Mike Raiford wrote:
> OEMs are just distributors of the software, though.
Yes? And?
You probably think you're CBS's customer, too.
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
Darren New wrote:
> Yes? And?
No. CBS's customers are the advertisers ...
MS doesn't write specifically for the hardware vendors. Unless you
consider corporations as being their biggest customers, but they're just
a conglomeration of end users.
"Mike Raiford" <mra### [at] hotmailcom> wrote in message
news:4880e65d$1@news.povray.org...
> Unless you
But end users without a say in what their company buys and they use. Can
they be called customers since they did not spend their own money on a
product?
Corperates are MS's largest clients. Single users who purchase their
software (like you or I) are small fry to them.
"Phil Cook" <phi### [at] nospamrocainfreeservecouk> wrote
> And lo on Fri, 18 Jul 2008 05:25:55 +0100, Darren New <dne### [at] sanrrcom>
> did spake, saying:
> > http://thedailywtf.com/Articles/That-Wouldve-Been-an-Option-Too.aspx
> "a developer had to step in and restart the site to release resources"
> Wouldn't that suggest that bunging some more memory in would only increase
> the time it took to fill up?
No. If there was a leak, they wouldn't have reduced the memory footprint by
50%.
> 50%.
Clearly the article *does* say they got rid of leaks and inefficiencies
both. :-) Some leaks just aren't big enough to worry about, tho.
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4880f9f3$1@news.povray.org...
by
> > 50%.
> both. :-)
That's not clear to me. Note that "unreleased resources" ...etc need not be
leaks.
It just doesn't make sense to me to be able to claim a 50% reduction in
memory in a leaky application, unless they halved the leaks as well instead
of eliminating them <g>
True, typically in interactive applications where user interaction
limitation sets an upper bound on leak rate.
> leaks.
Possibly not. Possibly they were released but not as early as they
should have been.
Yeah. In any case, it's obvious that it's not going to be resolved on
the basis of *that* article. :-)
And lo on Fri, 18 Jul 2008 17:26:33 +0100, Darren New <dne### [at] sanrrcom>
did spake, saying:
>> increase the time it took to fill up?
> "Had to restart the system to free up resources" could mean "we're
> thrashing because we have 5000 connections open to the server at once,
> because they're not closing, because we're thrashing." For example.
True, but that still may be simply postponing the problem; the article
mentions the increasing need for restarting.
> But sure, if there's a leak, you'll eventually fill up memory. If 2 gig
> changes it from being "restart the server once every day" to "restart
> the server more rarely than we upgrade the software anyway", it's a win.
Indeed from a business perspective if buying more memory is cheaper then
fixing the underlying problems then that's the 'best' solution. I just
wouldn't place this article in the pure WTF category.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
I actually know a system (actually, a 4-numbered set of those systems),
which is being reboot scheduledly every week because of a memory leak.
It's rare enough (and the actually needed schedule would be once in two
weeks oslt), so it's "ok".
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethiszbxtnetinvalid
> did spake, saying:
When I worked for GM a developer had to access a system to 'clean out
the database' about every month or so so that it wouldn't crash. They
had a nice maintenance contract going.....
Tom
