POV-Ray : Newsgroups : povray.newusers : New User Question about Variable Density Fog Server Time
7 Jul 2024 06:56:21 EDT (-0400)
  New User Question about Variable Density Fog (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: New User Question about Variable Density Fog
Date: 8 Apr 2011 04:10:01
Message: <web.4d9ec1c18c9a2319726a3c10@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> As for variable ior, sory, that's not possible, and may never be.
> It may be simulated to a sertain degree by giving your object an ior and
> altering it's normal according to some pattern.
Though it is painfully slow, a merge of a grid of boxes, each with its own ior,
does seem to work as expected.
Date: 15 Apr 2011 13:05:01
Message: <web.4da8787d8c9a231ce72fa320@news.povray.org>
Sounds good.  How would you tie the file data to the box grid? Can you post your
test code?  Variable ior would be really good, but I can live with variable
scatter. :)
I found a good link at http://paulbourke.net/miscellaneous/df3/
My orginal data is 3d, so the link looks very promising.
I assume DF3 is the only supported file format?  Would be nice if DF3 supported
floats, but gee, you can't have anything.  I probably could write a matlab
float2df3 util, but there's some 'c' code posted on the linked wavepage.
Life is good,
Thanks y'all for the posts.
Date: 16 Apr 2011 18:00:00
Message: <web.4daa11278c9a2319726a3c10@news.povray.org>
> scatter. :)
I always try to have my code output a valid POV-Ray include file, and sometimes
an entire scene file.  I've also used stand shell tools (grep,sed,awk) to
transform data similarly.  That said, POV-Ray can read something like a .csv
without too much trouble, just be sure to end each row with a comma.
My quick test POV-Ray scene (below) just uses an image for the IOR data.  [Note
I inverted the role of the source PNG's transmit component in the merged boxes
so it makes a sort of weird-lens-in-a-frame kind of thing.]
#version 3.7;
#include "stdinc.inc"
#declare pig_image =
 image_map {
  png "povray_64.png"
  once
box{<0,0,0>,<1,1,1>
pigment{pig_image}
#local image_width  = 64;
#local image_height = 64;
merge{
#local j=0.5;
#while(j<image_height)
   #local i=0.5;
   #while(i<image_width)
      #local image_color = eval_pigment(pig_image,
         <i/image_width,j/image_height,0.5>) ;
      box{<0,0,0>,<1,1,1>
         pigment{ Clear*(1-image_color.transmit)
                +Yellow*   image_color.transmit}
         interior{ ior 1+image_color.gray}
         scale 1.001 // Prevent coincident surfaces.
         translate <i,j,0>
      #local i=i+1;
#local j=j+1;
translate -0.5*<image_width,image_height,0>
scale <0.06,0.06,1>
translate -5*z
}//end union
plane{y,-2 pigment{checker Blue Gray50}}
sphere{0,100 pigment{color White} }
light_source{<-50,50,-50> color 1}
camera{location -10*z}
Date: 11 May 2011 11:40:01
Message: <web.4dcaad398c9a231b3050e770@news.povray.org>
Thank you for posting your code.  My advisor wants me to switch from varible
scatter to varible IOR, so it should come in very handy.  I wish I had a 2500K
I7, Hex AMD's only can do so much :)
On the other hand, look what I did with varible scatter.
http://www.scivee.tv/node/29097
That's the magnetic field in ways it has never been seen before.  I did it with
about 300 lines of GPU cuda C code that makes the density files and povray that
displays them.  I feed a small job file to the cuda code that defines the
locations of the magnets, not unlike objects in povray.
Question, if there Povray coders out there that would like to collaborate and
merge my code into povray?
Being able to display magnetic/electric fields would be big plus for the
scientific community.  The packages that I know of, cost thousands of dollars,
and take clusters of computers.
I'm doing it with free 3.7 povray, a $200 hex core cpu and a $90 GPU.
Cuda is C based and I believe povray is C++ based, I am sure a good programmer
could merge the two, add some new type EM objects and be off the races in a
weeks time.
Quick question, is there anyway to generate density filenames based on the
clock?  I would like to have slightly different named density files for each
frame if it was possible.
Date: 11 May 2011 18:28:45
Message: <4dcb0d9d@news.povray.org>
It's good to have tools like that, but I think it's a
bit too specialized for a general raytracer. Things like
this might be better packaged as your own cool science
app that has an export mode for povray density files
and a sample scene for rendering.
You should be able to use a combination of concat()
and str() for that (see 3.2.1.7.4 string functions)
Date: 11 May 2011 22:57:02
Message: <4dcb4c7e@news.povray.org>
Here, you will have a serious problem. The provided code only work if
you have a thin object where you can assume the ior stays constant
across it's thickness.
In your case, you need an ior that will change in a volume.
Now, you can no longer merge the constituent boxes at it makes the
internal surfaces disapear. You also need to provide a tiny gap between
the boxes to prevent coincident surfaces artefacts. Also, any ray
parallel to an axis will always go straight through. You also can have
problems with total internal reflection whenever you attempt to exit a
box from any faces not parallel to that from whitch you entered it.
For a variable ior in a volume, you need to follow curved rays. Those
ray's curvature depends on the 3D gradient along it's path. With the
stacked boxes method, the gradient is always parallel to one reference
axis and perpendicular to the other two.
Also, the direction and curvature of that curve can change in a very
complexe way. That means, in a simple case, 100's of sample points along
the ray's path, each one of those points will need additional samples to
find the effective gradient.
A density file can no longer be used as you need a continuous
transition, while the density file have discreete values.
Anyway, I find it dificult to aprehend the reason why, in this case, you
may need to use variable ior.
Date: 12 May 2011 01:40:01
Message: <web.4dcb72468c9a2319726a3c10@news.povray.org>
I'll take a stab in the dark (matter) and guess gravitational lensing.
On a somewhat related note, I'm starting to wonder why scattering media seems to
be the go-to media for visualizing fields.  I've had good luck applying the much
less intensive emission media for this purpose to get a good look at some fairly
gnarly fractal-generating functions.
Date: 13 May 2011 22:11:12
Message: <4dcde4c0$1@news.povray.org>
Emissive media is visible by itself and is prety fast.
On a minus note, it don't self shadow. The result is that, if it gets
very thick or have a very high density, it's effect can become to large.
Scattering media behave more like most medias you encounter everywhere.
It requires some light source to become visible. It self shadow and
absorbs the light that illuminate it. It's also the slowest kind.
Then, some peoples use a combination of emissive and absorbing media.
The absorbing media will limit the contribution of the emissive one.
A few application of variable ior:
Gravitational lensing, can be simulated with a properly shaped lense.
Some substance having a non-uniform temperature or salinity. Heated air
over a flame; fresh water "floating" on sea water; some plastics, mostly
under stress; fiber optics...
The case of a magnet and it's field don't even come close to those
cases. Progressive lenses definetly don't use that, they use a complex
curvature.
Date: 14 May 2011 15:40:00
Message: <web.4dced9ac8c9a231512c758e0@news.povray.org>
Below is how I did the contours of functions that I was mapping.  I found that
if you can map a function to a volume of digital 1-255 values and create a
density file, you can then show the isopotential surfaces of the function in
question.
Matlab has problems doing this, but povray worked perfectly.  I wonder if we
could do the same thing with 3d stereoscopic rendering?
Is there a 3d glasses version of povray?
emission <1,1,1> / 210
      density {
         density_file df3 "tsqrt07j.df3"
         interpolate 1
        color_map {
 [0.01 rgb <0,0,0>]
        [0.03 rgb <0,0,1>]
 [0.05 rgb <0,0,0>]
        [0.07 rgb <0,1,0>]
 [0.09 rgb <0,0,0>]
        [0.11 rgb <1,0,0>]
 [0.13 rgb <0,0,0>]
        [0.15 rgb <0,0,1>]
 [0.17 rgb <0,0,0>]
        [0.19 rgb <0,1,0>]
 [0.21 rgb <0,0,0>]
        [0.23 rgb <1,0,0>]
 [0.25 rgb <0,0,0>]
        [0.27 rgb <0,0,1>]
 [0.29 rgb <0,0,0>]
        [0.31 rgb <0,1,0>]
 [0.33 rgb <0,0,0>]
        [0.35 rgb <1,0,0>]
 [0.37 rgb <0,0,0>]
        [0.39 rgb <0,0,1>]
        [0.41 rgb <0,0,0>]
        [0.43 rgb <0,0,1>]
 [0.45 rgb <0,0,0>]
        [0.47 rgb <0,1,0>]
 [0.49 rgb <0,0,0>]
        [0.51 rgb <1,0,0>]
 [0.53 rgb <0,0,0>]
        [0.55 rgb <0,0,1>]
 [0.57 rgb <0,0,0>]
        [0.59 rgb <0,1,0>]
 [0.61 rgb <0,0,0>]
        [0.63 rgb <1,0,0>]
 [0.65 rgb <0,0,0>]
        [0.67 rgb <0,0,1>]
 [0.69 rgb <0,0,0>]
        [0.71 rgb <0,1,0>]
 [0.73 rgb <0,0,0>]
        [0.75 rgb <1,0,0>]
 [0.77 rgb <0,0,0>]
        [0.79 rgb <0,0,1>]
        [0.81 rgb <0,0,0>]
        [0.83 rgb <0,0,1>]
 [0.85 rgb <0,0,0>]
        [0.87 rgb <0,1,0>]
 [0.89 rgb <0,0,0>]
        [0.91 rgb <1,0,0>]
 [0.93 rgb <0,0,0>]
        [0.95 rgb <0,0,1>]
 [0.97 rgb <0,0,0>]
        [1.00 rgb <1,1,1>]
Hi Alain,
2d plane IOR is fine, I was exploring the 3d volume data but my real world
expermient is based on a 2d magnetic lens (very thin layer of ferrofluild).
Dark matter and lensing would be easier.
Thank you y'all,
Michael
http://www.aps.org/about/physics-images/heleshaw.cfm
Date: 15 May 2011 05:02:08
Message: <4dcf9690$1@news.povray.org>
Am 14.05.2011 21:38, schrieb sirzerp:
No; but it /can/ be used to produce stereoscopic output, as some guys
occasionally demonstrate in povray.binaries.images now and again.
