![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
48d20b02$1@news.povray.org...
> What *I* want to know is... in films, it's common to just punch somebody
> in the head and them be instantly knocked out. Is it actually possible to
> do this IRL? Is it really that easy? Do you wake up with just a headache,
> or permanent brain damage? Surely you'd at least have bruising??
That is a very bad idea and my advice is not to try it at home (or anywhere
else :-)
A shock at the head is very hazardous because you can't really know how
strong you can hit.
It can cause bleeding in the brain even if the skull is not cracked. You can
recover fast and leave then die in the next hours.
Even without bleeding, a brain shock can cause lifelong after-effects.
After a loss of conciousness caused by a head shock, the place to go is to
hospital.
Films often give the impression that it is like taking a sleeping pill but
that's not so harmless.
with a minimum of seriousness.
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> else :-)
So noted.
> You can recover fast and leave then die in the next hours.
Oh, nice! So like the Death Cap then?
Mmm, nice...
See, for example, Pirates of the Caribean: Curse of the Black Pearl.
Will gets smashed over the head with some kind of metal implement and is
instantly knocked out. Next morning, he wakes up with a sore head, and
sets off to rescue the damsel in distress... hmm?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
48d2170b$1@news.povray.org...
> See, for example, Pirates of the Caribean: Curse of the Black Pearl. Will
I quote myself :) "recent films *with a minimum of seriousness*."
Pirates of the Caribbean are adventure comedies, you don't believe all that
hapens in them is like reality do you?
In fact I was not clear : what I meant is that it is not impossible to
recover without being wounded but the proportion of the times it hapens in
films is not representative of real life statistics. Does it make more
sense? :-)
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
m_a_r_c wrote:
> You don't believe all that hapens in them is like reality do you?
More worryingly, you only have to watch TV for a short time to end up
seriously believing that you can drive a car in a high-speed chase, flip
it over 6 times, AND WALK AWAY AFTERWARDS!
Seriously. You wouldn't *believe* how much even a low-speed impact
hurts... Most people seem to understand that films are exaggerated a
little, but few seem to grasp just how much exaggeration there is there.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
> In films, I have several times seen people be knocked unconscious, or
> lost consciousness for some other reason, only to be brought back round
> by another person making them sniff some chemical. Whatever chemical it
> is seems to work almost instantly to make them awake again.
> Question: Does such a substance exist in real life? What is it?
I dunno, but...
My roommate in the 1987-88 time frame had BO so powerful that it woke me
up one night. He usually showered, but that night he'd gone jogging.
John
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ever watched boxing?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I have the impression that you see this typical scene only in older
> movies, not in newer ones. (Well, seeing someone fainting in newer movies
> is quite rare in the first place...)
The most recent time I remember seeing it was in 24 (series 2 or 3 IIRC)
where Jack is being tortured, everytime he loses consciousness they wake him
again immediately using that chemical. Reading wikipedia, maybe it is just
smelling salts, it says that ammonium carbonate can be "crushed when needed
in order to revive someone that has fainted".
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> to do this IRL?
Yes. What you need to do is a kind of sideways blow to the jaw area, so
your head turns rapidly to the side. I'm told that if your brain spins
around inside your skull (not all the way around, obviously), it tends
to have the capability of knocking you out. Just getting hit frontwards,
or over the top, isn't the same sort of thing (altho I imagine it might
make you pass out from some other cause).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What you are seeing is a hangover from the days when women (and some men) wore
tightly corseted clothes. This restricted their breathing and the fainting was
generally caused by a lack of sufficient blood and oxygen in the brain. A faint
has a low score on the Glasgow Coma Scale meaning it is not a deep state of
unconsciousness. Since the sense of smell is one of the last things we loose
when we loose consciousness a strong smell will often elicit a response. (Before
smelling salts became common burning feathers were used.)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jim Holsenback wrote:
> I would agree but hey I'm no doctor .... but I've been on sidelines of NFL
> game and when someone has gotten their bell rung they break out the smelling
> salts (ammonia tabs). I've also seen weight lifters take a BIG wiff before a
> lift.
OTOH, who really thinks that world-class sports are actually healthy
thing? :P
> Jim
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
