POV-Ray : Newsgroups : povray.off-topic : Web design IE mysterium Server Time
5 Jul 2026 03:30:50 EDT (-0400)
  Web design IE mysterium (Message 11 to 20 of 52)
Subject: Re: Web design IE mysterium
Date: 20 Jan 2008 14:01:45
Message: <47939a99@news.povray.org>
stbenge nous apporta ses lumieres en ce 2008/01/20 01:48:
> Rune wrote:
>> This page works fine in Firefox 2.0:
>> http://runevision.com/temp/new_design_test.htm
> I use FF 2.0.0.3 and I see no problems.
>> However, when I view it with IE 6 some of the boxes are completely
>> white, or flickers white, and they also have a white, unshaded left
>> border. I have really no idea what causes this, and haven't been able
>> to find help on the net (I don't know what to search for).
>> Do you see the same artefacts in IE? Are you using IE6 or IE7?
> I tested your site with IE7, and I see a couple of rendering errors. The
> first occurs at every 'box'. It manifests as a continuance of the
> left/right box graphics extending below the bottom graphic (shown in
> attached image). I also get the unshaded left border at each box. All
> these boxes are affected by the unshaded left border: 'Fractal Structure
> And Some Red', 'Burn in Hell', 'No More Chrome Spheres Please', 'Merry
> Christmas on The South Pole', 'Tunnel', 'Impossible Triangle', 'Red
> Dragon', 'Tubes', 'Torus Fractal', 'Green Dragon' and 'Pens'.
> I hope this helps.
>> Any idea how to fix it?
> Yeah, convince the world not to use IE :)
> Sam
> P.S. I'm still finding (good) uses for your Illusion include file!
Page open side by side in both Firefox 2.0.0.11 and IE7. They both look
identical, apart from a 1 point font size difference. No graphycal glitch or
anomaly here.
You know you've been raytracing too long when whenever you write include, even
in essays, etc, you always add a "#".
Date: 20 Jan 2008 16:21:03
Message: <4793bb3f@news.povray.org>
Rune wrote:
> "Tim Attwood" wrote:
>> I think "clear both" is buggy in IE7
>> http://www.456bereastreet.com/archive/200603/new_clearing_method_needed_for_ie7/
> I didn't see any solution I could understand in that article, but the
> problem was indeed "clear:both".
> Now I've reverted to using some good old tables, and everything works fine
> in IE 6 and Firefox 2.
> The menu items to the right are far more spaced in IE than in Firefox
> though. Don't know why.
I tested your site again with both FF 2.0.0.3 and IE 7, and I see no
such difference.
> Also, could someone with IE 7 let me know if the problem with the bottom of
> the boxes is still there?
I found neither hide nor hair of the pesky white boxes. It would appear
that you have managed to eradicate that particular problem. In fact, the
page actually looks *better* in IE due to the automatic antialising of
page fonts.
Sam
Date: 20 Jan 2008 16:27:13
Message: <4793bcb1@news.povray.org>
Ian Burgmyer wrote:
> Rune wrote:
>>>  Transparent PNGs + IE = sucks.
>> I thought it was fixed in IE7? For IE6 I am feeding the browser
>> transparent gifs instead.
> Yes, translucent PNGs actually work in IE7 (and, based on my limited use
> of it, they seem to work quite well).
> As you've seen, however, CSS is still horribly broken.  I can't even
> tolerate doing any sort of web design work anymore thanks to IE. :(
None of this is going to discourage me from liberally using translucent
PNGs and and CSS when I decide to update my site. What kind of people do
I want to have viewing my site? Probably not IE users ;)
Sam
Date: 20 Jan 2008 16:35:27
Message: <4793be9f$1@news.povray.org>
Rune wrote:
> That's nice to hear, and yeah, it's basically just a projection, so I guess
> it is versatile. If you have any images online that uses it, I could link to
> them in my "Outside Gallery" if you'd like.
I might just hold you to that offer.
BTW, it would seem your include file is partially incompatible with
POVb24.... It happens when I wrap the 'illusion' pigment inside a
pigment_pattern for a texture_map, and then render the scene with
antialiasing, focal blur, or any other feature that makes the scene
render slowly. POV just quits abruptly, without even an error to tell me
what went wrong. I need to look for a log file. Hopefully POV produces
one. It's really quite frustrating :(
Perhaps it's somehow related to the same error which causes the first
object in my HFarch example file to not render. I'm thinking POV doesn't
handle user-defined functions the same way it used to.
Sam
Date: 20 Jan 2008 18:22:08
Message: <4793d7a0$1@news.povray.org>
Because it's physically impossible to make a webpage without using CSS
or CSS features that IE doesn't render properly.  Gotcha.
Tim Cook
http://empyrean.digitalartsuk.com
Version: 3.12
Date: 20 Jan 2008 18:45:55
Message: <4793dd33$1@news.povray.org>
> PNGs and and CSS when I decide to update my site. What kind of people do I
I found a way to make transparent PNGs work even in IE 6, so my site will
feature nice drop shadows even when using that browser! :)
Rune
Date: 21 Jan 2008 01:37:09
Message: <47943d95$1@news.povray.org>
Standards were created for a reason.  The second you have to start
intentionally modifying your code to dodge implementation issues it
completely defeats the point of having the standard in the first place.
And really, since when should it be the web designer's responsibility to
mangle their perfectly compliant page just because Microsoft can't seem
to fix their broken web browser after this many years?
I suppose I just fail to see why me complaining about a perfectly valid
issue *that many web designers complain about* could possibly warrant
that sort of response.
-Ian
Date: 21 Jan 2008 01:54:44
Message: <479441b4@news.povray.org>
Okay, I've had time to find the real cause of this bug. It's with the
beta version of POV, not your include file! I posted a bug report to
p.beta-test.
Sam
Date: 21 Jan 2008 03:34:30
Message: <47945916$1@news.povray.org>
>> attached image).
> Eep, that's even worse than in IE6! How could that happen...?
I don't get that at all in IE7, it looks perfect and identical to FF.  I
thought maybe you have fixed it since you made the first post?
Date: 21 Jan 2008 04:57:16
Message: <47946c7c$1@news.povray.org>
It shouldn't; I'm just saying that there's nothing *requiring* you to
use CSS to design a webpage, or that you can't use the parts of CSS that
*do* work with IE and make a working layout.  I use some CSS on my
webpage and it renders fine in IE.
Tim Cook
Version: 3.12
