POV-Ray : Newsgroups : povray.newusers : camera orbit with simultaneous image plane rotation Server Time
7 Jun 2025 17:32:30 EDT (-0400)
  camera orbit with simultaneous image plane rotation (Message 1 to 10 of 14)
Subject: camera orbit with simultaneous image plane rotation
Date: 14 Jan 2011 02:45:00
Message: <web.4d2ffe3cb3460c10c6ac940d0@news.povray.org>
I am using povray to generate projections of anatomical structures derived from
a DICOM RT Structure Set. In essence I need to simulate a camera orbit about
each structure - in fact I rotate the structure using the clock parameter and
keep the camera fixed. These projections are the precursor to defining radiation
fields in radiotherapy and the camera represents a linear accelerator used for
the treatment.
I now need to make my simulation more general by allowing for camera roll, i.e.
rotation of the image plane (anti)clockwise about look at vector see
http://wiki.povray.org/content/Documentation:Reference_Section_3#Placing_the_Camera
povray -D mlc[Synergy]+Q0 +KFF90 +I/home/twostepgen/PTV0_0.pov i.e. 90
projections in orbit mlc[Synergy] defines image plane dimensions
PTV0_0.pov
#include "/home/twostepgen/PTV0.inc" - a mesh2 object
   perspective
   location <0 100 0>
   up <0,0,-1>
   right <-1.33,0,0>
   angle 11.9882
   look_at <0 0 0>
rotate -z*(178+(clock*-356))
 light_source { <0,10,0> color rgb 1 }
object{PTV0 translate <0.775167,-18.0811,7.82013e-05>}
translate is used to ensure that the "looked at" point is located at coordinates
0 0 0
In particular there are some instances where I need a constant roll angle for
all projections along the entire orbit. In other instances I need to adjust the
roll angle from one clock "tick" to the next. What is the most
efficient/simplest way of doing this?
Many thanks
Mark
Subject: Re: camera orbit with simultaneous image plane rotation
Date: 14 Jan 2011 12:58:57
Message: <4d308ee1@news.povray.org>
> Hi,
> the treatment.
> PTV0_0.pov
> camera {
>     perspective
>     location<0 100 0>
>     up<0,0,-1>
>     right<-1.33,0,0>
>     angle 11.9882
>     look_at<0 0 0>
>   light_source {<0,10,0>  color rgb 1 }
> object{PTV0 translate<0.775167,-18.0811,7.82013e-05>}
> 0 0 0
> Many thanks
> Mark
You can change your rotation as:
rotate <0, 90*clock, -178+(clock*360)>
and use +kc to set the clock to cyclical animation.
This will first rotate the camera around the Y axis, then rotate it
around the Z axis.
The result is a camera that smoothly rotate around the 2 axis during the
animation.
You can use something like:
int(30*clock)*12
To rotate in 12 degrees increments, doing a complete rotation in 30 steps.
Date: 17 Jan 2011 05:40:00
Message: <web.4d341344863e0b1cc6ac940d0@news.povray.org>
Ok, it seems that I did not clearly define my problem. I have to simulate two
general situations; firstly where the camera is at a fixed roll angle, say 15
degrees for all positions along the orbit: rotate <0,15,(-178+clock*360)> ??
Secondly the more general case I need to adjust the roll angle between clock
ticks by a variable amount, e.g. a typical sequence of roll angles for 15 clock
ticks would be 0,1,3,5,7,5,3,1,0,1,3,5,7,5,3. Thus I would probably need to
provide a file or parameter list containing the roll angles that are (somehow?)
substituted into the .inc file at runtime. Alternatively I would need to avoid
the full orbit (rotate keyword) and write 15 discrete projections which simulate
the desired roll angles
Mark
> around the Z axis.
> animation.
> int(30*clock)*12
> Alain
Date: 17 Jan 2011 13:59:08
Message: <4d34917c$1@news.povray.org>
>> rotate<0, 90*clock, -178+(clock*360)>
> degrees for all positions along the orbit: rotate<0,15,(-178+clock*360)>  ??
> Mark
In that case, you can use an array that will contain your various rotations.
#declare Roll = array[16] {0,0,1,3,5,7,5,3,1,0,1,3,5,7,5,3}
This create the array and initialize it in one operation.
The element zero (first) can be used for single frame renderings, while
the others will be used during an animation.
You ther access the elements like this:
Roll[frame_numnber]
Outside an animation, this internal variable evaluate to 0 (zero), and
to non-zero during an animation.
This can be used as a rotation or the actual locations for your camera.
It can also define the up, right, direction or sky vectors.
Note that the array can contain vectors that can be used normaly:
#declare Roll =  = array[15]
{0,<0,20,-2>,<1,12,12>,3,<-5,5,5>,7,5,3,1,0,1,3,5,7,5,3}
The singles floats will be promoted to full vector status: 7 becomes
<7,7,7>.
More advanced: You can use the spline feature. Please read the
documentation about the implementation and use of the splines.
This can be somewhat overkill for what you want to acomplish.
Date: 18 Jan 2011 08:50:01
Message: <web.4d359962863e0b1cc6ac940d0@news.povray.org>
This sounds very promising. Since I am generating scripts to execute the
raytracing with povray I would then only need to determine whether the roll
angle is fixed or variable, based on user input.
> Roll[frame_numnber]
Could you please give me more detailed syntax, or a reference to the relevant
manual /wiki page, on how to implement this. Thanks.
> <7,7,7>.
> Alain
Date: 18 Jan 2011 09:11:45
Message: <4d359fa1$1@news.povray.org>
 From the help
3.3.1.1.2 The Sky Vector
frame_numnber:
3.2.1.3.6 Built-in Variables
Using frame_numnber requires you to do a bit of arithmetic to get a
meaningful number,
For instance: 1 - (final_frame - frame_numnber)/final_frame
Regards
Date: 18 Jan 2011 09:38:10
Message: <4d35a5d2$1@news.povray.org>
P.S.
debug -- 3.2.2.7.1 Text Message Streams
concat(S1,S2,...), str(A,L,P) -- 3.2.1.7 Strings
Are useful for checking that you have got your maths right.
Regards
Date: 18 Jan 2011 22:37:20
Message: <4d365c70$1@news.povray.org>
>> Roll[frame_numnber]
Some samples:
#declare Value = Array[Some_Integer];
camera{location Array[Some_Integer1]
  look_at Another_Array[Some_Integer2]
  rotate Array_Of_3D_Vectors[Some_integer3]
  angle A_Fourth_Array[Some_Integer4]
} // extreeme example where most of the camera's parameters are
  // defined using arrays.
For the windows version documentation:
3.2.1.8 Array Identifiers
General online documentation:
http://www.povray.org/documentation/view/3.6.1/233/
Date: 18 Jan 2011 22:44:33
Message: <4d365e21$1@news.povray.org>
>> relevant
>  From the help
Changing that vector is one way to tilt the camera in some way. It's a
3D vector that defaults to <0,1,0>.
> frame_numnber:
> meaningful number,
It depends on what you want to acheive.
If you need an integer value that depends ONLY on the actual
frame_number and is independent on the clock value, there is NO
arithmetics to perform. It also assume that your animation is made to
use only a fixed number of frames.
Your suggestion is only needed if, for some reason, you want to
substitute frame_number for places suited for the clock variable.
Date: 19 Jan 2011 04:10:00
Message: <web.4d36aa5b863e0b1cc6ac940d0@news.povray.org>
Ok. I naively thought (hoped!) the following would work, but apparently not:
// here is the array of camera roll angles - angles are exaggerated for effect
#declare cameraRoll= array[15]
{10,20,30,40,50,60,70,80,90,100,110,120,130,140,150}
   perspective
   location <0 100 0>
   up <0,0,-1>
   right <-1.33,0,0>
   angle 11.9882
   look_at <0 0 0>
// attempt to insert the cameraRoll angle into the rotation orbit
rotate <0,cameraRoll[clock],-(178+(clock*-356))>
However this naive approach does not work. All rotation angles appear to be at
10 degrees i.e. cameraRoll[1]. It seems that I cannot use the rotate in this
way.
> Some samples:
> Alain
