POV-Ray : Newsgroups : povray.off-topic : Linux & drivers Server Time
16 May 2026 17:48:44 EDT (-0400)
  Linux & drivers (Message 4 to 13 of 43)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Linux & drivers
Date: 4 Sep 2008 11:34:38
Message: <48c0000e$1@news.povray.org>
>> I discovered that many if not most live CDs can be coaxed into seeing
>> the drives by manually executing a modprobe command. (No, I have no
>> idea which one... and it wouldn't help you anyway.)
> That's what I ran across - I just didn't have the energy to dig into
> which one.
> I guess I should learn it sometime as this PC is going to have this
> issue for a while and I plan on doing some fun Linux things with it.
IIRC, most live CDs failed to find either my harddrives or my NIC. To
fix it, you have to say something like
   modprobe nv_forcedeth
   modprobe nv_sata
and then they both work again. I figured this out by searching several
billion manpages, discovering where kernal modules (such as device
drivers) are stored, and then listing the contents of the folder and
looking for anything that sounded like it might work.
Hard to fix? No. User-friendly? No!
I still have no idea what "force deth" actually means...
http://blog.orphi.me.uk/
Date: 4 Sep 2008 12:04:40
Message: <48c00718$1@news.povray.org>
>> which one.
>   modprobe nv_sata
I find that I can get into Linux fairly easily and remember quite a bit,
but when i step back from the guts for a while I have to figure things
out again.  Granted it all seems familiar and doesn't take as long, but
it's hard to remember exactly what everything does when you mess with it
once in a while.
Date: 4 Sep 2008 13:10:18
Message: <op.ugyvbgqh7bxctx@e6600>
It makes more sense as "forced eth", even though the idea of a module that
forces death is somewhat amusing...
Apparently, the ambiguity is at least partially intentional.
FE
Date: 4 Sep 2008 13:43:50
Message: <48c01e56@news.povray.org>
> once in a while.
I know what you mean...
At one time I installed Gentoo Linux. (As in, that Linux that doesn't
come with an installer and has to be manually compiled from source and
installed piece by piece.) Now I have _no clue_ how I did it.
Date: 4 Sep 2008 13:56:22
Message: <48c02146$1@news.povray.org>
Tom Austin wrote:
> And all I wanted - fdisk
What does fdisk give you that diskpart doesn't?
Date: 4 Sep 2008 15:28:06
Message: <48c036c6$1@news.povray.org>
On Thu, 04 Sep 2008 16:12:22 +0100, Invisible wrote:
> My motherboard uses the nVidia nForce 4 chipset, and as a result many
> Linux live CDs can't see any of the SATA drives. However, they all find
> the PATA ones just fine.
Weird, my HP system here has that same chipset on it, and the live discs
do OK with it - SATA drive works beautifully with openSUSE 11.0 running
on it, too.
Jim
Date: 4 Sep 2008 15:40:01
Message: <48c03991@news.povray.org>
I usually do a Linux From Scratch for most things.
While I do the automated build, it at least keeps me in touch with the
roots of what is going on.
Date: 4 Sep 2008 15:42:17
Message: <48c03a19$1@news.povray.org>
I know how to use it and get to it easier than thru the XP recovery console.
I actually tried to get to it, but was prompted for an XP installation
to recover before I got to a prompt that I could use.
I figured that at that point I would rather learn how to get Linux
running on my machine because I plan on messing around with it later.
Tom
Date: 4 Sep 2008 16:47:12
Message: <48c04950$1@news.povray.org>
> console.
Diskpart runs for me from the XP command line. Oh, I see what you mean.
You had nothing at all on the machine. OK.
Yeah, I can see where that would slow you down. :-) BartPE is a good
cure if you do that sort of thing regularly.
Yeah. And live CDs are certainly easier to find for Linux than Windows.
I just thought there might have been functionality missing or something
that I didn't know about in fdisk.
Date: 4 Sep 2008 20:53:14
Message: <48c082fa@news.povray.org>
  Does Windows support creating so-called live CDs at all (maybe through
extensive hacking)? I know you can create recovery boot disks from Windows,
but if I'm not completely mistaken, those just basically create a DOS disk
with some text-based utilities. You *could* call that a "live CD", but
not really, IMO.
  Of course even if Windows had full support, there's always the pesky
limiation that it's commercial software which is illegal to distribute
without permission. There really are certain situations where free
software does have its advantages.
