POV-Ray : Newsgroups : povray.off-topic : Reserved words redux Server Time
16 May 2026 11:14:50 EDT (-0400)
  Reserved words redux (Message 11 to 20 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Reserved words redux
Date: 17 Oct 2008 23:10:57
Message: <48f953c1$1@news.povray.org>
Darren New wrote:
> nemesis wrote:
>> That would utterly suck.  Programming languages should be about
>> meaning and meaning is conveyed by words, not by how they are drawn or
>> spelled.
> Meaning isn't conveyed by words in programming languages. It's conveyed
> by tokens and formal matches between tokens at different parts of the
> source.
> { int index = 23;
>   cout << index;
> The meaning there isn't conveyed by "int". In chinese, you might use
> something different than "int" (maybe 整數 or something) and it would be
> just as meaningful if not moreso to a native chinese speaker (assuming
> you fixed the compiler, of course).  The compiler doesn't care what
> token you use to mean what Warp means by "int" in his code.
Fine.  整數 is still a word with a meaning associated, which is my
point:  words should convey meaning, not how 整數 is written or spelled.
I mean, surely 整數 can be written in italics or bold without altering
its meaning.  And no, I'm not a fan of case-sensitive syntax either.
>> Let external tools do any styling to the source text if you will.
> OK, so reserved words are in greek, and user-defined words are in latin
> characters, no matter what fonts you use. Better?
Yes.  You may use whatever font you please, as long as it's Unicode and
can correctly display the greek and latin words in the text or else the
meaning is lost.  This is not the same as styling with bold or italics,
nor as capitalizing words.
Date: 17 Oct 2008 23:27:09
Message: <48f9578d@news.povray.org>
somebody wrote:
> "nemesis" <nam### [at] gmailcom> wrote in message
> news:48f8f145$1@news.povray.org...
>> That would utterly suck.  Programming languages should be about meaning
>> and meaning is conveyed by words, not by how they are drawn or spelled.
> Meaning is conveyed by anything that is meant to convey meaning, be it
> words, grunts, connections between gears, flowcharts, hearldry symbols,
> colours... etc.
You know?  That's very true.  And I can even imagine a tokenizer to a
compiler accepting italicized words to be different from non-italicized
words if it was to internally apply some transform like:
*Foo* /foo/;
bold_foo -> italic_foo ->
etc.
To me, it just sucks, though.  It means, when I'm writing a program I
have now to think not only of good identifier names, but also of
correctly applying the right styling, besides also capitalization.
> Pictorial representations will eventually assume a more
> prominant role in general programming.
Sure, UML and company have been around for quite some time already.  And
it all eventually gets converted to a stream of text in some language
anyway, and that to a stream of bytes in machine language, so hey!,
perhaps it's time we communicate using just jpgs and emoticons as well... :P
I for one find some things much easier to write about than to drag
balloons, boxes and arrows around and apply meaning by combos,
radiobuttons and so on, besides messing with a UI looking like that of a
top aircraft...
BTW, perhaps you'd be interested in this nutjob and his take on the
future of computers and programming:
http://rebelscience.blogspot.com/2008/09/cosa-new-kind-of-programming-part-i.html
I still find much simpler writing a textual while loop though... :P
Date: 18 Oct 2008 12:47:36
Message: <48fa1328$1@news.povray.org>
hout altering
> its meaning.
Again, it depends on the field of study.  "R" is a variable. Bold-face R
means the set of real numbers, in mathematical notation.
And capital delta and lower-case delta mean two different things in
math, too.
You've yet to actually provide a reason for your disagreement.
Date: 18 Oct 2008 18:25:00
Message: <web.48fa61b0b947749355bd91cf0@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> hout altering
> > its meaning.
Nice try, but in one given program it means one and only one thing.
> math, too.
We're not talking about math, we're talking about a program, possibly a domain
specific one with its own business rules and meanings.
I thought I was clear enough.  I consider "foobar", *foobar*, /foobar/, Foobar,
FooBar, FOOBAR to be all the same.  It's still a foobar like any other...
yes, I know C++ users will say FOOBAR is a constant, Foobar or FooBar a class
and foobar an instance of such class.  Baloney...
Date: 19 Oct 2008 12:23:42
Message: <48fb5f0e$1@news.povray.org>
 R
You assert this without justification.
>> math, too.
 domain
Yes? You don't understand hypotheticals?
 Foobar,
Maybe you mean that you simply disagree with the merit of the idea.
That's fine. But you phrase it as if there's actually a good reason why
the idea needn't be considered other than your personal preference.
You say "surely 整數 can be written in italics or bold with
out altering
its meaning."  I'm disagreeing that it is as sure as you say, but your
justification seems to be "saying the same thing louder". :-)
Date: 19 Oct 2008 14:00:01
Message: <web.48fb751cb94774933906a7480@news.povray.org>
>  Foobar,
Yes.  I can certainly see the value of having different identifiers binded to
the same word under different graphisms, from a practical standpoint, but still
do not agree with it.
It's not mine alone.  The Pascal and Lisp languages have long supported this
notion.
Besides, case-sensitiveness is already bad enough, but at least most editors
support it.  I'm guessing your proposal would not play nice with notepad
folks...
Date: 19 Oct 2008 14:27:07
Message: <48fb7bfb$1@news.povray.org>
nemesis wrote:
> I'm guessing your proposal would not play nice with notepad folks...
Less a proposal than a thought thrown out to look over, yes.  And you'd
definitely not be writing it in notepad, unless you used wordstar or
html conventions or something. (I.e., embedded markers, like <b>int</b>
or embedded control characters or something.)
APL, after all, used greek letters (mostly) for built-in functions
(along with things like a proper division sign), and ascii for
user-defined variables and functions, and with the appropriate
infrastructure (such as keyboards with the characters printed on them)
it really wasn't a problem as such. You couldn't read the program on a
terminal that didn't have the right character sets, of course, but
that's hardly a problem nowadays.
And of course 8-bit BASIC interpreters did something similar internally,
but decoded it into text for display.
But yeah, it doesn't seem like there's a particular technological
benefit to trying that.
Date: 19 Oct 2008 14:47:29
Message: <48fb80c1$1@news.povray.org>
I'd be much more interested in that if he'd actually written something
larger than a quicksort. Or even a quicksort that would actually work in
a generic sort of way, like with different types, or different size
arrays, or whatever.
Too much handwaving while loudly proclaiming he's solved every problem.
He thinks hardware is very reliable, but he's clearly never worked at
building hardware, where you ship off dozens of versions of chips, and
when you're done, you use software to patch the bugs in the hardware
design.  He also doesn't seem to realize that there are all kinds of
timing problems in hardware, and that indeed solving the timing problems
in "synchronous" hardware is a major part of the development effort.
He also thinks that hardware is more complex than software, but the
reason people write software instead of building hardware is that much
that software does is too complex to implement in hardware.
He also seems to think that the problems with making software work is
problems with getting from detailed correct specs to software that
implements those specs. Much more often, the specs on what a piece of
software is to do is far more vague than what hardware is to do. Nobody
starts building a chip before they decide what all the CPU instructions
are going to be for sure. I'd also suspect it's pretty rare that
hardware is designed in a way that's easy to upgrade - add-on floating
point units would seem to be the most obvious example of what I mean,
while every piece of software is meant to be "soft". Virtually nobody is
happy with software that never changes once released, and for those who
are (a la cell phones, microwave ovens, etc) it seems we manage a pretty
good level of reliability.
He also seems to think that hardware doesn't have the same problems as
software, yet http://www.opencores.org/ exists.
When he shows how you'd build an air traffic control system that's more
reliable than what we have, or even a SQL RDBM server, using his system,
I'll maybe start to worry about it. :-)
Date: 19 Oct 2008 15:40:01
Message: <web.48fb8cb6b94774933906a7480@news.povray.org>
I think you devoted too much time to the guy's ideas.  He's a well-known,
long-time internet crackpot and he knows it:
http://rebelscience.blogspot.com/2007/10/who-am-i-what-are-my-credentials.html
Beware, he may be an online sentient being.  One day I innocently invoked his
name in comp.lang.lisp and he appeared all of a sudden!
http://groups.google.com/group/comp.lang.lisp/browse_thread/thread/e0ee331cfe13f214/9f84e2cccc7c0269?lnk=gst&q=louis+sa
vain#9f84e2cccc7c0269
He may drop by here as well... :P
Date: 19 Oct 2008 15:48:09
Message: <48fb8ef9@news.povray.org>
It's hard to tell without looking. Anyway, he's just proposing "data
flow" types of languages. Of course, he doesn't know that, since he
never actually studied the field. :-)  They work great, until you need
an algorithm.
