP too) to
see what happened when it crashed?
It seems from your comments that the laptop is still running, just not
responding to user input.  Is this the internal mouse and keyboard? Try
plugging in an external USB mouse next time it "freezes".
