POV-Ray : Newsgroups : povray.off-topic : My laptop is a binge drinker Server Time
10 Jun 2026 16:47:56 EDT (-0400)
  My laptop is a binge drinker (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: My laptop is a binge drinker
Date: 10 Sep 2007 17:24:28
Message: <46e5b60c@news.povray.org>
46e5b254$1@news.povray.org...
>I heard that you can stick a cell-phone, or an Ipod
> that has gotten wet into a bag of dry uncooked rice
> overnight to get the last of the water out.  The rice
> absorbs the water I guess. You might try some
> variation on that.
One of these variations can be Silica gel dryer (the stuff you find in
little bags in electronic devices package)
Marc
Date: 10 Sep 2007 20:34:57
Message: <46e5e2b1$1@news.povray.org>
Bill Pragnell wrote:
> I will reassemble it this evening and fire it up to see what's what. In
> the meantime, does anyone have any additional advice?
If you persist in drinking around your laptop, get an external keyboard
so that you can keep the CPU farther away from the beer.
John
Date: 11 Sep 2007 05:03:09
Message: <46e659cd$1@news.povray.org>
Phil Cook wrote:
> And lo on Mon, 10 Sep 2007 14:05:46 +0100, Tom Austin <taustin> did
> spake, saying:
>>> So, last night I knocked over a full can of beer onto my MacBook.
>>> Which was open, turned on and rendering (as usual). I will reassemble
>>> it this evening and fire it up to see what's what. In the meantime,
>> just make sure it gets enough exercise so it doesn't get a beer
>> belly......
> and note that you'll now only be able to do that render when you pour
> some more beer onto it, otherwise it'll be 'file not found' ;-)
When I eventually check the output file I'll probably find unexpected
focal blur. Or maybe the preview will look much better than the actual
image or something. :)
Date: 11 Sep 2007 05:17:12
Message: <46e65d18$1@news.povray.org>
Orchid XP v3 wrote:
> 1. Where the hell did you get lab-grade ethanol from?
The lab at work. You've probably got access to some too by the sounds of
it, although I wouldn't go 'borrowing' any unless you know for certain
that you won't get fired for it.
> 2. Isn't that likely to disolve important plastic components?
I don't think so, maybe some of the cheaper adhesives. Now acetone -
that would probably dissolve the circuit boards! Ethanol is particularly
suitable for cleaning electronics because it's hydrophilic,
non-conductive and evaporates very swiftly at room temperature.
Date: 11 Sep 2007 05:20:13
Message: <46e65dcd$1@news.povray.org>
>> variation on that.
Good ideas both - we've got silica in the desiccators in the lab, I'll
borrow some of that and give it a go. Apparently it can take weeks to
properly dry laptops after spillages...
Date: 11 Sep 2007 05:20:46
Message: <46e65dee$1@news.povray.org>
>> In the meantime, does anyone have any additional advice?
Yes, or one of those silicone overlays. Isn't 20-20 hindsight a
wonderful thing! :)
Date: 11 Sep 2007 05:26:05
Message: <46e65f2d$1@news.povray.org>
Well, I put it back together and booted it up last night. I think it
needs some more drying time :(
I think the HD and motherboard and everything actually within the case
is fine. However, the screen has been badly affected - it has big glare
artifacts across more than a quarter of its area, although all the
pixels seem to be firing OK so maybe the moisture is in a different
layer or something. The keyboard has 7-8 non-functional keys and I have
a suspicion it's sending the wrong characters, because I can no longer
log in - it complains about the password, even though all those keys
appear to work.
Anyway, it's back in bits in the airing cupboard now. I think it'll take
some time to be sure of long-term damage...
(kicks self)
Date: 11 Sep 2007 06:16:04
Message: <46e66ae4$1@news.povray.org>
> However, the screen has been badly affected - it has big glare artifacts
> across more than a quarter of its area, although all the pixels seem to be
> firing OK so maybe the moisture is in a different layer or something.
Yes, it's pretty unlikely that any moisture got inside the actual LC, or
even under the polarisers, they are all laminated together with
moisture-proof seals around the outside.
What probably happened is the beer got between the rear polariser and the
backlight, there is usually a 100-500 micron air-gap that could easily fill
with liquid.  Any contamination in this area will show up very obviously on
the screen.
Cleaning it out will be hard, if you're lucky you could remove the actual
display panel from the backlight without too much effort (sometimes they are
stuck down with almost super-glue like adhesives!).  But then the backlight
will consist of several very thin optical films, which the liquid could have
got between too.  In theory you could take the backlight apart and clean
each film thoroughly, but I don't rate your chances of being able to get
back to a perfect looking screen (this sort of assembly is normally done in
clean rooms).
Date: 11 Sep 2007 06:47:38
Message: <46e6724a$1@news.povray.org>
>> layer or something.
That's a relief.
> the backlight, there is usually a 100-500 micron air-gap that could
> easily fill with liquid.  Any contamination in this area will show up
> very obviously on the screen.
Well, I'm hoping that my overkill sloshing of ethanol is the main
culprit here, and that most of it will evaporate eventually. I've taken
the trim off the screen which will help, I guess - there are some small
vents around the edge of the actual screen panel. I'm reluctant to take
it apart further without good reason because I have zero experience with
LCDs!
> actual display panel from the backlight without too much effort
> (sometimes they are stuck down with almost super-glue like adhesives!).
It doesn't look human-dismantle-able, I couldn't see any more screws
than those that hold it to the plastic case.
> But then the backlight will consist of several very thin optical films,
> which the liquid could have got between too.  In theory you could take
> the backlight apart and clean each film thoroughly, but I don't rate
> your chances of being able to get back to a perfect looking screen (this
> sort of assembly is normally done in clean rooms).
Are they very delicate? I don't have access to a clean room but we have
any amount of rubber gloves, sterile dooberys and anti-static wossnames
in our lab at work.
The real problem is if the films are held together by decent adhesive I
might break something just taking it apart. This will be a worst-case
last-ditch option I think!
Thanks for the info
Date: 11 Sep 2007 07:09:29
Message: <46e67769$1@news.povray.org>
>> fill with liquid.  Any contamination in this area will show up very
> Well, I'm hoping that my overkill sloshing of ethanol is the main culprit
It may be a residue of ethanol on the rear polariser, you could try and put
a few drops on the front of the screen and see if you can see anything once
it has dried off.  Polarisers are funny things and react weirdly sometimes
to certain chemicals.
Turn on the screen anyway, it will generate a load of heat which will help
dry out any left-over moisture.
> It doesn't look human-dismantle-able, I couldn't see any more screws than
Yeh, they are not really designed to be taken apart once assembled.  A lot
of the components are stuck down and "snapped in" rather than screwed.  If
you don't know the details about the exact model you could easily end up
breaking something.
The panel will be made from two sheets of glass stuck together around the
edge, each sheet of glass is probably between 0.3 and 0.7 mm.  The only real
weak point is around the edge where there is no polariser attached to
strengthen the glass - it is really easy to chip or snap off a corner or
edge of the glass here, especially as this is usually where it is stuck down
to the backlight.  Once you do that it's the end, because there are
electrical connections and circuits all around the edge of the glass.
The films aren't usually held together by anything, they just sit in there
and are constrained from moving by all the other components.  Once you get
the panel itself off, the films should just lift out one by one (maybe they
have a small dab of adhesive in one corner to help keep them in position).
The hardest bit is the glue around the outside of the panel that holds it to
the backlight.  Maybe you have some chemical that can dissolve this
adhesive, or just go around the outside carefully with a knife (if
accessible).  Don't put any force on the edge of the glass though, it's the
weakest point and will chip easily.
