POV-Ray : Newsgroups : povray.newusers : output file Server Time
19 Nov 2025 00:53:14 EST (-0500)
  output file (Message 1 to 7 of 7)
Subject: output file
Date: 17 Nov 2009 16:00:00
Message: <web.4b030ec2fb2de8d4cfad7b660@news.povray.org>
Thanks for all your help, I have finished my image however the output bitmap
becomes a bit blocky when I zoom in. I have rendered it at the highest possible
setting and it looks really good in the render window. Is there a way of
changing the output file to fix this?
Thank you
Subject: Re: output file
Date: 17 Nov 2009 16:15:18
Message: <4b031266$1@news.povray.org>
> bitmap
> possible
That's what anti-aliasing is for, try the standard AA settings,
or use something slower like +am2 +a0.1 +r4. As a last
resort you can add custom render sizes to quickres.ini and
render the whole image larger.
Date: 17 Nov 2009 17:47:30
Message: <4b032802$1@news.povray.org>
> Thank you
The highest setting in the drop-down is not the highest setting
possible, it's only the highest default preset.
In the text box next to the resolutions list, you can enter "command
line" switches.
You can use +wnn and +hnn to use user provided width and height for your
renders. For example, "+w3200 +h2400" will render an image at a
resolution of 3200x2400 pixels.
You can use +a0.n to set the antialiasing threshold. Smaller value will
result in smoother result, but will increase the rendering time.
You can add more resolutions: If you use the windows version, in the
menu, item "Tools", sellect "Edit resolutions INI file" and create new
sections similar to the ones already present. The part between the
square brackets "[" and "]" is what you will see in the menu. The part
under that contains the actual parameters.
If you render at a high resolution like the example, you'd be advised to
change the file format from bit-map (default under windows,
uncompressed) to PNG (lossless compressed) by using the "+fn" switch.
Otherwise, the resulting file will get prohibitively huge.
Date: 18 Nov 2009 04:45:00
Message: <web.4b03c2184c0fbec9bb1d6280@news.povray.org>
> > Thank you
> line" switches.
> Alain
I didn't know you could increase the resolution from the defaults so thanks for
that info. I did however find the +fn info in the help manual but I don't know
where to put it. I tried putting it in the code for the picture but it showed it
as an error is this not where it is meant to go or am I typing something wrong?
Sorry I'm not very technical minded
Thanks
Date: 18 Nov 2009 05:08:25
Message: <4b03c799@news.povray.org>
"colaroid" <col### [at] hotmailcom> wrote in message
news:web.4b03c2184c0fbec9bb1d6280@news.povray.org...
> thanks for
> know
> showed it
> wrong?
> Thanks
+fn is a command line switch .... check out for some background:
http://wiki.povray.org/content/Documentation:Tutorial_Section_2.2#Setting_POV-Ray_Options
then have a look at the refernce beginning here:
http://wiki.povray.org/content/Documentation:Reference_Section_1#Command-line_Options
+fn is covered here:
http://wiki.povray.org/content/Documentation:Reference_Section_1.1#File_Output_Options
Jim
Date: 18 Nov 2009 07:30:32
Message: <4b03e8e8$1@news.povray.org>
> Thanks
Just to confuse you with information overload ;) You can put all these
settings in an INI file which can call the Pov file. See in the
documentation 1.2.5.2  INI Files and 2.2.8.2  Using INI Files.
Best Regards,
Date: 18 Nov 2009 12:15:23
Message: <4b042bab$1@news.povray.org>
> Thanks
You put the command line options in the area marked as "Command line box"
You also can put it in the main INI file. Menu->Tools->Edit master
povray.ini
Just put it alone on a new line and save the file.
If you do that, then ALL your rendered images will be saved as PNG files
/unless/ you disable file output or force it to another file type.
Download 'command-line.jpg' (14 KB)
Preview of image 'command-line.jpg'
