POV-Ray : Newsgroups : povray.off-topic : Doomed? Server Time
2 Jul 2026 22:01:45 EDT (-0400)
  Doomed? (Message 11 to 20 of 57)
Subject: Re: Doomed?
Date: 21 Sep 2008 10:36:40
Message: <48d65bf8@news.povray.org>
Orchid XP v8 wrote:
> ....still not found a way to compile things yet...
It's the little icon on the toolbar that looks like a birthday cake, at
least on the 2005 version. (I don't know why it looks like a birthday cake.
Isn't there a "build" menu when you open the "solution"?
You know, "create new project", then pick the type (like console), then
type in the "hello world" program where it belongs, then "build" and
then "run"?
Date: 21 Sep 2008 10:41:36
Message: <48d65d20@news.povray.org>
Orchid XP v8 wrote:
> Hmm, you really have to do stuff in *exactly* the order it wants, don't
> you? Man this thing's inflexible!
Uh, like what?  But yeah, a lot of Microsoft stuff can be like that. I
don't really remember that to be the case in VS. Maybe getting something
set up in the first place the first time is more tedious than I remember.
> Clearly this thing is designed for programs *way* bigger than "Hello
> World". I can't help thinking that if Hello World is all you're trying
> to write, this is massive overkill.
Yep. The full-blown product has stuff like automated unit testing built
in, and even the cheap $99 version has stuff like automated source
control built in.
Date: 21 Sep 2008 10:48:13
Message: <48d65ead$1@news.povray.org>
Yeah, there was a build button, but disabled.
> then "run"?
Yeah, that's just it - I hadn't figured out that you must create a
"project" before you can compile anything. ;-) It lets you edit source
code just fine without one, but won't actually compile anything.
http://blog.orphi.me.uk/
Date: 21 Sep 2008 10:50:58
Message: <48d65f52$1@news.povray.org>
Darren New wrote:
>> don't you? Man this thing's inflexible!
> Uh, like what?
Like if you go File > New > File... and then select "CPP File", it
doesn't add it to the current project. (And opens the file browser in a
random spot.) You must instead right-click on the "Source Files" node of
the current project and select "Add item..." and select "CPP File", and
*then* it automatically puts the file in the correct place, adds it to
the project, and lets you compile and run it. Sheesh!
Yeah. I remember the self-same thing with Visual J++ Studio, 10 years
ago! ;-)
> control built in.
Ooo, I *so* must buy that!!!1!eleven!
Date: 21 Sep 2008 11:08:36
Message: <48d66374@news.povray.org>
Oh, yeah, OK. But you can also add files that aren't in the project. So
if you create a CPP file that's outside the "solution", you can then
choose to add it to the solution later.  Not really an "out of order"
problem so much as a "too many choices" problem. :-)
> ago! ;-)
I was thinking stuff like installing interrelated packages, drivers, etc.
Date: 21 Sep 2008 11:10:06
Message: <48d663ce$1@news.povray.org>
They may have made it more complicated in the 2008 version or something.
The 2005 version has a big button saying "create new project" and you
have to go into the menus and such to find the "create a file that I
don't know how to compile" part. ;-)
But yeah, it's a big and complex tool. It'll take a day or two to learn
how it works.
Subject: Re: Doomed? Yep!
Date: 21 Sep 2008 12:28:37
Message: <48d67635$1@news.povray.org>
Oh... cool.
According to "Thinking in C++", you can use the keywords "and", "or" and
"not" in place of symbols. GCC accepts this. However, Visual C++ doesn't
seem to like it.
I just took the program source code and handed it, unmodified, to GCC.
It compiled immediately. Yet Visual C++ complains about "not" being an
"undeclared identifier". Goodie.
Date: 21 Sep 2008 12:33:32
Message: <48d6775c$1@news.povray.org>
> how it works.
Tell me about it! I just discovered that adding a breakpoint doesn't
actually do anything - you have to add a breakpoint *and* turn it on. o_O
WTF? I ask you...!
Date: 21 Sep 2008 13:51:24
Message: <op.uhuejxic7bxctx@e6600>
On Sun, 21 Sep 2008 18:28:44 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
> you can use the keywords "and", "or" and "not" in place of symbols.
Don't. Not all compilers support this, and very few programmers are
accustomed to it.
> However, Visual C++ doesn't seem to like it.
This one in particular does not by default.
You can make it support it by checking the option "Disable language
extensions" which you probably should anyway.
FE
Date: 21 Sep 2008 14:01:53
Message: <48d68c11$1@news.povray.org>
> accustomed to it.
According to the tutorial, "if your compiler does not support this, it
is not a standards-compliant C++ compiler". (I'm only saying what the
tutorial says; I have no idea if that's correct or not.)
I keep trying to sort out in my head which combination of symbols mean
bitwise operations and which ones mean logical operations. Using names
makes the difference clear. (To me anyway.) Of course, none of this
helps with trying to read other people's code.
(Now Haskell also uses symbols for both. However, in Haskell, if you try
to perform logical operations on numbers, you get a type error, and vice
versa. Unfortunately C++ inherits C's braindead "hey, if you can
represent it as an unstructured bit pattern, it's an int, right?"
mentallity.)
Uh-huh. Yeah, I'll be doing that. I'd like to write code that will
compile everywhere. ;-)
Who'd have thought? An M$ product bending the standard slightly...
</sarcasm>
