POV-Ray : Newsgroups : povray.off-topic : Valid solution or evil hack? Server Time
6 May 2026 01:28:00 EDT (-0400)
  Valid solution or evil hack? (Message 11 to 20 of 46)
Subject: Re: Valid solution or evil hack?
Date: 15 May 2008 05:20:27
Message: <482c005b$1@news.povray.org>
> Well, this is for mission-critical stuff, so we have a service contract
> and all that kind of thing, so we basically get the hardware and software
> they provide. But yeah, if support wasn't an issue, that's probably what
> I'd do...
Yeh, guess you don't want to be held responsible when it breaks for
something mission critical, better to be able to pass the responsibility on
(even if they haven't updated their software since Win3.1!).
Still, you could encourage them to make some updates (like using USB instead
of serial, and writing software for XP/Vista rather than Win3.1), or buy the
system from a more up to date supplier that is less hacky.
Date: 15 May 2008 06:24:00
Message: <482c0f40@news.povray.org>
> on (even if they haven't updated their software since Win3.1!).
> instead of serial, and writing software for XP/Vista rather than
> Win3.1), or buy the system from a more up to date supplier that is less
> hacky.
Well now, if you want a couple of thermometers and a data logger,
it's mission critical. What are you gonna do? You simply *have* to have
this thing, so basically you have to pay whatever they charge you. Which
is probably _why_ they charge you so much. ;-)
I wasn't in any way involved in the purchase process, but I gather that
we were quoted tens of thousands of pounds by various parties, and we
eventually went with the lowest bidder. As far as I know...
http://blog.orphi.me.uk/
Date: 15 May 2008 07:24:07
Message: <482c1d57$1@news.povray.org>
> Now if you write the words "mission critical" on it, suddenly the same
Not really, I assume the hardware is of a much higher specification than
some *really* cheap consumer version you could get for 20 quid.
> But hey, it's mission critical. What are you gonna do? You simply *have*
> to have this thing, so basically you have to pay whatever they charge you.
> Which is probably _why_ they charge you so much. ;-)
Usually you have the option of other suppliers, so the price should be
pretty competitive for what you're getting. Otherwise they would go out of
business if everyone else could sell the same product for half the price.
> I wasn't in any way involved in the purchase process, but I gather that we
If you were about to spend 10k on something, would you blindly take the
cheapest one without even bothering to see exactly what you were getting?
Sadly a lot of companies do exactly this, often with much larger sums of
money...
Date: 15 May 2008 07:54:19
Message: <482c246b$1@news.povray.org>
every 15 minutes. If they go outside a preset range, an alarm goes off.
How much would *you* suggest such a system costs?
>> *have* to have this thing, so basically you have to pay whatever they
>> charge you. Which is probably _why_ they charge you so much. ;-)
> of business if everyone else could sell the same product for half the
> price.
Apparently all the suppliers we could find were charging 5 figures for
something that will do what we want. Seems absurd to me, but... mission
critical, gotta have one, gotta be up and running before date X...
> getting? Sadly a lot of companies do exactly this, often with much
> larger sums of money...
Well, you'd hope so... but as I say, I wasn't really involved in the
process. I believe the hardware was all much the same, so they went with
the cheapest option from a supplier who could actually supply on time.
Date: 15 May 2008 08:09:41
Message: <482c2805$1@news.povray.org>
Depends on far more than just the raw technical performance.
If I'm going to use it check the temperature in my greenhouse, I would
imagine a 50 quid jobby from Maplins would do with some cheap hacked
together Win3.1 program.  However, if I'm putting it in a manned spacecraft
that is orbiting the moon, I would expect way higher performance, and an
equally higher price.
BTW, the stuff we make here, we always have to put on the 1st page of the
specification that it is not to be used in anything critical, like plane
instruments, hospital equipment, traffic signals etc, simply because we
don't design or test to high enough standards.  If we did, the cost would be
astronomical, for stuff like PC monitors you don't need that level of
reliability so you get them very cheap.
Date: 15 May 2008 08:22:04
Message: <5nao24tmm04tc57ku72qgs4lqvrnr95srv@4ax.com>
Is the equipment and software certified? Because that adds to the
cost.
Regards
Date: 15 May 2008 08:33:50
Message: <482c2dae$1@news.povray.org>
Invisible wrote:
> So, you have some equipment for monitoring temparature sensors and
> logging their readings. And you supply some software that downloads this
> data and lets you organise and examine it on a desktop PC.
> You also supply your customers with a blob of software which, when
> installed on a PC, somehow tricks the PC into thinking it has a new
> serial port. All data sent to this port is *actually* tunnelled to the
> little black box.
> So, between the little black box at one end, and the custom software
> driver at the other end, the hardware and software geniunely believe
> they're still locally connected, yet actually they can be on different
> continents.
> Is this a valid solution to a design problem? Or is it a cheap hack?
> [Did I mention that the "software" in question appears to be designed to
> work with Windows 3.0? Does that change the answer?]
If it is an existing system that needs to be made network 'aware' then
it is a valid solution, but one that should be taken with caution.
Recently I built something that does exactly that.
I have some GPS modules that speak serial.
I built a custom serial/ethernet module.  But this one is smart - it has
a buffer and built in web page for basic GPS info.
On the computer I run a ethernet/comm port emulator so that programs
that expect only a comm port can work.
But one better, the serial/ethernet module allows for multiple
connections - I can get multiple computers and applications pulling the
same data on comm ports.
IMHO, a serial-ethernet module should be used as a last resort when
there is no viable alternative.
If it is a mission critical application, then you are just introducing
more points for failure.  When one of those points die, then it takes
all that much longer to debug.
This reminds me of what would be put in at the GM-Saturn plant I worked
in several years ago.  You kludge a bunch of stuff together until it
works, then repeat and put 50 of them on the plant floor.  Even tho if
one of them failed it would stop the production line.  I ran into some
strange setups - parallel to serial to ethernet to serial to com
port....  and in one case it took 3 days to figure out what piece failed.
Best of luck!
LAter... Tom
Date: 15 May 2008 08:51:38
Message: <482c31da$1@news.povray.org>
>> off. How much would *you* suggest such a system costs?
> spacecraft that is orbiting the moon, I would expect way higher
> performance, and an equally higher price.
Well, we'd like to check that the blood samples we're storing actually
about this fact, urgently.
I'm guessing a temparature sensor that actually *works* at temparatures
that low is going to cost a tad more than your average room thermometer,
but beyond that I don't see why it would need to cost more. It seems the
only reason for the higher price is that this is a critical device, so
the suppliers know they can charge the Earth and we will pay it. We have to.
> the specification that it is not to be used in anything critical, like
> plane instruments, hospital equipment, traffic signals etc, simply
> because we don't design or test to high enough standards.  If we did,
> the cost would be astronomical, for stuff like PC monitors you don't
> need that level of reliability so you get them very cheap.
The mass spectrometers we have here all say "for research and
development only; not for diagnostic procedures" on them. I can't
imagine why - it's a mass spectrometer! Either it measures masses
reliably, or it doesn't. If it does, you can use it for anything you
like. If it doesn't, it's a worthless piece of equipment. So... why the
sticker?!
Date: 15 May 2008 08:52:42
Message: <482c321a@news.povray.org>
> cost.
Not by the supplier, I don't *think*. Certainly *we* will be regularly
checking it against an ISO standards-certified reference instrument
[which really *is* insanely expensive]. But I don't *think* the
suppliers actually provide any such guarantees - I'm not sure...
Date: 15 May 2008 09:18:19
Message: <482c381b$1@news.povray.org>
informed?  Would you trust a 20 quid meter from Maplin then?
Not really, thermocouples are cheap (like a fiver) and measure down to
below -100 degrees.
> only reason for the higher price is that this is a critical device, so the
Or the fact that there is a much lower chance it will break or mal-function.
A simple example I can think of is that the connector where the thermal
probe plugs in mal-functions somehow so that the electronics thinks that the
temperature is -90 when really it is only -70.  Or some solder joint on the
circuit board wasn't made completely correctly and messes up some other
reading in an undetectable way once the temperature and humidity get to a
certain value.  There are all sorts of failure mechanisms that needs to be
checked and fixed somehow, and that costs lots of money.
> The mass spectrometers we have here all say "for research and development
> only; not for diagnostic procedures" on them. I can't imagine why - it's a
> mass spectrometer! Either it measures masses reliably, or it doesn't. If
> it does, you can use it for anything you like. If it doesn't, it's a
> worthless piece of equipment. So... why the sticker?!
Because they don't guarantee it will work reliably the whole time.  For them
to guarantee that, they would need to do lots of expensive testing on every
unit, probably design in lots of redundant systems, use more expensive
components that have longer lifetimes, use better assembly methods etc.
