POV-Ray : Newsgroups : povray.newusers : shinyness Server Time
14 Aug 2025 04:05:22 EDT (-0400)
  shinyness (Message 1 to 8 of 8)
Subject: shinyness
Date: 5 Nov 2009 11:15:01
Message: <web.4af2f8aaacc0365abb1d6280@news.povray.org>
How do you make an object look really shiny, basically I want a gold box to go
into a picture and all Im achieving is a dull brown colour (with the gold
pigment)? I have tried phong and finish methods but I am clearly doing something
wrong!
Subject: Re: shinyness
Date: 5 Nov 2009 11:30:01
Message: <web.4af2fcb91902ed1c86ff1d480@news.povray.org>
> wrong!
Try using specular and/or reflection in your finish block, e.g.:
finish {
   specular 1 roughness 0.01
   reflection {0, 0.25 fresnel on} conserve_energy
(And if using reflection make sure you have something in your environment to
actually reflect)
Date: 5 Nov 2009 11:34:27
Message: <4af2fe93$1@news.povray.org>
> wrong!
Reflection!
What you really need for shiny things is something they can reflect.
Highlights alone won't do (and they're particularly poor with objects
that don't have any curved surfaces or beveled edges).
Date: 5 Nov 2009 12:31:06
Message: <4af30bda@news.povray.org>
> wrong!
  There's a trick with specular highlights which most people don't realize:
Use a very large specular setting (larger than 1, eg. 3 or 4) and adjust
roughness until it looks good (usually try to make the highlights smaller
in size). This works especially good for glass surfaces. You can combine
this with a more moderate larger phong highlight as necessary (depending on
how plastic you want it to look).
  The ultimate technique to get realistic shiny surfaces is, however, to use
a HDRI environment image (with megapov or pov 3.7) and some amount of
reflection on the object finish.
Date: 5 Nov 2009 15:26:57
Message: <4AF33560.6000602@joplin.com>
> wrong!
Where's your Light?
Bad lighting can cause all kind of problems.
Date: 5 Nov 2009 23:02:57
Message: <4af39ff1$1@news.povray.org>
> wrong!
Some way to do that:
Adding some reflection.
With the reflection, you need something to reflect, so, you need to add
some environment.
Carefull placement of the light(s). Works with...
Use phong (with phong_size) ou specular (with roughness) highlight.
Good with rounded shapes, much less with mostly flat surfaces and sharp
edges. Don't work with ambient "lights".
For metallic textures, add the keyword "metallic" in the finish.
metallic will colour the highlight the colour of your pigment.
Most metals have roughly constent reflection, independent on the angle:
use a single component reflection. metallic in the reflection block will
tint the reflected things acording to the pigment.
sample: reflection{0.3 metallic}
Experiment with "briliance". It takes a float value. Any positive value
is possible. "Standard" metallic textures mostly have brillance larger
than 1.
Date: 6 Nov 2009 04:30:00
Message: <web.4af3ebc91902ed1cbb1d6280@news.povray.org>
> > wrong!
> some environment.
> than 1.
> Alain
Thanks for all the answers, I did think it was possibly due to a lack of things
to reflect so I put an extra plane in, I think I need real objects there. I will
have a go at all of your suggestions.
Date: 6 Nov 2009 11:32:39
Message: <4af44fa7@news.povray.org>
>>> wrong!
>> some environment.
>> than 1.
>> Alain
If you use a simple plane, don't use a simple pigment, but a texture.
That texture can be scaled somewhat large or small depending on your
taste and the particularty of your main object.
