POV-Ray : Newsgroups : povray.off-topic : My laptop is a binge drinker Server Time
10 Jun 2026 15:07:28 EDT (-0400)
  My laptop is a binge drinker (Message 17 to 26 of 26)
Subject: Re: My laptop is a binge drinker
Date: 11 Sep 2007 07:38:36
Message: <46e67e3c$1@news.povray.org>
>>> What probably happened is the beer got between the rear polariser and
>>> the backlight, there is usually a 100-500 micron air-gap that could
>>> easily fill with liquid.  Any contamination in this area will show up
>>> very obviously on the screen.
>> Well, I'm hoping that my overkill sloshing of ethanol is the main
>> culprit here, and that most of it will evaporate eventually.
> It may be a residue of ethanol on the rear polariser, you could try and
> put a few drops on the front of the screen and see if you can see
> anything once it has dried off.  Polarisers are funny things and react
> weirdly sometimes to certain chemicals.
> Turn on the screen anyway, it will generate a load of heat which will
> help dry out any left-over moisture.
My laptop's screen died after I was caught under heavy rain, carrying it
in a not-so-waterproof bag...
I never knew exactly what happened, but apparently some water got caught
in the screen, causing the sort of effect Bill is seeing, I think. At
first it was working OK but large drops of liquid could be seen, I
believe they were behind the pixels and just in front of the backlight.
I thought turning it on would help it dry, and apparently it was an
error... One day after that the screen would not show anything. Perhaps
some metallic connector got corroded by the water, I don't know.
The screen can still be turned on (it was a year ago), but now shows
only squarish clusters of weakly colored pixels. Something hard to
describe... Anyhow my laptop has became a desktop :-( And traces of the
water can still be seen.
The interesting thing is that it had one broken pixel that permanently
appeared red. This is now the only pixel with a definite color ;-)
I don't know exactly how you can solve the problem, but in my experience
turning it on to make it dry did not help...
Vincent
Date: 11 Sep 2007 08:03:51
Message: <46e68427$1@news.povray.org>
> error...
You need to make sure all water (or anything water-based, eg beer) is gone
before turning it on.  As soon as you get water in anything electronic rip
the battery out immediately, otherwise the tracks on the circuit boards (and
the glass if you have an LCD) will start to corrode very quickly.
Only after you have got rid of all the water should you attempt to put the
battery back in and turn it on.  Using ethanol (as Bill did) is a good way
to get rid of all the water, my suggestion was to turn it on to encourage
any remaining ethanol to evaporate.
Sorry if that wasn't clear... I take no responsibility for anyone damaging
anything :-)
Date: 11 Sep 2007 08:49:32
Message: <46e68edc$1@news.povray.org>
>> error...
> gone before turning it on.  As soon as you get water in anything
> electronic rip the battery out immediately, otherwise the tracks on the
> circuit boards (and the glass if you have an LCD) will start to corrode
> very quickly.
> the battery back in and turn it on.  Using ethanol (as Bill did) is a
> good way to get rid of all the water, my suggestion was to turn it on to
> encourage any remaining ethanol to evaporate.
> damaging anything :-)
Well in my case the damage is done and I will only blame myself :-) In
fact I'm surprised that the screen is the only thing that died in that
laptop...
I guess what confused me in your previous post was the term "moisture"
which I associate with water.
That raises another question: how can one be sure that no water is left,
before turning the screen on? And if liquid can be seen still, how can
you tell it's ethanol?
Vincent
Date: 11 Sep 2007 09:55:47
Message: <46e69e63$1@news.povray.org>
> before turning the screen on? And if liquid can be seen still, how can you
> tell it's ethanol?
Good point, I assume that Bill has it covered though:
"Well, I'm hoping that my overkill sloshing of ethanol is the main
culprit here,"
I had a look through a few documents here and my suspicion is that the
ethanol might have done some permanent damage to the polarisers.  Here we
have to test the polarisers for lots of different things (petrol, diesel,
sweat, face-cream, cleaning fluids, coffee etc), and one of the tests for
cleaner fluid (some mixture with ethanol in it) often fails and leaves
permanent marks on the polariser...
FWIW we use IPA (isopropyl alcohol) for cleaning the polarisers... might be
worth a shot if you can get to the inside.
Date: 11 Sep 2007 10:50:34
Message: <op.tyhvixb8c3xi7v@news.povray.org>
And lo on Tue, 11 Sep 2007 10:28:22 +0100, Bill Pragnell
<bil### [at] hotmailcom> did spake, saying:
> Well, I put it back together and booted it up last night. I think it
> needs some more drying time :(
> I think the HD and motherboard and everything actually within the case
> is fine. However, the screen has been badly affected - it has big glare
> artifacts across more than a quarter of its area, although all the
> pixels seem to be firing OK so maybe the moisture is in a different
> layer or something. The keyboard has 7-8 non-functional keys and I have
> a suspicion it's sending the wrong characters, because I can no longer
> log in - it complains about the password, even though all those keys
> appear to work.
That'd be the hangover, try not to type so heavily.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 11 Sep 2007 10:51:29
Message: <46e6ab71$1@news.povray.org>
Yeek, now I hope it was the beer after all. Do you make LCDs for Apple
or can I also hope that their materials are sufficiently different that
I might be in the clear? :-\
> be worth a shot if you can get to the inside.
I'll look into it, cheers
Date: 11 Sep 2007 11:07:37
Message: <46e6af39$1@news.povray.org>
> Yeek, now I hope it was the beer after all. Do you make LCDs for Apple or
> can I also hope that their materials are sufficiently different that I
I know we supply the LCDs for the full-size iPods and the iPhone, not sure
about any other Apple products though, it's not out of the realms of
possibility that we do.  The other groups tend to keep themselves very much
to themselves, I only really know about LCDs in phones and cars in Europe.
But even within my small area of knowledge we use several different
polariser suppliers and each of them has several different versions of
polarisers, each with different good and bad points.  It's always a matter
of compromises when you select which one to use.
It's worth noting though that the front polariser usually has some
anti-glare and anti-reflection coatings (unless you have one of those "CRT"
effect LCDs...) and possibly even some layer to protect it from impact with
the keyboard, so the front is usually much better protected than the back...
Date: 13 Sep 2007 09:21:40
Message: <46e93964@news.povray.org>
It lives!
24h in an airing cupboard, 24h sealed in a bin liner with a tray of
silica crystals. The keyboard works perfectly, although the touchpad
button sticks a little. It boots to the desktop properly, no problems.
The screen is still a bit munged, but I think the effect has shrunk
slightly, so I'm going to keep drying it when not in use. The pixels all
fire ok, it's just a smudge of brightness variation... looks really weird!
I've invested in an external drive to back up my system properly just in
case the HD throws in the towel at a later date (which I was meaning to
do anyway, so not really an unexpected cost).
Thanks for the sounding board, everybode :)
Date: 4 Oct 2007 17:57:12
Message: <470561b8$1@news.povray.org>
"Bill Pragnell" <bil### [at] hotmailcom> wrote in message
news:46e93964@news.povray.org...
> It lives!
Very Impressive. I just bought a MacBook Pro this afternoon and I hope to
never have to go through this. I am reassured however that it is possible in
some cases.
-r
Date: 5 Oct 2007 05:36:01
Message: <47060581$1@news.povray.org>
>> It lives!
> some cases.
Get one of those silicone keyboard covers if your home is a high-risk
beverage environment. I plan to. Any day now. Promise.
