POV-Ray : Newsgroups : povray.off-topic : Idle curiosity Server Time
23 Dec 2025 08:25:48 EST (-0500)
  Idle curiosity (Message 1 to 10 of 31)
Subject: Idle curiosity
Date: 15 Aug 2008 10:10:28
Message: <48a58e54$1@news.povray.org>
What *is* the difference between a BJT and a FET?
Are they different designs for doing the same thing, or do they actually
"do" something different?
How do you use them anyway?
http://blog.orphi.me.uk/
Subject: Re: Idle curiosity
Date: 15 Aug 2008 12:04:58
Message: <48a5a92a$1@news.povray.org>
I think I can describe the difference (a little) with an analogy.
Think of a BJT like two pools of water, with a low spot between, hoses
connected. To make the water flow, you pump enough water into the low
spot that the water from the hoses can flow across. Of course, this
washes away the water you pumped in, so you have to pump in more.
A FET is like a balloon wrapped around a hose. To make the water stop
running, you pump water into the balloon, which squeezes off the hose.
But since it's in the balloon, it really doesn't leak as such, so the
efficiency is much better.
Of course, these are *way* simplified descriptions. If you really care
how the semiconductors work at the quantum level, I can go into that,
but it didn't sound like the kind of question you were asking.
Look at the wiki pages for each. In the BJT, the current flows from the
blue, thru the green, and into the other blue. That's the "bipolar
junctions", the two boundaries.
In the FET, there's the "gate" and the "oxide" that keeps the gate from
actually conducting the electricity you put on it. But when you charge
up the gate, the "static electricity" pulls/pushes away the charges that
actually conduct between the two "N" pads there. So, FETs are used in
things like wrist watches, which are expected to run for a year on a
tiny little battery, because they work on voltage rather than current,
and batteries are better at supplying voltage than current.
The do "the same thing" in different ways. The BJT is less efficient but
it can handle much larger currents (i.e., the "hose" can be bigger
because you don't need to wrap a balloon around it).
They're basically amplifiers of electricity. If you want to make binary
circuits, you over-drive them so they're either completely off or
completely on.
Date: 16 Aug 2008 05:05:13
Message: <48a69849$1@news.povray.org>
>> actually "do" something different?
OK. So you'd wire them both up in essentially the same way?
Is there any major overall difference in operating characteristics? (I
seem to recall that whichever one you pick there's about 50,000,000
models to choose from anyway!)
> completely on.
So why is it that (say) a simple NAND gate involves 8 transistors, 3
diodes and 25 resistors? That doesn't make any sense to me... Logically
it looks like any possible 2-input gate should require 1 or 2 switches
and nothing else.
Date: 16 Aug 2008 14:06:00
Message: <48a71708@news.povray.org>
You're getting a bit past my expertise, but yes, physically there's
three connections with the same functions on each. Electrically, of
course, there's different voltages, switching times, etc.  It's like
asking if you drive a camper essentially the same way as you drive a VW bug.
Note that you also wire up vacuum tube triods in "essentially the same
way", so I'm not sure how helpful that answer is. ;-)
Well, yes. I thought I'd been clear on that. They take different
voltages and handle different currents and so on.
> and nothing else.
To make a switch, you have to either switch to + or to -, so that's at
least two switches right there. I.e., you need two transistors, one to
amplify the + voltage, and one to amplify the - voltage, using CMOS FET,
just to make a NOT gate.  Depending how you do it, it may take diodes
and resistors and such.
Date: 18 Aug 2008 03:57:27
Message: <48a92b67@news.povray.org>
Essentially, yes, but you need to bear in mind the differences between the
two when designing your circuit.  The main difference is that a FET is
controlled by input voltage, and the BJT by input current.  So in most
designs with BJTs you'll see some resistors dotted around to control the
current.
> seem to recall that whichever one you pick there's about 50,000,000 models
Good point about FET is that they have almost infinite input impedance,
which is often useful for low-power operation or when measuring very low
powered signals.  Good point about BJT is that the output resistance is
higher, so good for driving higher powered devices rather than pure digital
signals.
> diodes and 25 resistors? That doesn't make any sense to me... Logically it
> looks like any possible 2-input gate should require 1 or 2 switches and
> nothing else.
A NAND gate needs 4 FETS and no resistors:
http://en.wikipedia.org/wiki/Image:CMOS_NAND.svg
Inside an IC, resistors are HUGE compared to FETs, there is no way you could
make a modern CPU if you needed to include resistors for each gate.
Date: 18 Aug 2008 05:09:59
Message: <48a93c67$1@news.povray.org>
> the two when designing your circuit.  The main difference is that a FET
> is controlled by input voltage, and the BJT by input current.  So in
> most designs with BJTs you'll see some resistors dotted around to
> control the current.
See, in theory the way a transistor works is supposed to be simple.
However, every transistor circuit I've ever looked at seems so damned
complicated...
> digital signals.
...and this is why I like to stick to logic circuits. You don't have to
worry about obscure concepts like impedance or capacitance. (I mean,
unless you're designing "high performance" circuits anyway.)
>> Logically it looks like any possible 2-input gate should require 1 or
>> 2 switches and nothing else.
> could make a modern CPU if you needed to include resistors for each gate.
Even so, you can make a NAND gate out of just 2 electromechanical
relays. Why does it require twice that number when you use transistors?
(Additionally, I can't make any sense out of that diagram. The wiring
seems to have no reason or rhyme to it.)
Date: 18 Aug 2008 05:38:14
Message: <48a94306$1@news.povray.org>
> complicated...
You mean something like this - a simple amplifier circuit?
http://www.cjseymour.plus.com/layin/BJTAMP.jpg
The reason it looks complicated is because you are using a
current-amplifying device (the BJT) to amplify voltage.
The two resistors on the left are to bias the input voltage to somewhere in
the middle of the operating range of the transistor.  Otherwise you cannot
amplify negative input voltages (quite common in audio signals...).
The capacitor on the left allows the input voltage to be added to the bias
voltage.
Resistor R3 causes the amount of current flowing out of the emitter to be
(almost) proportional to the input (base) voltage.  Capacitor C2 helps to
boost the gain by allowing AC signals to see a lower resistance to ground,
but still keeping the DC operating point.
Resistor R4 generates the output voltage proportional to the amplified
current flowing through the collector/emitter.  Capacitor C3 removes any DC
component of the signal.
Note that the circuit inverts as well as amplifying...
Even with logic circuits, you cannot connect a single output to 5000 inputs,
there is always a limit due to internal resistances.  At some point your
circuit is going to fail, and for some technologies the number is much lower
than 5000.
> Even so, you can make a NAND gate out of just 2 electromechanical relays.
How?
Out is either connected to Vss (low) or Vdd (high) depending on the inputs A
and B.  If A or B or both are low, then Out gets connected to Vdd because
one (or both) of the top FETs will start conducting.  Only if both A and B
are high will there be a link between Out and Vss.
Date: 18 Aug 2008 06:34:53
Message: <48a9504d$1@news.povray.org>
>> complicated...
Yeah, pretty much.
The books say "a transistor is an amplifier" - and then should you a
*working* amplifier which actually consists of almost a dozen
components, of which the transistor is only one.
Uh... does it matter? I mean, the two are inherantly linked anyway...
>> to worry about obscure concepts like impedance or capacitance. (I
>> mean, unless you're designing "high performance" circuits anyway.)
> inputs, there is always a limit due to internal resistances.  At some
> point your circuit is going to fail, and for some technologies the
> number is much lower than 5000.
Yeah, but I'm never likely to build anything that even *contains* 5,000
components in total, am I? ;-)
> How?
Let's assume that a positive potential represents logic high, and a zero
potential represents logic low. Take a pair of relays connected up so
that by default the circuit is closed, and energising the magnet opens
the circuit. (This is easy to arrange with 3-pin switch type relays.)
Connect the relays in parallel between the positive rail and the signal
output terminal. Connect each input to one side of one magnet coil, and
connect the other sides to the negative rail. Done.
> inputs A and B.  If A or B or both are low, then Out gets connected to
> Vdd because one (or both) of the top FETs will start conducting.  Only
> if both A and B are high will there be a link between Out and Vss.
It probably doesn't help that I'm not understanding the symbols in the
diagram, but OK...
Date: 18 Aug 2008 07:06:14
Message: <48a957a6@news.povray.org>
Well yeh, that's why the resistors are needed.  Generally you want to
amplify voltages, not currents.
> potential represents logic low. Take a pair of relays connected up so that
> by default the circuit is closed, and energising the magnet opens the
> circuit. (This is easy to arrange with 3-pin switch type relays.) Connect
> the relays in parallel between the positive rail and the signal output
> terminal. Connect each input to one side of one magnet coil, and connect
I don't understand what is connected to the negative rail?
Don't forget that the output must be connected to either the negative or
positive rail (and not both!) under all input conditions.  It sounds to me
like in your circuit, the output will just be floating (ie not connected to
anything) when you charge both relays.
Date: 18 Aug 2008 07:22:47
Message: <48a95b87$1@news.povray.org>
...because you don't want to actually push too many electrons around and
warm up the wiring?
>> zero potential represents logic low. Take a pair of relays connected
>> up so that by default the circuit is closed, and energising the magnet
>> opens the circuit. (This is easy to arrange with 3-pin switch type
>> relays.) Connect the relays in parallel between the positive rail and
>> the signal output terminal. Connect each input to one side of one
>> magnet coil, and connect the other sides to the negative rail. Done.
> me like in your circuit, the output will just be floating (ie not
> connected to anything) when you charge both relays.
Ah, OK. If you want bipolar then yes, you'll need more relays. I'm used
to playing with TTL circuits where if you connect it to V+, that's 1,
and if you connect it to thin air, that's 0. (After all, a digital
circuit is just a circuit that has two possible states. It doesn't
matter especially what those states are, so long as everybody agrees...)
