POV-Ray : Newsgroups : povray.off-topic : Yes, that time Server Time
26 Oct 2026 01:15:52 EDT (-0400)
  Yes, that time (Message 41 to 90 of 179)
<<< Previous 40 Messages Goto Latest 50 Messages Next 50 Messages >>>
Subject: Re: Yes, that time
Date: 17 Jun 2008 08:11:38
Message: <4857a9fa@news.povray.org>
scott <sco### [at] scottcom> wrote:
> > The only way I can think of doing this is to just rerender the entire
> > frame multiple times - which would obviously not work in realtime. So
> That's one way of doing it, and it works ok if your scene is simple enough,
> or if you only want to motion blur certain parts of it (eg a fast moving
> missile).
  Note that antialiasing also is based on rendering the frame multiple
times (although current cards might have some tricks to reduce the amount
of required rendering).
Date: 17 Jun 2008 08:18:31
Message: <4857ab97@news.povray.org>
Eero Ahonen <aer### [at] removethiszbxtnetinvalid> wrote:
> >   People often have prejudices against the touch screen in the iPhone,
> > but that's because they have never tried it.
> To be honest, that would be the first touchscreen ever that would be
> daily-usable in something as intensive as telephone I've ever touched.
> It doesn't mean it's impossible - it just means I'm very, *very*
> skeptical about a touchscreen.
  But the touchscreen in the iPhone is just amazing. It's not just a
touchscreen, it's a multitouchscreen. For example, you can zoom and rotate
images (or webpages or maps or...) by using two fingers, etc. Now do that
with your 12-key keyboard. ;)
  Also the scrolling is just cool. (After having using the scrolling feature
in the iPhone, any other non-touchscreen phone will feel almost completely
unusable...)
Date: 17 Jun 2008 08:18:51
Message: <4857abab$1@news.povray.org>
>> missile).
nVidia claims their full-frame AA works by just rendering the entire
thing to a larger framebuffer and downsampling with smoothing, but their
faster "smart AA" works by using filtered texturing, and does AA only at
polygon edges (using something like Bresenham's algorithm I would think,
rather than actual supersampling, since a polygon edge is a straight line).
http://blog.orphi.me.uk/
Date: 17 Jun 2008 08:21:23
Message: <4857ac43@news.povray.org>
> unusable...)
Ooo... so we have smudges and smeres as opposed to just finger prints?
Neat! :-D
Again, my sat nav allows you to scroll like this - but it's very
unpredictable. It doesn't "respond" very well to the touches you're
trying to make. I don't know why. Also, it's very hard to *slide* warm,
sticky fingers over a plastic surface in a smooth motion.
Still, at least it sounds like Apple actually thought about useful ways
to use a touchscreen rather than just throwing on in there to be contrary...
Date: 17 Jun 2008 08:30:43
Message: <4857ae73$1@news.povray.org>
> unpredictable. It doesn't "respond" very well to the touches you're trying
> to make. I don't know why. Also, it's very hard to *slide* warm, sticky
Your satnav is likely a resistive touch screen, it works when you physically
bend the top layer enough to make contact with the bottom layer
electrically, and then just like a variable resistor you can measure the
resistance to work out the position you touched.  The iPhone uses a
capacitive screen, as soon as you touch the surface of the screen the
electronics can detect the capacitance of your finger, also using clever
electronics/software it can work out the position of 2 fingers in contact,
to allow those wacky zoom and rotate operations.
The disadvantage of capacitive touch screens is that they only work with
your bare fingers, not while you are wearing gloves, or any sort of stylus.
The accuracy is also much lower than resistive touch screens, but that
doesn't really matter when you're using your fingers.
Date: 17 Jun 2008 08:35:57
Message: <4857afad$1@news.povray.org>
>> warm, sticky fingers over a plastic surface in a smooth motion.
> physically bend the top layer enough to make contact with the bottom
> layer electrically, and then just like a variable resistor you can
> measure the resistance to work out the position you touched.  The iPhone
> uses a capacitive screen, as soon as you touch the surface of the screen
> the electronics can detect the capacitance of your finger, also using
> clever electronics/software it can work out the position of 2 fingers in
> contact, to allow those wacky zoom and rotate operations.
> stylus. The accuracy is also much lower than resistive touch screens,
> but that doesn't really matter when you're using your fingers.
Damnit, I wish I knew some people IRL who possess such encyclopedic
knowledge... I'd never be bored again!
[FWIW, the sat nav *does* in fact have a stylus. Unlike my dad's cheap
device, the stylus is optional on mine. On my dad's, only the stylus
will operate it...]
PS. Is it only me who things pointing a sharp pointy thing at a delicate
and fragile layer of semi-liquid gloop fashioned into an intricate
display mechanism is a bad idea?
Date: 17 Jun 2008 08:50:31
Message: <4857b317$1@news.povray.org>
It's my job to know such information, ask me anything about history or
literature and I'd be totally stumped.
> and fragile layer of semi-liquid gloop fashioned into an intricate display
Don't worry, the semi-liquid gloop is behind 2 or 3 layers of glass, a
polariser and some air space, so unless you press *really* hard...  From the
specs I remember seeing, you could press with up to 50 N of force before
anything went wrong.
Date: 17 Jun 2008 09:05:11
Message: <4857b687$1@news.povray.org>
...and I care about history or literature because...? ;-)
Seriously, is it normal for LCDs to get warm during operation?
>> delicate and fragile layer of semi-liquid gloop fashioned into an
>> intricate display mechanism is a bad idea?
> the specs I remember seeing, you could press with up to 50 N of force
> before anything went wrong.
...is 50 N a lot?
Heee, do you remember the old laptops with the blue/purple monochrome
LCDs? Where if you touched the screen, the whole picture rippled slightly?
[Actually, our photocopier has a display like that. And I think it needs
a screen saver, cos some of the controls are well burnt into it! I
didn't think LCDs could "burn" like that?]
Date: 17 Jun 2008 09:51:10
Message: <4agf549ifl4p40qimiu2bdmsucdq8vlh1a@4ax.com>
It shows that you are not a complete ignoramus.
Regards
Date: 17 Jun 2008 09:53:42
Message: <4857c1e6@news.povray.org>
I love the way not knowing about differential calculus is perfectly
acceptable, but not knowing about English literature gets you labelled
as some kind of idiot. As if English literature is somehow "more
important" than differential calculus...
Date: 17 Jun 2008 10:07:51
Message: <4857c537@news.povray.org>
If they have a backlight, yes, because LEDs and CCFLs are only about 10%
efficient at converting electrical energy to visible light.  A typical
monitor might need around 5W of backlighting power, most of that is
converted to heat.
> ...is 50 N a lot?
About 5 kg.  Significantly higher than the force you usually use to
write/press with.
They still do, if you don't have any protection on the front.  My two
monitors and my laptop screen here certainly do.
> [Actually, our photocopier has a display like that. And I think it needs a
> screen saver, cos some of the controls are well burnt into it! I didn't
They can if you don't keep the average voltage across each pixel exactly
zero volts.  A bad/cheap driving circuit can easily allow enough of a DC
voltage to start to screw things up after years of operation.  However
usually the burn-in is not permanent, and disappears after some period (can
be up to an hour or so with very slow displays).  Must admit I don't know
the details because the displays we work on are not allowed to have any
visible burn-in at all.
Date: 17 Jun 2008 10:19:49
Message: <4857c805@news.povray.org>
> converted to heat.
Is that also why my LCD here at work is about 2°C warmer at the top than
the bottom?
>> ...is 50 N a lot?
> write/press with.
5 Kg? Yeah, that is quite a bit... [Hmm, I wonder how much a human arm
weighs?]
>> slightly?
*pokes it* Oh yeah, mine too. :-)
But it's not blue and purple. It's real colour. Even *our* equipment
isn't *that* ancient. ;-)
>> needs a screen saver, cos some of the controls are well burnt into it!
>> I didn't think LCDs could "burn" like that?]
> (can be up to an hour or so with very slow displays).  Must admit I
> don't know the details because the displays we work on are not allowed
> to have any visible burn-in at all.
Well, it *is* a 2-year old photocopier. And it runs 24/7. (Although
actually after a while it goes into a power-save mode where IIRC the LCD
shuts down too.) That's a touch-sensitive display, come to think of it.
But it doesn't ripple all that much... hmm.
I wonder... If you wanted to go all mad-scientist, how hard would it be
to concoct a chemical which forms a vaguely-functional LCD?
[NB. I once tried to make an oscilator at school. The damn thing never
actually produced any sound. It did, however, heat up the two power
transistors with remarkable efficiency - I would never have believed
that 9V was enough to burn your finger on...]
Date: 17 Jun 2008 10:48:25
Message: <4857ceb8@news.povray.org>
  In context, it is, in fact. That's because literature is much more
related to the culture around you (which, in the end, is closely related
to socializing between people), while differential calculus isn't.
  Humans are cultural and social beings and literature is one of the
best forms of learning and expressing about it. That's why it's usually
considered a good thing for your education to read a lot.
Date: 17 Jun 2008 10:54:56
Message: <4857d03f@news.povray.org>
> ...is 50 N a lot?
  Again we have to teach you about something you should know, especially
given that you are a technical nerd.
  To get a grasp of what 50 Newtons means, it may be easiest to convert
them to kiloponds.
  1 kilopond is the force exerted by Earth's gravity on one kilogram of
mass. In other words, assume you hold a 1 kg object on your hand, and
think how much force it applies to your hand downwards. That's 1 kp.
  50 Newtons is approximately equal to 5.1 kiloponds. In other words,
it's the force you feel applied to your hand when you hold a 5.1 kg object.
Date: 17 Jun 2008 10:59:37
Message: <4857d159$1@news.povray.org>
> the bottom?
Most likely just because heat rises :-)  Don't know where the LEDs are on
your LCD, or it may even be a CCFL in there...
That's because it has a touch screen on the front of it - not as easy to
distort the actual LCD.
> I wonder... If you wanted to go all mad-scientist, how hard would it be to
Read the first few parts of:
http://en.wikipedia.org/wiki/Liquid_crystal
It's relatively easy to get a "functional" liquid crystal nowadays, the
extremely hard bit is creating one that works over a wide temperature range,
gives a high contrast ratio, has a fast switching time, etc.
> transistors with remarkable efficiency - I would never have believed that
I tried to make a simple AM transmitter, my first design transmitted about
5cm.  I then proceeded to make the supply voltage higher and higher (in the
end I think I had 5 or 6 30V supplies in series) and eventually I made it
transmit about 3 metres while probably using half of the school's power :-)
Date: 17 Jun 2008 11:13:23
Message: <4857d493@news.povray.org>
>> ...is 50 N a lot?
I just figured that somebody who's used to dealing with such units on a
regular basis would have a more intuitive grasp of what is or isn't a
large force.
Of course 1 N is the force required to induce an acceleration of 1 m/s^2
on a mass of 1 Kg. But how much *is* that in real-world terms?
So... a reasonably large force to be pressing something with. ;-)
Date: 17 Jun 2008 11:18:00
Message: <g3lf54pgdrg8bfg0dp8veqoh7umljn23ue@4ax.com>
Warp said it all.
It's the way of the world.
[A well known Restoration comedy. Written by William Congreve, an
English playwright.]
:P
Regards
Date: 17 Jun 2008 11:18:28
Message: <4857d5c4$1@news.povray.org>
Hmm... Clearly it's going to take me a while to wrap my brain around
this concept...
Presumably this is why all schoolchildren [in the UK at least] have
Shakespear inflicted upon them as a mandatory component of their
education. I still can't figure out what good it's supposed to do.
Certainly I can understand the importance of social interaction. But
"culture" always seemed to me to involve lots of pretensious people
standing around whaffling something incomprehensible about a bend lump
of metal painted green or something...
Date: 17 Jun 2008 11:28:11
Message: <4857d80a@news.povray.org>
  It's good because it's an expression of social culture.
  You have a twisted notion of the term "culture". Culture is much more
mundane than that.
  For example, if someone greets you, you greet back. That's part of
your culture.
Date: 17 Jun 2008 11:31:28
Message: <4857d8d0@news.povray.org>
> >> ...is 50 N a lot?
> large force.
  I didn't have any idea whatsoever "how much" 50 N is, but basic education
helped me in figuring it out. I knew that Newtons and kiloponds both measure
the same thing (force), and that a kilopond is a much more intuitive unit,
so the logical step was to convert the Newtons to kiloponds, and from there
imagine a real-life situation where such force would apply (in this case,
holding a 5-kilogram object on your hand).
Date: 17 Jun 2008 11:53:27
Message: <4857ddf7@news.povray.org>
"scott" <sco### [at] scottcom> wrote in message
news:4857642d$1@news.povray.org...
> >> I've heard of TV casualties from the wrist band snapping. LCDs and
> >> Plasmas.
> >> The glass on a CRT is usually strong enough to survive,
> Yup, whereas the glass in an LCD is usually under 1mm thick - the
polarisers
> stop it shattering, but it still cracks easily and then it's useless.
Don't remind be. I cracked a laptop's LCD panel last year. The surface was
fine, something was cracked underneath. Large portions of the screen are now
black.
Repair place quoted me R8000 to replace the panel, and that was a 17" laptop
screen. I'd hate to see the price to replace a 40" LCD TV's panel.
Date: 17 Jun 2008 11:59:03
Message: <4857df47@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4857d493@news.povray.org...
Well gravitational acceleration is 9.8m.s^-2, so gravity exerts a force of
9.8N on 1 kg object.
Does that help?
Date: 17 Jun 2008 12:12:46
Message: <4857e27e$1@news.povray.org>
Invisible wrote:
>> There are lots around 10 pounds if you want to spend a bit more.
> ....so it's a tax on stupidity then?
It's an ongoing argument. HDMI is digital, so it shouldn't make a
difference. But it's a very poorly designed digital standard
(physical-layer-wise) so EEs who ought know what they're talking about
say it's important to keep the cables short if they're not really good
quality.  I suspect it's more like "it's important to keep the cables
short, period."
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 17 Jun 2008 12:14:49
Message: <4857e2f9$1@news.povray.org>
scott wrote:
>> You now have fingerprints all over your viewing area. Good luck
>> cleaning skin oil off a plastic display. ;-)
>> You get no tactile feedback from the "keyboard".
> Previously Nokia and still today many car manufacturers rejected the
> touchscreen keyboard approach for those very two reasons.
I read Nokia actually has a touchscreen that gives tactile feedback.
There's something behind it that "taps" from behind when the key would
click, or some such silliness. :-)
Date: 17 Jun 2008 12:16:34
Message: <4857e362$1@news.povray.org>
<RainbowsEnd>
   "You seem to know an awful lot about what's going on."
   "Hey, I'm wearing."
</RainbowsEnd>
Date: 17 Jun 2008 12:21:31
Message: <4857e48b$1@news.povray.org>
I was like that for a long time.  Then I realized it's basically
learning all the social macros, if you will.
One can make a reference to a piece of literature, or some other social
or literary context, and invoke an entire background to what you're
saying.  Boss says "Time to go visit the customer," and coworker say
"Yep, back down the rabbit hole."   If you never heard of Alice in
Wonderland, you'd have no idea what that meant, or why your coworker
would say it. If you'd read your literature, you'd know your coworker is
calling your customer and their entire environment crazily surreal.
If you want a nerdier example, when friends (who I know will get the
reference) ask me how the weather is where I am, I've been known to
answer "It's very Windows 98 out."
Date: 17 Jun 2008 12:25:15
Message: <4857e56b$1@news.povray.org>
Warp wrote:
> I knew that Newtons and kiloponds both measure the same thing (force),
FWIW, I never even *heard* of a "pond" as a unit of measure. I knew
"pounds" were a measure of weight (rather than mass), but I never heard
of a "pond".  Good explanation. :-)
Date: 17 Jun 2008 13:08:07
Message: <4857ef77$1@news.povray.org>
Consider another example. Imagine this:
You're in the conference room, along with several coworkers, waiting for
someone you haven't met before to show up so you can start. This person,
who has been around the company a while but you just never happened to
meet, walks past the window on the way into the conference room.  You
coworker whistles a tune under his breath,
... which you don't recognise.
... which you recognise as the Darth Vadar theme.
... which you recognise as the Wicked Witch of the West theme.
... which you recognise as the Indiana Jones theme.
OK?  Your different opinions, of this person who you still haven't met,
have been shaped by a string of otherwise-meaningless tones.  That's
culture.  (Assuming you've actually seen those movies, see...)
The reason you read Shakespeare is because others do too, and when they
make references to a Shylock, a pound of flesh, or "Lead on, McDuff", or
things like that, they're bringing *that* entire story into context.
Sort of like that Star Trek NG episode where the aliens communicate
*only* in cultural references, and they kidnap the two captains and beam
them down to the hostile planet surface so they'll have some cultural
story in common to start communicating with?
(Yes, thank you, I appreciate just how f'ing nerdy this sounds. :-)
Date: 17 Jun 2008 14:00:13
Message: <4857fbad$1@news.povray.org>
Wait... The WWW had a *theme*??
Maybe I'm just strange, but I don't think it would matter what a person
is whistling. The fact that they're whistling something would be more
significant...
See, now, in all the years I've been alive, I've never [knowingly] heard
of anybody making any Shakespeare references at all. [Except maybe to
Romeo and Juliet.]
...as nerdy as me saying "yeah, I remember that silly episode"?
Date: 17 Jun 2008 14:01:48
Message: <4857fc0c$1@news.povray.org>
Oh, is *that* what that's supposed to mean?
Obviously I've had the misfortune of reading Alice in Wonderland, but I
didn't understand a word of it. It just seemed to completely defy any
kind of logic... Just left me feeling really confused. [And wondering
why I just wasted several months of my life reading such an utterly
horrid book!]
Wuh?! o_O
Date: 17 Jun 2008 14:04:04
Message: <4857fc94@news.povray.org>
> Romeo and Juliet.]
Monty Python references seem far more common - although perhaps that
says something about the strange people I hang around with...
Date: 17 Jun 2008 14:45:20
Message: <48580640$1@news.povray.org>
Um, yes. Very much so. :-)
> significant...
It conveys their opinion.
> Romeo and Juliet.]
If you haven't read any Shakespeare, how would you know?
Date: 17 Jun 2008 14:47:16
Message: <485806b4@news.povray.org>
While true, such references are usually not used to communicate
something complex in a quick way, I'd guess.  As in, when people say
"It's only a flesh wound", they're really not saying "It's actually an
awful mortal wound, but I'm so dedicated to my cause I'm going to ignore
it." Instead, they really mean "it's only a flesh wound."
Date: 17 Jun 2008 14:48:19
Message: <485806f3$1@news.povray.org>
>> person is whistling. The fact that they're whistling something would
>> be more significant...
Surely it's more or less random and represents whatever happens to
wander into their heads? Besides, most people seem to whistle random
sequences of notes having no particular composition rather than actual
tunes...
>> heard of anybody making any Shakespeare references at all. [Except
>> maybe to Romeo and Juliet.]
Who says I haven't read any Shakespeare?
Date: 17 Jun 2008 14:55:58
Message: <485808be$1@news.povray.org>
You know, I'm not sure I can explain it any better than I already have.
If someone says "Here comes with Wicked Witch" when they see your boss
walking towards them, that conveys an opinion of your boss. Whistling
the theme song (which, in the movie, plays every time the Wicked Witch
approaches) also conveys the same thought. But you wouldn't understand
either meaning without culture behind it.
Sorry. You didn't.
In any case, that's what it's supposed to do. If some time in your life,
someone tells you not to hire some particular lawyer because he's a real
shylock, you'll know what it means.
Of course, there are fewer references to Shakespeare and various operas
and such than there are to popular movies, but the movie references will
probably not outlive the Shakespeare references either.  I mean, what do
you hear more, "Romeo and Juliet" or "Tony and Maria"?
Date: 17 Jun 2008 15:00:18
Message: <485809c0@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> [And wondering
> horrid book!]
  Exactly how fast do you read? One word per minute?-o
Date: 17 Jun 2008 15:03:25
Message: <48580a7d@news.povray.org>
  It never ceases to amaze my why you are so eager to shout about your
ignorance about things. You must know how it looks when you do that
constantly, yet you keep doing it again and again.
  (And I didn't say "I'm amazed you didn't know that". That's irrelevant.)
Date: 17 Jun 2008 15:07:08
Message: <48580b5c@news.povray.org>
  Seems like Andrew is not the only one who hasn't read his literature. :P
  (The first time I read about kiloponds, which was quite a long time
ago, was in a thriller novel, of all things. Maybe it was by Ludlum,
or someone who writes similar style. :) )
Date: 17 Jun 2008 15:29:58
Message: <485810b6@news.povray.org>
On Tue, 17 Jun 2008 10:40:56 +0100, Invisible wrote:
>> I typed "hdmi cable" into amazon and this one is only 51p!!!
Well, might also be a quality thing.  Then again, I bought a splitter
cable off of Amazon for my Blackberry & headset so I could charge both at
the same time (the headset didn't come with USB charging cable).  Cost
was about $0.95, and I got free shipping.  And it works.
New iPod battery was about $7 including shipping.  Previous one I bought
cost more like $15+tax.
"Tax on stupidity" = lottery.  Or on "people who can't do math". :-)
Jim
Date: 17 Jun 2008 15:42:59
Message: <485813c3$1@news.povray.org>
>> [And wondering
>> horrid book!]
A few pages, once every few days. Otherwise yuh, that would be pretty
damn slow! ;-)
Date: 17 Jun 2008 15:53:16
Message: <4858162c$1@news.povray.org>
Mmm, OK...
I doubt you can learn such things just from reading books though. More
like going out and actually talking to people...
> Sorry. You didn't.
I didn't read any Shakespeare? Now what on earth makes you think that?
Actually, considering Shylock's character, I'm not 100% sure I know what
they're trying to imply.
Hell, I haven't heard of that latter one *now*! ;-)
Date: 17 Jun 2008 15:57:52
Message: <48581740$1@news.povray.org>
It never ceases to amaze me how you like to remind me what a stupid
ignorant fool I am at every possible opportunity.
[Or that not knowing fact X qualifies somebody as "ignorant". As if
there's some magical set of facts that all human beings are innantely
expected to know...]
Date: 17 Jun 2008 16:19:56
Message: <48581c6c$1@news.povray.org>
Not really true.
Here's lottery number one:
You give me $1, and I give you a 1/100 chance you will win a $1,000,000
dollars. Do you take the bet?
Here's lottery number two:
You give me a $1,000,000 dollars, and I give you a 1/100 chance you will
win $1,000,000,000,000. Do you take the bet?
It's the same expected outcome, you'll note.
Date: 17 Jun 2008 16:21:29
Message: <48581cc9@news.povray.org>
> damn slow! ;-)
For the most part, it's probably pretty difficult to understand a book
like Alice in Wonderland if you read it that slowly. It's like trying to
be frightened by a horror movie you only watch for five minutes a day.
And, of course, it helps if you *already* understand some culture so you
can understand what the symbolism in Alice is actually referring to also.
Date: 17 Jun 2008 16:22:54
Message: <48581d1e$1@news.povray.org>
There's some of that invovled too, yes. ;-)
>> Sorry. You didn't.
Sorry.  You didn't say you hadn't read any Shakespeare. Erf.
That's kind of my point. Look up West Side Story.
Date: 17 Jun 2008 16:23:52
Message: <48581d58$1@news.povray.org>
>> damn slow! ;-)
I have also watched various films of it. Which also completely failed to
make any senblance of sense.
[Although I think possibly Dune exceeds it in outright
incomprehensibility...]
Date: 17 Jun 2008 16:24:10
Message: <48581d6a$1@news.povray.org>
I never claimed to be widely read. :-) Sadly, by the time I figured out
why the heck the teachers wanted me reading all that crap, it was too
late - I'd already graduated.
Date: 17 Jun 2008 16:30:21
Message: <48581edd$1@news.povray.org>
It strikes me that the thing about "culture" is that it is entirely
dependent on who you hang out with.
(Somebody around the POV-Ray server not knowing what the word "algebra"
means would get some fairly strange looks. Walk around on the street and
it's a different story. Now go read Questionable Content and try to
figure out some of the more obscure references. I just checked with an
emo kid I know who's dating an indie boy and *she* said it was obscure!)
>>> Sorry. You didn't.
Not only have I *read* several Shakespeare plays, as part of our
education we were forced to *perform* part of one. [Not Romeo & Juliet,
mercifully. It was a school for boys, after all...]
I played Shylock.
Best thing about performing Shakespeare: If you make a mistake, nobody
in the audience will ever know. They can't understand a word you're
saying, AND THEY DON'T CARE ANYWAY. Really reduces the pressure! ;-)
And next year, I happened to be visiting the school, and they told me
that Macbeth had just been expelled from the school. Guess who played
Macbeth's character that year?
And the year after that?
Jesus I'm a sap... :-S
And I'm agreeing. ;-)
Date: 17 Jun 2008 16:38:54
Message: <485820de$1@news.povray.org>
Well, no, they aren't going to make sense at all.
Me, I thought the Cyberiad (Stanislaw Lem) was truly wonderful for a
bizarre book, as well as being fairly deep in many ways. (Not too many
references to it in culture, mind.)   What amazes me more is that it was
originally in Polish and translated to English.  (Altho you'd have to
read it to understand why that's amazing - amazing writing, and an
amazing translation.)
Date: 17 Jun 2008 16:41:23
Message: <48582173$1@news.povray.org>
> Not really true.
I meant for lotteries like the Minnesota State Lottery, or Powerball.
Or any game, really, that's rigged so the house wins most of the time.
Jim
