POV-Ray : Newsgroups : povray.newusers : Single lens show side view Server Time
28 Sep 2024 18:27:09 EDT (-0400)
  Single lens show side view (Message 1 to 10 of 13)
Subject: Single lens show side view
Date: 6 Oct 2011 12:50:00
Message: <web.4e8ddbded249915551a4331b0@news.povray.org>
Hello everyone,
I have created a checker board with a pole. Later i designed a single lens (by
intersecting two spheres) to view the pole through the lens. Now i need to see
the side view of the entire image (i.e., Single lens show side view, to
illustrate distance between lens and pole). Please help me with this...
Thanks in advance
Cheers,
Arun.
Subject: Re: Single lens show side view
Date: 6 Oct 2011 13:11:46
Message: <4e8de152$1@news.povray.org>
Am 06.10.2011 18:48, schrieb Arun Kumar:
> Hello everyone,
> Thanks in advance
Change the camera position accordingly; you may also want to use an
orthographic camera rather than the standard perspective camera.
To retain the ability to render the image from the current camera
position, us a construct such as:
   #declare SideView = yes;
   #if (SideView)
     camera { ... /* side view camera */ }
   #else
     camera { ... /* current camera */ }
Date: 7 Oct 2011 02:20:01
Message: <web.4e8e99da66b8b2e851a4331b0@news.povray.org>
Thanks for the clarification...
I have some more doubts. I created a checker board with stick and a lens. I need
to view the stick through the lens. But the lens which i created is in
horizontal position. I need to rotate it vertically so that the stick can be
viewed through the lens. I tried changing the attributes of ROTATE and TRANSLATE
but i couldn't get the exact image which am looking for. Please help me with
this issue.
Here is my code..
#include "glass.inc"
#declare Photons=on;
  global_settings {
  assumed_gamma 1.0
  max_trace_level 5
  #if (Photons)
    photons {
      spacing 0.02
  //perspective
  location  <1, 2, -10>
  look_at   <0, 2,  0>
  right     x*1.33
   light_source
        { <0,15,0>
           color rgb <1,1,1>
#declare Glass_material =    // Glass material
material {
    pigment {rgbt 1}
    finish {
      ambient 0.0
      diffuse 0.05
      specular 0.6
      roughness 0.005
  interior {
    ior 1.5
    fade_power 1001
    fade_distance 0.9
    fade_color <0.5,0.8,0.6>
// CSG union, add all of shapes 1...N
union
     box      { <-4,0,-4>,<4,0,4>    pigment { checker color Black, color White}
rotate -y*35}
     cylinder { <0,0,0>,<0,3.5,0>, 0.1   pigment { color MediumSpringGreen } }
     intersection
     sphere {
      <0, 5.5, 0>, 6
      scale 1
      rotate <0, 0, 0>
      translate <0, 0, 0>
   sphere {
      <0, -5.5, 0>, 6
      scale 1
      rotate <0, 0, 0>
      translate <0, 0, 0>
   translate y*3
      color rgbt <0.2, 0.41176, 0.43922, 0.8>
   interior {
      ior 1.5
   material { Glass_material }
   photons {
      target
      collect off
Thanks,
Arun
Date: 7 Oct 2011 03:28:40
Message: <4e8eaa28$1@news.povray.org>
> this issue.
I kept the board without rotation, and moved that rotation on the camera.
I removed the union (no purpose)
Adjusted max_trace_level
Beware, the lense currently has 2 layered textures/pigments (and the
interior... the colour of the material might be too clear to view the
lense per itself.
#version 3.7;
#declare Overview=on;
  global_settings { assumed_gamma 1.0
// 20 is for overview=on
// 3 when off
max_trace_level 55
  #if (Photons)
  photons { spacing 0.02 }
#if (Overview)
  //perspective
  look_at   <0, 2,  0>
  right     x*1.33
  rotate y*65
#else
  //perspective
  look_at   <0, 2,  0>
  right     x*1.33
light_source { <0,15,0> color rgb <1,1,1> }
material {
    pigment {rgbt 1}
    finish {
      ambient 0.0
      diffuse 0.05
      specular 0.6
      roughness 0.005
  interior {
    ior 1.5
    fade_power 1001
    fade_distance 0.9
// floor
White} }
// pole
// lens
intersection
   sphere { <0, 5.5, 0>, 6 }
   sphere { <0, -5.5, 0>, 6 }
   rotate 90*x
   translate y*2-3*z
// Beware, layered textures ahead...
   pigment { color rgbt <0.2, 0.41176, 0.43922, 0.8> }
   interior { ior 1.5 }
   photons { target collect off }
Date: 7 Oct 2011 03:31:46
Message: <4e8eaae2$1@news.povray.org>
> this issue.
> Here is my code..
>    global_settings {
>    assumed_gamma 1.0
>    max_trace_level 5
>    #if (Photons)
>      photons {
>        spacing 0.02
>    #end
> camera {
>    //perspective
>    location<1, 2, -10>
>    look_at<0, 2,  0>
>    right     x*1.33
>     light_source
>          {<0,15,0>
>             color rgb<1,1,1>
> material {
>    texture {
>      pigment {rgbt 1}
>      finish {
>        ambient 0.0
>        diffuse 0.05
>        specular 0.6
>        roughness 0.005
>    interior {
>      ior 1.5
>      fade_power 1001
>      fade_distance 0.9
>      fade_color<0.5,0.8,0.6>
> union
>       box      {<-4,0,-4>,<4,0,4>     pigment { checker color Black, color White}
> rotate -y*35}
>       cylinder {<0,0,0>,<0,3.5,0>, 0.1   pigment { color MediumSpringGreen } }
>       intersection
>       sphere {
>        <0, 5.5, 0>, 6
>        scale 1
>        rotate<0, 0, 0>
>        translate<0, 0, 0>
>     sphere {
>        <0, -5.5, 0>, 6
>        scale 1
>        rotate<0, 0, 0>
>        translate<0, 0, 0>
>     translate y*3
>     pigment {
>        color rgbt<0.2, 0.41176, 0.43922, 0.8>
>     interior {
>        ior 1.5
>     photons {
>        target
>        collect off
> Thanks,
> Arun
Change your code for the intersection like this:
intersection {
   sphere {
     <0, 0, 5.5>, 6
     scale 1
     rotate <0, 0, 0>
     translate <0, 0, 0>
   sphere {
     <0, 0, -5.5>, 6
     scale 1
     rotate <0, 0, 0>
     translate <0, 0, 0>
   translate <0, 2, -5>
   interior {
     ior 1.5
   photons {
     target
     collect off
Explanation: The intersection (the lens) is now defined in a vertical
manner by using the z-axis instead of the y-axis. Then, the lens is
translated 2 units along the y-axis and -5 units along the z-axis, in
order to see your cylinder at the origin.
NB It does not matter here, but your checkered box has no thickness. Use
a plane instead or give the box a little thickness like:
<-4, -0.1, -4>,<4, 0, 4>
in order to avoid coincident surfaces.
Date: 7 Oct 2011 16:52:32
Message: <4e8f6690@news.povray.org>
> this issue.
> Here is my code..
>    global_settings {
>    assumed_gamma 1.0
>    max_trace_level 5
>    #if (Photons)
>      photons {
>        spacing 0.02
>    #end
> camera {
>    //perspective
>    location<1, 2, -10>
>    look_at<0, 2,  0>
>    right     x*1.33
>     light_source
>          {<0,15,0>
>             color rgb<1,1,1>
> material {
>    texture {
>      pigment {rgbt 1}
>      finish {
>        ambient 0.0
>        diffuse 0.05
>        specular 0.6
>        roughness 0.005
>    interior {
>      ior 1.5
>      fade_power 1001
>      fade_distance 0.9
> union
> rotate -y*35}
>       intersection
>       sphere {
>        <0, 5.5, 0>, 6
>        scale 1
>        rotate<0, 0, 0>
>        translate<0, 0, 0>
>     sphere {
>        <0, -5.5, 0>, 6
>        scale 1
>        rotate<0, 0, 0>
>        translate<0, 0, 0>
>     translate y*3
>     pigment {
>     interior {
>        ior 1.5
>     photons {
>        target
>        collect off
> Thanks,
> Arun
As Thomas pointed out, by changing your working axis, you can create the
lens verticaly.
Next, if you want to rotate it in any way, you *must* rotate it before
you do any translate. Otherwise, it will also orbit arount the origin as
it rotates.
If you want, or need, to scale it, it should also be done before the
translation, or you'll also scale the previous translation making it
move further.
I find the lens visible enough as it is, no real need to change it's
colouration. It may be advisable to use a slightly coloured or textured
background.
Date: 7 Oct 2011 17:55:00
Message: <web.4e8f742366b8b2e878641e0c0@news.povray.org>
"Arun Kumar" <aru### [at] yahoocoin> wrote:
>    photons {
>       target
>       collect off
You did not ask about photons, but I thought I'd point out that this statement
has no effect in this scene.  You'll need to add "refraction on" to get the
effect of focused light.
Also look into autostop, as an intersection of spheres is often not efficiently
bounded.  (If you don't understand this, then just add "autostop 0" to the
photons block in your global_settings.  It may speed up the photons
calculations.)
Date: 19 Oct 2011 07:20:01
Message: <web.4e9eb24666b8b2e89a5a87d90@news.povray.org>
Thanks a lot...
Arun.
> > this issue.
> lense per itself.
> #version 3.7;
> // 3 when off
> max_trace_level 55
>   #if (Photons)
>   #end
> #if (Overview)
> camera {
>   //perspective
>   look_at   <0, 2,  0>
>   right     x*1.33
>   rotate y*65
> #else
> camera {
>   //perspective
>   look_at   <0, 2,  0>
>   right     x*1.33
> #end
> material {
>   texture {
>     pigment {rgbt 1}
>     finish {
>       ambient 0.0
>       diffuse 0.05
>       specular 0.6
>       roughness 0.005
>   interior {
>     ior 1.5
>     fade_power 1001
>     fade_distance 0.9
> // floor
> White} }
> // pole
> // lens
> intersection
>    rotate 90*x
>    translate y*2-3*z
Date: 21 Oct 2011 01:50:01
Message: <web.4ea1072266b8b2e89a5a87d90@news.povray.org>
Thanks again for your help.. It helped me a lot. I have created lens and front &
side views which am exactly looking for. Now i need to calculate the focal
length of the lens. How can i calculate the focal length.
To calculate focal length manually there is a formula
1/f = (n-1) {1/R1 - 1/R2}.
But how can i calculate it from the code.
I need to place the lens exactly at the distance of focal length to get the
better resolution image.
Thanks in advance.
Arun.
> > this issue.
> lense per itself.
> #version 3.7;
> // 3 when off
> max_trace_level 55
>   #if (Photons)
>   #end
> #if (Overview)
> camera {
>   //perspective
>   look_at   <0, 2,  0>
>   right     x*1.33
>   rotate y*65
> #else
> camera {
>   //perspective
>   look_at   <0, 2,  0>
>   right     x*1.33
> #end
> material {
>   texture {
>     pigment {rgbt 1}
>     finish {
>       ambient 0.0
>       diffuse 0.05
>       specular 0.6
>       roughness 0.005
>   interior {
>     ior 1.5
>     fade_power 1001
>     fade_distance 0.9
> // floor
> White} }
> // pole
> // lens
> intersection
>    rotate 90*x
>    translate y*2-3*z
Date: 21 Oct 2011 06:45:20
Message: <4ea14d40@news.povray.org>
Le 21/10/2011 07:46, Arun Kumar nous fit lire :
The formula is wrong. (or rather, you forgot the interesting part)
it's
1/f = (n-1)( 1/R1 - 1/R2 + (n-1)d/(nR1R2))
(if I was to trust wikipedia :
http://en.wikipedia.org/wiki/Focal_length
R1 & R2 are the radius of the sphere.
d is the thickness of the intersection (at the line connecting the spheres)
n is the ior
Numeric application from previous code:
R1=6;
R2=6;
d=1;
n=1.5;
notice that 1/R1-1/R2 is null;
1/f = 0.5 ( 0.5*1/(1.5*6*6)) =
.00462962962962962962962962962962962962962962962962962962
or f= 216
Units (meter, foot, pov-unit) are irrelevant as they all ends up in the
same space (a linear length).
