POV-Ray : Newsgroups : povray.off-topic : Yes, that time Server Time
30 Jan 2026 04:27:02 EST (-0500)
  Yes, that time (Message 40 to 49 of 179)
Subject: Re: Yes, that time
Date: 17 Jun 2008 07:23:01
Message: <48579e95$1@news.povray.org>
Orchid XP v8 wrote:
> You now have fingerprints all over your viewing area. Good luck cleaning
> skin oil off a plastic display. ;-)
I think it's glass actually. It's designed to be easily wiped down, at
any rate.
Date: 17 Jun 2008 08:11:38
Message: <4857a9fa@news.povray.org>
scott <sco### [at] scottcom> wrote:
> > The only way I can think of doing this is to just rerender the entire
> > frame multiple times - which would obviously not work in realtime. So
> That's one way of doing it, and it works ok if your scene is simple enough,
> or if you only want to motion blur certain parts of it (eg a fast moving
> missile).
  Note that antialiasing also is based on rendering the frame multiple
times (although current cards might have some tricks to reduce the amount
of required rendering).
Date: 17 Jun 2008 08:18:31
Message: <4857ab97@news.povray.org>
Eero Ahonen <aer### [at] removethiszbxtnetinvalid> wrote:
> >   People often have prejudices against the touch screen in the iPhone,
> > but that's because they have never tried it.
> To be honest, that would be the first touchscreen ever that would be
> daily-usable in something as intensive as telephone I've ever touched.
> It doesn't mean it's impossible - it just means I'm very, *very*
> skeptical about a touchscreen.
  But the touchscreen in the iPhone is just amazing. It's not just a
touchscreen, it's a multitouchscreen. For example, you can zoom and rotate
images (or webpages or maps or...) by using two fingers, etc. Now do that
with your 12-key keyboard. ;)
  Also the scrolling is just cool. (After having using the scrolling feature
in the iPhone, any other non-touchscreen phone will feel almost completely
unusable...)
Date: 17 Jun 2008 08:18:51
Message: <4857abab$1@news.povray.org>
>> missile).
nVidia claims their full-frame AA works by just rendering the entire
thing to a larger framebuffer and downsampling with smoothing, but their
faster "smart AA" works by using filtered texturing, and does AA only at
polygon edges (using something like Bresenham's algorithm I would think,
rather than actual supersampling, since a polygon edge is a straight line).
http://blog.orphi.me.uk/
Date: 17 Jun 2008 08:21:23
Message: <4857ac43@news.povray.org>
> unusable...)
Ooo... so we have smudges and smeres as opposed to just finger prints?
Neat! :-D
Again, my sat nav allows you to scroll like this - but it's very
unpredictable. It doesn't "respond" very well to the touches you're
trying to make. I don't know why. Also, it's very hard to *slide* warm,
sticky fingers over a plastic surface in a smooth motion.
Still, at least it sounds like Apple actually thought about useful ways
to use a touchscreen rather than just throwing on in there to be contrary...
Date: 17 Jun 2008 08:30:43
Message: <4857ae73$1@news.povray.org>
> unpredictable. It doesn't "respond" very well to the touches you're trying
> to make. I don't know why. Also, it's very hard to *slide* warm, sticky
Your satnav is likely a resistive touch screen, it works when you physically
bend the top layer enough to make contact with the bottom layer
electrically, and then just like a variable resistor you can measure the
resistance to work out the position you touched.  The iPhone uses a
capacitive screen, as soon as you touch the surface of the screen the
electronics can detect the capacitance of your finger, also using clever
electronics/software it can work out the position of 2 fingers in contact,
to allow those wacky zoom and rotate operations.
The disadvantage of capacitive touch screens is that they only work with
your bare fingers, not while you are wearing gloves, or any sort of stylus.
The accuracy is also much lower than resistive touch screens, but that
doesn't really matter when you're using your fingers.
Date: 17 Jun 2008 08:35:57
Message: <4857afad$1@news.povray.org>
>> warm, sticky fingers over a plastic surface in a smooth motion.
> physically bend the top layer enough to make contact with the bottom
> layer electrically, and then just like a variable resistor you can
> measure the resistance to work out the position you touched.  The iPhone
> uses a capacitive screen, as soon as you touch the surface of the screen
> the electronics can detect the capacitance of your finger, also using
> clever electronics/software it can work out the position of 2 fingers in
> contact, to allow those wacky zoom and rotate operations.
> stylus. The accuracy is also much lower than resistive touch screens,
> but that doesn't really matter when you're using your fingers.
Damnit, I wish I knew some people IRL who possess such encyclopedic
knowledge... I'd never be bored again!
[FWIW, the sat nav *does* in fact have a stylus. Unlike my dad's cheap
device, the stylus is optional on mine. On my dad's, only the stylus
will operate it...]
PS. Is it only me who things pointing a sharp pointy thing at a delicate
and fragile layer of semi-liquid gloop fashioned into an intricate
display mechanism is a bad idea?
Date: 17 Jun 2008 08:50:31
Message: <4857b317$1@news.povray.org>
It's my job to know such information, ask me anything about history or
literature and I'd be totally stumped.
> and fragile layer of semi-liquid gloop fashioned into an intricate display
Don't worry, the semi-liquid gloop is behind 2 or 3 layers of glass, a
polariser and some air space, so unless you press *really* hard...  From the
specs I remember seeing, you could press with up to 50 N of force before
anything went wrong.
Date: 17 Jun 2008 09:05:11
Message: <4857b687$1@news.povray.org>
...and I care about history or literature because...? ;-)
Seriously, is it normal for LCDs to get warm during operation?
>> delicate and fragile layer of semi-liquid gloop fashioned into an
>> intricate display mechanism is a bad idea?
> the specs I remember seeing, you could press with up to 50 N of force
> before anything went wrong.
...is 50 N a lot?
Heee, do you remember the old laptops with the blue/purple monochrome
LCDs? Where if you touched the screen, the whole picture rippled slightly?
[Actually, our photocopier has a display like that. And I think it needs
a screen saver, cos some of the controls are well burnt into it! I
didn't think LCDs could "burn" like that?]
Date: 17 Jun 2008 09:51:10
Message: <4agf549ifl4p40qimiu2bdmsucdq8vlh1a@4ax.com>
It shows that you are not a complete ignoramus.
Regards
