POV-Ray : Newsgroups : povray.off-topic : Almost dead computer? Server Time
10 Jun 2026 16:48:25 EDT (-0400)
  Almost dead computer? (Message 11 to 17 of 17)
Subject: Re: Almost dead computer?
Date: 28 Sep 2007 22:50:33
Message: <46fdbd79$1@news.povray.org>
Jim Henderson escribió:
> On Fri, 28 Sep 2007 21:56:46 +0100, St. wrote:
>>      I've even been *inside* the power supply and cleaned it out! Now
>> there's a sight for sore eyes!
>>        It's amazing how the dust builds up in there.
> Yeah, it really is.  We've got three cats as well, so not only does dust
> end up in there, but cat hair.  I need to replace a couple of the fans,
> too - I've got three half-height 5.25" bays with bay fans in them, and at
> least one of them has stopped working (the fans have snapped off the
> motors).
> Jim
Dust is a big problem for POVers. POV-Ray uses 100% CPU. More CPU usage
= more computer heat. Dusty fan + POV-Ray = very hot CPU.
But then, I run BOINC too, so the CPU on my Pentium IV computer has been
at 100% for around two years (not exactly continuously, uptime record is
27 days). I once cleaned it, then opened it three months later and it
was all dusty again. >_> CPU reached 75°C sometimes (according to Intel
it's the limit; knowing it was not surpassing the limit made me worry less).
Date: 29 Sep 2007 02:02:27
Message: <46fdea73$1@news.povray.org>
>> dust end up in there, but cat hair.  I need to replace a couple of the
>> fans, too - I've got three half-height 5.25" bays with bay fans in
>> them, and at least one of them has stopped working (the fans have
>> snapped off the motors).
>> Jim
It does tend to drive the utilization up; in my particular case, the
system isn't used for POV; but I've got a new dual-core Athlon system on
its way next week, and I anticipate it being used for some more
rendering.  I've not done much serious with POV since I had to give my
dual-processor Dell system back to work (changed jobs and it was a lab
machine that the department wanted back).  Pity, because I loaded it up
with memory - it had 4 GB thanks to finding a very difficult-to-find
memory expansion board.
But I miss that system.
> less).
That is quite warm, yeah.  My laptop has burned out a couple of times
(but not due to CPU overutilization, more because of a faulty suspend
that would put the fans to sleep but not the CPU or the video card).
Jim
Date: 29 Sep 2007 03:29:49
Message: <46fdfeed@news.povray.org>
1. The power switch isn't working.
2. The power switch isn't connected properly. (Usually a thin 2-strand
wire to a pair of bare pins on the motherboard.)
3. The power supply unit is faulty.
4. The motherboard is faulty.
Pick one of the above.
I don't know about where you are, but over here a new power supply is a
pretty cheap item, so maybe start with that? (It's also quite simple to
replace.)
http://blog.orphi.me.uk/
Date: 1 Oct 2007 07:51:49
Message: <4700df55@news.povray.org>
"scott" <sco### [at] laptopcom> wrote in message
news:46fcfde5$1@news.povray.org...
>> I'm having problems with my computer again. (Writing from another one.)
>> When I press the ON button, nothing happens at all. Does it have power?
>> Yes - the little green LED on the motherboard is lit just fine. I just
>> can't turn the thing on...!
>> Any suggestions what to do, or even just finding out in which part of the
>> computer the problem lies?
>> (Remember that I am totally clueless when it comes to hardware...)
> As Warp said, likely the PSU, or just the On switch has
> broken/disconnected. You're going to have to get inside the PC to diagnose
> the problem further.
> Step 1 : Unplug the big connector that goes onto the mainboard from the
> PSU. It will have 20 or 30 small cables going into it all different
> colours. Once unplugged, look for the green one (there should only be one,
> pin 14 IIRC) and then find a black one (probably more than one).  With
> power disconnected, insert a paper-clip (or a bit of wire) into the socket
> where the green and black cables are, thus joining them together.  Then
> turn on the mains, the PSU should spin-up.  If it doesn't get a new PSU.
I don't like this approach. Though I have found a green and a black wire,
I'm not 100% certain I understand what you mean I should do with them, and I
don't like risking damaging my hardware (or myself).
Isn't there some way to test the PSU without using paper clips or cables? I
have an old motherboard I don't need that can be used for plugging the PSU
in if it helps any...
> 2) If the PSU is working ok then next check the On switch is working.
> Look where the on switch is connected to the mainboard (usually in the
> bottom corner somewhere) and unplug it.
Problem here is that several cables are coming from a closed area of my
case, so I can't see which one is for the On-switch and which is for reset,
LEDs etc. I can't even imagine how to open this part of the case - I can't
see any obvious screws to unscrew... Can I deduce it from where the cables
are plugged in? I found this image of my motherboard:
http://www.thetrailingedge.com/images/products/asus-a8n-sli-big.jpg
> Try jumping the two connectors on the mainboard with a paper-clip again.
Won't that equal to holding down the On-switch = signalling a shut-down?
> If the computer works then you have a problem with the On switch.  If it
> doesn't then you have a problem with the motherboard. You could then try
> forcing the PSU to start by jumping the green and black wires as in step
> 1) while it is connected to the mainboard.
I don't understand how the wires can be jumped while the cable is
simultaneously plugged in. I don't think I'm skilled enough with hardware to
operate at this level.
Rune
Date: 1 Oct 2007 08:27:33
Message: <4700e7b5$1@news.povray.org>
Ok, I tried plugging in the PSU to my old computer, and it correctly started
humming and could be turned on and off with that computer's ON-switch. It
also made some beeping. PSU fault ruled out.
Back to problem computer I wanted to test if the On-switch was at fault.
There was a cable labeled M/BSW that was plugged into some pins labeled
PWRSW so I guess that's the On-switch one. I tried unplugging that cable and
replacing it with a jumper while the power was off. That I turned the power
on and ... nothing happened.
So what does that mean? Can I be completely sure that the motherboard is the
fault, or...?
Rune
Date: 1 Oct 2007 09:31:27
Message: <4700f6af@news.povray.org>
  Technically speaking, not necessarily. That's because the old computer
might require less watts and the failing PSU may just be alive enough to
run it, but not your watt-hungry newer computer.
  It wouldn't be the first time that a dying PSU runs the computer for some
minutes but then it just shuts down. When it's left to cool for a moment
and the computer is turned on again, the same thing happens.
Date: 2 Oct 2007 17:48:27
Message: <4702bcab@news.povray.org>
> started humming and could be turned on and off with that computer's
> ON-switch. It also made some beeping. PSU fault ruled out.
> and replacing it with a jumper while the power was off. That I turned the
> power on and ... nothing happened.
> the fault, or...?
> Rune
Are the B-line capacitors on the motherboard OK? We had a dell that controls
one of our mass spectrometers blow its "b-line" capacitors on the
motherboard with similar results to what you describe. You can usually tell
by looking at them if they're bad or not.
http://www.windows-help-central.com/windows-xp-shutdown-automatically.html
