![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> - On every laptop known to man, holding down the power button will
> forcibly power down the laptop.
Here's a thought. See if you can configure the BIOS to turn off APCI stuff?
The "advanced" power control? Linux tends to handle this differently, and
perhaps Windows is confused by some problem being caused by this.
No idea why it would crop up after a while, tho.
Why is there a chainsaw in DOOM?
There aren't any trees on Mars.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 07 Jan 2009 16:52:51 +0000, Invisible wrote:
> - Repeated memory tests reveal no problems of any kind.
What are you using to do the memory tests?
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
memtest86
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> memtest86
86, or 86+? ISTR that 86+ is more thorough, but 86 should be sufficient.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> The utterly weird thing is, it behaves perfectly under [several different
> variants of] Linux, but continues to randomly freeze when running under
> Windows. [I have reinstalled Windows several times now. Interestingly, it
> always seems to hang at the same places in the installation sequence.]
Sounds to me like it is one particular piece of hardware/driver
malfunctioning. Under Linux it either has a different driver or is just not
used at all (as already mentioned).
I would try booting Windows in safe mode and seeing if that is stable. If
so then I would reboot normally and disable all non-critical hardware in
device manager. If it is still stable then selectively restart hardware
until it you find the culprit. If you are really lucky a driver update
might fix it...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> different variants of] Linux, but continues to randomly freeze when
>> running under Windows. [I have reinstalled Windows several times now.
>> Interestingly, it always seems to hang at the same places in the
> malfunctioning.
This is my feeling also. It used to work just fine, and now it doesn't,
despite multiple reinstalls, which suggests a hardware issue. (But I
have no idea which bit of hardware.)
I did think perhaps it was the audio - my sister mentioned the sound
suddenly stopped working a while ago, and sure enough the machine locked
shortly after I installed the audio drive.
...but then I reinstalled without the audio driver, and it still
randomly hangs. *sigh*
Ah, the joy of intermittent faults. Is it *really* gone? Or is it just
not happening right now? :-/
> If so then I would reboot normally and disable all non-critical hardware
> in device manager. If it is still stable then selectively restart
> hardware until it you find the culprit. If you are really lucky a
> driver update might fix it...
Well, currently I have installed Windows plus every update that Windows
Update will give me. I haven't *seen* it crash since that time, but.....
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ah, the joy of *extremely* intermittent faults :-)
Have you looked in the Event Viewer (I think it's called that in XP too) to
see what happened when it crashed?
It seems from your comments that the laptop is still running, just not
responding to user input. Is this the internal mouse and keyboard? Try
plugging in an external USB mouse next time it "freezes".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Indeed!
> to see what happened when it crashed?
Yeah, "crashed" would seem an exaggeration. More like "suddenly going
extremely slowly". (IIRC, the CPU graph in Task Manager stops scrolling,
for example.)
I'm using the internal glide pad. I didn't have a USB mouse with me. I
guess I could give that a try...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New wrote:
>> forcibly power down the laptop. This does not work while the laptop is
>> frozen. (Fortunately the battery typically dies after ~5 minutes or so.)
> Wow. I was under the impression this was built right into the power
> supplies. Maybe not on a laptop, tho.
Indeed.
On the other hand, I was *also* under the impression that the cooling
fan is hardware-controlled. But it turns out to be software-controled. (!!)
I discovered this while trying to install SUSE on my dad's ancient brick
of a laptop. The install kept failing in bizare and unexplained ways.
Until I picked up the laptop and almost burnt my hand off!
We rebooted the laptop, and as soon as the BIOS screen showed up, the
fans started spinning like mad. We waited for them to slow down. (It
took a while.) Then we resumed the installation attempt. Same problem.
No matter how hot the laptop got, no fans.
The solution in the end was quite simple. Reboot with the laptop hot.
The fans spin up to full power. Rather than waiting for them to stop,
just start installing. The fans remained at full speed until the system
soft-reset onto the new kernel. After that they appeared to work "normally".
GO. FIGURE.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> We rebooted the laptop, and as soon as the BIOS screen showed up, the fans
What software was running then while you were waiting?
> The solution in the end was quite simple. Reboot with the laptop hot. The
> fans spin up to full power. Rather than waiting for them to stop, just
> "normally".
I notice when I boot up my Vista box, that every fan runs at full blast
until some point during Vista boot, whereby first the CPU fan virtually
turns off, then a few seconds after the desktop appears the GPU fan
virtually turns off, all I can hear then is just occasional blips of hard
drive head movement - until I fire up a 3D game, then all hell breaks loose
again :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
