POV-Ray : Newsgroups : povray.off-topic : Data recovery Server Time
7 Apr 2026 13:50:53 EDT (-0400)
  Data recovery (Message 41 to 50 of 128)
Subject: Re: Data recovery
Date: 27 Aug 2008 11:20:08
Message: <48b570a8$1@news.povray.org>
Invisible wrote:
> If stuff costs money then fine. But don't claim something is free when
> it isn't. That's deception.
That's "Search Engine Optimization".  :-)
Date: 27 Aug 2008 11:43:02
Message: <48b57606@news.povray.org>
>>> Yeah, I can see how that might corrupt the filesystem. But badly
>>> enough to render it unreadable? You would think you'd just get a few
>>> filesystem inconsistencies. The error message sounds more like the
>>> superblock is unreadable or something...
>> Depends on what the computer is doing when the stick is pulled out.
>> Think what could happen, if the computer were writing file allocation
>> tables...
> Or, say, the superblock. ;-)
Yeah, but AFAIK you only write to the superblock when you initially
format the volume?
I can understand a file or folder being broken, but the entire FS?
http://blog.orphi.me.uk/
Date: 27 Aug 2008 11:43:21
Message: <48b57619$1@news.povray.org>
That's what I said. Deception. :-P
Date: 27 Aug 2008 11:49:21
Message: <48b57781$1@news.povray.org>
> format the volume?
Hmmm... On FAT? I'm not sure. There might be a flag there that marks
whether the drive was dismounted cleanly or not. Or if you screw up the
root directory, I can see that mucking things up too. If there were just
a couple of directories, and the first sector of the root directory got
scrambled because she pulled it out while it was writing, I can see that
messing things up.
FAT usually has two FATs, too, for just such a reason. It's possible she
got a warning that the first was broken and just ignored it until the
second got messed up too.
I'm not real sure of the electrical characteristics of a USB stick such
that it gets the whole chip messed up by being pulled out while writing,
but I have to believe avoiding that was one of the design goals.
Date: 27 Aug 2008 11:50:55
Message: <48b577df$1@news.povray.org>
>>> when it isn't. That's deception.
I'm not disagreeing. :-)
I was told by someone at google that the two highest cost ads are for
"data recovery" and for "mesothelioma" (the cancer you get from asbestos).
Date: 27 Aug 2008 13:24:10
Message: <48b58dba$1@news.povray.org>
On Wed, 27 Aug 2008 08:57:11 +0100, Invisible wrote:
> Jim Henderson wrote:
>> I had asked questions about using a journaling filesystem and it was
>> told.  Yes, I could've read the specs but I didn't.  So shoot me.
> Wear-leveling, anyone?
Probably contributes to the increased life of the devices these days.
Jim
Date: 27 Aug 2008 14:58:30
Message: <48b5a3d6$1@news.povray.org>
Darren New wrote:
>> format the volume?
> messing things up.
Yeah. Well it's not complaining the filesystem is broken, it claims that
there *is* not filesystem at all. That's what I find so puzzling...
As I understand it, to write to flash RAM, you erase a small block and
then completely re-flash it. If that got interrupted, your whole block
is gone.
No idea how large a flash block is - I'll bet it isn't the same size as
a filesystem block! ;-)
You'd think a tiny little capacitor would keep the electronics running
for enough split seconds to shutdown vaguely cleanly... *shrugs*
Date: 27 Aug 2008 15:26:53
Message: <48b5aa7d$1@news.povray.org>
Right. The superblock (i.e., the boot block) holds a table that says
where the file system is, how many blocks are in it, which block the
root directory starts on, and so on. If that got wiped, then no, you
don't have any file system. :)
I imagine it depends.
Not when you're writing flash. That tends to take a lot of current.
Date: 27 Aug 2008 15:47:20
Message: <48b5af48$1@news.povray.org>
>> that there *is* not filesystem at all. That's what I find so puzzling...
I can see how that would be. What I don't see is why the hell you would
ever be writing data to anywhere near this location...
That again, I have no idea how FAT works.
Date: 27 Aug 2008 17:46:52
Message: <48b5cb4c$1@news.povray.org>
Flash isn't like a disk drive. It's electronic. If you zap the
electronics by (for example) pulling it out while it's writing, I don't
know what it would mess up.
And, as I said, there *is* a flag somewhere, I think, that says whether
the disk needs to be checked when remounted.  I *think* that's in the
root block.
