POV-Ray : Newsgroups : povray.off-topic : Holograms for camouflage! Server Time
9 Jun 2026 11:00:51 EDT (-0400)
  Holograms for camouflage! (Message 14 to 23 of 23)
Subject: Re: Holograms for camouflage!
Date: 5 Jan 2008 06:16:05
Message: <477f66f5$1@news.povray.org>
Leroy wrote:
> Deer are color blind, so you can wear bright orange!
No you can't - but you can wear nicely dappled and patterned orange
without much issue. ;-)
http://blog.orphi.me.uk/
Date: 5 Jan 2008 18:33:59
Message: <MPG.21e9c0a1e64dd3f298a0da@news.povray.org>
In article <477e910f$1@news.povray.org>,
nic### [at] gmailisthebestcom says...
> And the fact that there isn't any 3D hologram projector except on the
> virtual world on your website :)
> PS: I fell for it too. Great job there.
Well, this isn't 100% true now. Some guy is developing a system that
takes a laser, runs code through a standard 3D card to determine the
pattern of interference needed to make a 3D image, then alters the
laser, using some optical technique that apparently eliminates the
mirrors normally used, to generate a hologram. I.e., he is doing the
reverse of what you do to get a holographic print. Like other holograms,
it isn't projected into mid air, but on a flat surface. It is also only
monocolored at the moment, though that wouldn't matter much for most
animals, and takes up a room the size of a small refrigerator truck. He
hopes to make it work with multicolor lasers, and get it down to the
size of... a copier machine, or some such, in the relatively near
future.
Now, whether you could a) generate an image from data, like a picture,
which would work, b) find some place to hide something the size of a
refer, and c) really hide behind it usefully, is another matter. lol You
are probably better off just buying camo netting. 5-10 years from now...
who knows, especially with new developments in laser technology, 3D
hardware, etc.
Think I read about it is MIT Technology Review, but not sure if that was
the magazine or not.
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 6 Jan 2008 01:04:43
Message: <47806f7b$1@news.povray.org>
I think the typical deer blind is box nailed to a tree, or a
movable tower with a box on top. Not much chance of
mistaking it for a deer.
Date: 6 Jan 2008 05:25:36
Message: <4780aca0@news.povray.org>
Well, when I was doing my final year at uni, one of the professors was
talking about a new 3D TV technology that was "nearly ready to market".
It still hasn't appeared.
There are quite a wide range of technologies out there for generating 3D
animated images. None of them has ever become all that popular. And
certainly none of them enable you to "project" a hologram into mid-air. ;-)
Date: 6 Jan 2008 16:35:10
Message: <MPG.21eaf75c770cacfa98a0dc@news.povray.org>
In article <4780aca0@news.povray.org>, voi### [at] devnull says...
Well. The problem with the 3D TV system is a) recording, b) storage and
c) transmission. Your talking about a *massive* increase in data. Like,
a blueray disk might store 20 minutes of the data needed (instead of
like 10 DVDs, or what ever it is supposed to support). This guys idea
"looks" like its projected into space, since it works just like a
projected holographic plate, and while the laser assembly is large and
complicated, the hardware needed to calculate the image is already
sitting on your desk. A number of improvements in chip based lasers, and
other tricks, are ***very*** likely to make it viable to have a
holographic display on your desk in very short order. Recording and
playing back "TV", where you are using a camera to record the data, is
going to require either a) a vastly different technology, or b) some
method of reading the data from two cameras, calculating a 3D mesh(s) of
the objects in the scene, mapping textures to those, then reintegrating
them at the other end. I.e., each frame would need "image" data, as in
the textures, and "mesh" data, defining the location of the objects in
3D, onto which you want to map those images. You *might* be able to code
something that can make a decent approximation now, but its going to be
something that has a surface, but no solidity. I.e., a movie made using
3D software could place an object in the center of scene, which could be
seen from all angles and sides, while something mapped using the sort of
3D system we *can* build, would look like one of those topo maps they
make, which is just plastic formed into a shell, then painted.
This isn't what they are trying to create though. They want something
more detailed, and I don't think they have the software, cameras,
hardware *or* bandwidth to manage it yet. And storing the data at all,
instead of doing it live....
void main () {
  else
Date: 6 Jan 2008 17:19:51
Message: <47815407@news.povray.org>
Massive increase in data? Yes. Corresponding increase in
compressibility? Maybe.
> Recording and
This technology already exists. See, for example, The Matrix. Record a
scene from several directions, and then pan around it in (nearly)
arbitrary 3D by interpolating between camera angles. Apparently they
call it "time slicing". (In the still image case at least.)
I suspect it's technically possible right now. As to whether it will
ever become economically feasible... I doubt it. But maybe.
And I return to my original point: nobody has a system that can
*project* a hologram into free air yet. Nor even a vague inkling of how
to approach such a task. ;-)
Date: 7 Jan 2008 00:20:46
Message: <4781b6ae@news.povray.org>
> Recording and
They did that for Minority Report, but I think they used something like
15 different camera angles to get the geometry calculated correctly.
I'd have to go back and look, and I'm feeling lazy atm.
...Ben Chambers
www.pacificwebguy.com
Date: 8 Jan 2008 11:46:52
Message: <4783a8fc$1@news.povray.org>
Orchid XP v7 nous apporta ses lumieres en ce 2008/01/06 17:19:
>>> 3D animated images. None of them has ever become all that popular.
>>> And certainly none of them enable you to "project" a hologram into
>>> mid-air. ;-)
>> and c) transmission. Your talking about a *massive* increase in data.
OK. Any voxel of open space will be zero, you will have a LOT of those.
Any voxel inside a closed surface can be set to zero, as there will be no way of
recording nor vewing those.
Finaly, you are looking at absolutely huge compression capability, as long as
you don't have to much non uniforn fog and smoke.
You know you've been raytracing too long when you tell stories to your kids that
include stuff like "Once there was a polygon mesh who was very sad because he
was only Gourard shaded."
     -- Taps a.k.a. Tapio Vocadlo
Date: 8 Jan 2008 14:59:04
Message: <MPG.21ec986db23275d698a0dd@news.povray.org>
In article <47815407@news.povray.org>, voi### [at] devnull says...
3D
> > Recording and
f
Yeah. It uses like 18-36 cameras, or some crazy stuff like that. I.e.,
one camera per "slice" of the 360 degree pie. Its not possible in real
time, yet, and is limited to what you can place a ring of cameras
around. As for what they did in the Matrix. They took time slice images,
then integrated CGI into the scenes along with it, so most of it wasn't
time slice, or 3D in that sense anyway. Its a very limited, but very
interested technology, and while you *could* build meshes and map
textures with it, its just not practical, for most cases. We need
something that uses fewer cameras, preferably two, and can "map" a scene
the same way human vision does. I.e., build a believable 3D result,
using limited data, and a very narrow wedge of perception. And that we
*don't* have.
void main () {
  else
Date: 8 Jan 2008 15:39:06
Message: <4783df6a@news.povray.org>
  There exists at least one documentary and one music video which use this
technique very well. The documentary has quite impressive images. Too bad
I can't remember the names.
