POV-Ray : Newsgroups : povray.newusers : Want to attach one object to another Server Time
7 Apr 2026 07:24:39 EDT (-0400)
  Want to attach one object to another (Message 1 to 10 of 25)
Subject: Want to attach one object to another
Date: 18 Jun 2013 16:05:00
Message: <web.51c0bc73e677e64c520168c30@news.povray.org>
I have a cylinder that needs a label.
So i created the cylinder object and the label object.
this http://www.harry-arends.nl/werkgroep/images/WrapText.png
should look like this http://www.harry-arends.nl/werkgroep/images/Ptdc0437.jpg
I was looking at the wrap commant but with no result
Subject: Re: Want to attach one object to another
Date: 18 Jun 2013 17:24:39
Message: <51c0d017@news.povray.org>
http://wiki.povray.org/content/Reference:Bitmap_Modifiers#The_map_type_Option
Date: 18 Jun 2013 17:27:12
Message: <51c0d0b0$1@news.povray.org>
Label object? I would use a texture with an image map wrapped around the
cylinder.
Are you mixing up wrap with warp?
Regards
Date: 18 Jun 2013 22:36:13
Message: <51c1191d$1@news.povray.org>
If you use the cylindrical warp with the once option, all should be
nice. Be sure to scale horizontaly so that it covers the correct part.
If it covers 1 fourth of the circonference, you need to use
scale<1/4,1,1>. Without scaling, the image will get wrapped around
exactly once, the right side touching the left side.
Scale along the Y direction to get the correct hight. It start at 1 unit
high.
In this case, scaling along the Z axis have no effect.
You may want to give the label some thickness.
In that case, I'd use a cylinder just very slightly larger than the body
of your object, and apply the image_map to it. Use a difference or
intersection to keep only the part with your image, or use a transparent
pigment for the part outside of the label. The transparent pigment will
leave a gap that may be visible in some cases.
Date: 19 Jun 2013 05:00:02
Message: <web.51c172cfc1f827c4520168c30@news.povray.org>
Maybe i should say warp instead of wrap.
Als both the cylinder and the label are POV-Ray objects.
The label is no bitmap image.
Date: 19 Jun 2013 06:01:07
Message: <51c18163$1@news.povray.org>
Well that is different. You did it the hard way. :-)
I don't know if applying shear transformations would bend the label the
way you want. My mathematics is not good enough.
You could rebuild the label but use a cylinder as your base. Then rotate
the characters and symbols so that they are tangential to where they
intersect the cylinder. Then intersect the characters with a slightly
larger cylinder to smooth them flush with the label.
Regards
Date: 19 Jun 2013 16:23:15
Message: <51c21333$1@news.povray.org>
Or use an object pattern of the content of the label for eatch colours.
Then, you can use a warp{spherical}.
Date: 19 Jun 2013 16:49:00
Message: <51c2193c$1@news.povray.org>
Nice idea. But this is newusers, Alain.
Could you point to an example? I wouldn't mind seeing how to do this myself.
Regards
Date: 20 Jun 2013 00:38:35
Message: <51c2874b$1@news.povray.org>
> myself.
 From the included documentation for the Windows version, section
3.4.7.2.5 Object Pattern.
pigment{object{Some_object color InsidePigment color OutsidePigment}}
"Some_object" must be defined in a #declare directive.
This is often used to create a pattern from a text object, but any
object can be used, both simple or complexe ones. Points that are inside
the reference object use the first item. Those outside will use the
second item.
For the warp, it is described in section 3.4.7.5.5.7 Mapping using warps.
Assuming that you created an object named "My_Text" and "My_Logo, it can
look like this:
pigment{rgb 1} // the background.
pigment{ // a red element, can be some text or anything.
  object{My_Logo color rgb <1,0,0> color rgbt 1
   warp{cylindrical}
   translate 3*y // and move it up 3 units
   once // Ensure that the pigment show only one time
pigment{ // some black element, can be some text.
  object{My_Text color rgb 0 color rgbt 1
   warp{cylindrical}
   once
This is a layered pigment using 3 pigments with some transparency.
You can use any number of layers.
The pigment "rgbt 1" is perfectly transparent showing whatever is under.
The scaling of the X component control the fraction of the cylinder's
circonference that is covered. Normaly, you should use a value that is
less than 1. Without that scaling, the pigment get wraped all the way
around the cylinder.
The scaling of the Y component control the hight. Without it, the
pigment will be only 1 unit high.
The lower point of the pattern is always a Y=0, and, without once, will
repeat every unit up and down.
I used simple pigments, but you can use full textures. It will look like:
texture{object{My_Object texture{Texture1} texture{Texture2} }}
Date: 21 Jun 2013 05:15:01
Message: <web.51c41928c1f827c4520168c30@news.povray.org>
I have made a picture of the label.
Trying the example in the documentation i managed te get it on a cylinder.
object{
    cylinder{<0,0,0><0,70,0>27.5
        pigment{
        image_map {
            jpeg "RE55.jpg"
            map_type 1
        scale<.1,.1,.1>
But it seems i cant get it smaller and my knowledge of povray to do a correct
search, not knowing the the correct phrases to use, i cant find the solution.
