POV-Ray : Newsgroups : povray.off-topic : This is why Windows doesn't need a package manager Server Time
16 May 2026 18:43:24 EDT (-0400)
  This is why Windows doesn't need a package manager (Message 12 to 21 of 51)
Subject: Re: This is why Windows doesn't need a package manager
Date: 18 Aug 2008 13:36:23
Message: <48a9b317$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> Um, no. It's because you can bundle all that stuff in with the
>> application, but Linux doesn't.
>   Linux? I thought you were talking about Firefox. Firefox != Linux.
Most Linux packages don't bundle all their dependencies into the
package, primarily because most don't need to.  No, I wasn't talking
about firefox except as an example of how Windows programs tend to be
distributed with everything they need and Linux programs tending to rely
on the package manager.
>   There's nothing stopping anyone from including whatever the program
> needs in the installation package (or even linking everything statically
> in the binary), but where do you draw the line?
Dunno, really.  Good thing Linux has a package manager so you don't have
to do that, isn't it? :-)
>   In Windows you are forced to always include everything in the package.
> Then you end up with the problem of your system having hundreds of thousands
> of dll files which you just can't delete because you can't know if something
> is using it.
Actually, the system does indeed keep track of that stuff. Tht's part of
what's in the registry.  Of course, if your package isn't built right
and it doesn't tell the system that it is using the DLL, then you have a
problem when you uninstall the original provider of the package. Take a
look, for example, at C:\Program Files\Common Files.
And of course, if you have different versions of DLLs that are supposed
to be compatible but aren't, then it's a good thing you have lots of
copies about.
> With a package manager you can try to remove some library, but
> if something requires that library, the package manager not only tells you
> that this is so, but it even tells you *which* apps require that library,
> and it even offers you the option of uninstalling also those apps if you
> want.
Yep. Windows only tells you it's in use. Of course, it's pretty easy to
figure out which program is using it, by looking at the same parts of
the registry that tells you it's in use.
Date: 18 Aug 2008 13:38:28
Message: <48a9b394@news.povray.org>
Sabrina Kilian wrote:
> and it fails because it does exactly that?
No. It succeeds if it does exactly that. I didn't say "fail" anywhere.
If you're referring to the blog post calling it a "fail", well, I think
you've missed his point.
> could. Maybe he should really be complaining
> about how these 'long use, stable libraries' keep having updates. Why
> won't those developers just leave it alone!
Date: 18 Aug 2008 13:40:37
Message: <48a9b415@news.povray.org>
>> could. Maybe he should really be complaining about how these 'long
>> use, stable libraries' keep having updates. Why won't those developers
(I hate RDP not always catching the key-up. :-)
Yes, I suspect the "long use stable libraries" shouldn't be adding
important features. If you have features in 2.10 that you can't possibly
get away without using, then I wouldn't call 2.6 the "long use stable
libraries."  But that's just terminology.
Date: 18 Aug 2008 14:17:10
Message: <48a9bca6$1@news.povray.org>
Jim Henderson wrote:
> There are a great many Linux apps that use static linking to bundle the
> necessary libraries with the package.
Actually, you don't even need static linking. You just need to include
the right version in the package and install it properly (either in your
own directory or overwriting stuff (leading to DLL Hell) or whatever).
Of course, there are still occasional programs where they say "if you
get error 38173, go download some mumble DLL from Microsoft here..."
That would be the Windows equivalent of Package Fail. :-)
Date: 18 Aug 2008 14:53:41
Message: <48a9c535$1@news.povray.org>
True, you could do that, and override library paths with LD_LIBRARY_PATH
environment variables....But you've just helped me make my case. :-)
Yep...
Jim
Date: 18 Aug 2008 14:56:04
Message: <48a9c5c4$1@news.povray.org>
Darren New wrote:
> Yeah. The problem is, who is going to host such a thing?  We already
> have a software repository: it's called Google. :-)
Somehow I can't think Google as software repository, but I might be too
technical thinker (oslt) for that.
> That would certainly be convenient, but impractical for any commercial
> software. But for the free stuff? Sure, why would it be difficult?
> Nobody wants it enough to actually write the code to maintain the list
> of places to download setup.exe files from. :-)
Actually I'm starting to think it could be a good programming practice
:-). Software developers (possibly others, too, but it could create some
problems) could enter the version, URL of the package, name of the
executable and what versions of Windows it works for (ie. via the web).
The software could sync this list either when told or by a schedule and
when told, get the package and run the installer.
Yes, there's still problem of getting software to the reposity.
>> Not always (actually I can't remember a single .NET -software I've
>> installed that inholds the .NET system),
> Actually, it was pretty common in the earlier days. And DirectX always
> came with the software.
Yes, I remember DX coming with lot of games (I also remember that some
games insisted to have older DX installed and that created problems). I
don't remember .NET coming with any other software (OTOH I haven't
installed a lot of .NET -software, just some).
> I think now that pretty much everyone has gotten
> .NET via windows update, folks don't include it as much.
Yep. I don't have one installed at my home-XP (yes, my laptop has one
and I have booted it up once this summer, when I played C&C Generals at
Norway :p), but I also don't update that XP, so I'm a special case anyway.
> Certainly not
> in a downloaded product, but on CDs it still is there.  Why include a
> free download package with your download if it isn't needed?
Yep, certainly not needed, since (as I wrote) it's easily available from
MS's site.
> Of course, those who don't even provide a direct link to the .net from
> their installer are just lame. :-)
Actually I don't recall seeing one even once. I'm getting more and more
sure that we are mostly using different software on Windows ;).
> Actually, it's done on purpose, and specifically designed to work
> nevertheless. They call it "side by side execution".
Ok, now I know more.
> Fair enough. And sure, having a nice interface to a repository in that
> sense is a good thing.
Yep, it would be freaking great IMO ;).
> But you can't really do that in the commercial
> world,
True.
> and there's way way too much Windows software to do that for free
> in the "free" world.
Umm... I don't get this. There's loads and loads of free software using
such systems in Linux -world, so I don't straight away believe that the
amount of free Win-software would be a problem.
> It's not like it would be hard to support - all
> you'd need is the list of packages to download and launch.
Yep. Also version and supported platforms would be needed to avoid
problems and make upgrading software possible.
> Getting
> everyone to play along is the problem, and if folks don't play
> along,they don't show up in your repository *and* there's nothing you
> can do about it
Yep.
> unless it's GPL so you can recompile it yourself to make
> it play along.
Hmm.. Why would it need to be recompiled? Yes, the next-clicking
operation could be avoided, but having the setup up with just one
command would already be a half of a win.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 18 Aug 2008 16:03:49
Message: <48a9d5a4@news.povray.org>
> You know, I begin to see what Warp means when he says everyone takes the
> worst possible reading of something.
  I'll turn the suggestions I get in these cases back at you: Maybe choosing
your words and phrasing appropriately will minimize the possibility of
misunderstanding... :P
Date: 18 Aug 2008 16:48:59
Message: <48a9e03b$1@news.povray.org>
>> think you've missed his point.
It's not features that the GTK people can't get away without using, it's
features that Mozilla wants to use. This complaint is not that much
different, on the surface, then someone who wants to install a DX 9 game
on a Windows computer with DX8...you mean, I bought the game, but I have
to install something else too? I don't think, and I could be wrong here
cause I don't follow GTK, that GTK has ever released a 'long term
support' version of their library.
Yeah, there is a problem when it says 'requires 2.10 or higher' and
means 'requires 2.10.6 or higher'. That's bad, and probably will cause
lots of confusion. That's the actual problem, not the binary repository
maintainers having to check through the dependency lists.
I'm not surprised that Ubuntu 7.10 has some problems with it. 7.10 was
never a long term support version, and gets less work once the numbers
move on to the next full version, 8.10 or something by now.
All I read in the blog post was "I want to use a older distro that the
package manager maintenance  crew probably aren't supporting anymore,
but I also want every new package delivered to me by my package managers
without having to recompile new versions of old libraries." Yeah, some
OSes, even distros, can do better then that. Gentoo's portage got me
firefox3 with no problems on a machine that only gets updated once a year.
Date: 18 Aug 2008 17:00:08
Message: <48a9e2d8$1@news.povray.org>
It's not. It's a link repository. :-)  I think if you actually wanted to
*store* all the software ever written for Windows, you'd be looking at
an even larger expenditure.
It's ... pretty trivial to do that sort of code these days. Not really
much practice, unless you've never done that sort of thing before. :-)
If you can standardize the formats coming in, it wouldn't be hard. Just
put the "browse" button in.
Next up: let the owner of the software take it down. Hire lawyers to
defend you against people uploading illegal software. Etc.
Print Shop 2.0 did, for one. Lots of them just checked to see if it was
installed, and if not, silently installed it for you off the CD. Kind of
funky, but I can see their point.
It certainly sounds that way.   I don't tend to install a whole lot of
ametuer-ware. Some, but not a lot.  Mostly little utilities more than
packages complex enough to need something like .NET.
Go for it. ;-)
So, you think sourceforge.net doesn't have financial difficulties? :-)
And, honestly, I think there's *tons* more (admittedly crappy) software
for Windows than Linux. Pick some random utility - convert OGG to MP3,
for example, or printing barcodes (as two recent examples of mine). How
many versions do you think are distributed for something like this for
compared to for Linux? Google the expression, and see how many of the
top hits you go through before you find a version for Linux. (Or look
for that expression in your Linux repository, and see how many hits you
see, if you don't think google gives you good Linux results.)
There's lots of decent software in Linux. There's *tons* of crappy
software for Windows, and no good way of sorting out which is which.
Now, if you ran a "windows repository" that had only the well-written
utilities, I'd pay to access that. :-)
>> unless it's GPL so you can recompile it yourself to make it play along.
Well, repackaged. If all you get is "setup.exe" and everything's wrapped
up in that, you're going to have trouble distributing it yourself in a
package manager. Or if you get dozens of files as on a CD, you'll also
have a bit of trouble there. I guess you could do what RPMs do, and wrap
up everything with a script that runs afterwards to put stuff in the
right place and register it in the registry. Kind of a bummer if it's an
old setup.exe that reboots your machine at the end of the setup, before
your package manager can record its successful installation.
I'm sure if you took 500 Windows packages that you can download right
now, you'd find at least 100 you'd need to rework in some way to make
them register their presence in *your* package manager. :-)
Date: 18 Aug 2008 17:00:11
Message: <48a9e2db$1@news.povray.org>
I agree. I should have added more context.  I should have realized I was
posting it on a group with a larger audience than the previous group.  I
could have put in some disclaimers or something that I wasn't bashing
anything (altho I generally try not to bash anything as such anyway).
