POV-Ray : Newsgroups : povray.newusers : Rendering voxel-style functions in Povray Server Time
19 Nov 2025 00:53:12 EST (-0500)
  Rendering voxel-style functions in Povray (Message 1 to 10 of 13)
Subject: Rendering voxel-style functions in Povray
Date: 6 Sep 2009 11:20:00
Message: <web.4aa3d30f666353bc813aa4820@news.povray.org>
Hi all, I need to be able to render arbitrary functions easily. In other words,
the following function would draw a sphere by checking a giant 3D grid of
say... 100x100x100 voxels to check if the point is in the sphere:
// Check through multiple x, y and z voxels to draw a sphere:
bool sphere(float x, float y, float z) {    // x, y and z are normalized to 1 or
less.
 float f = sqrt(x^2 + y^2 + z^2)
 if (f<1.0) return 1; // Part of sphere
 else return 0;  // Not part of sphere
Is this easy to do in Povray or maybe some other 3D software? An equivalent to
voxels would be to trace rays to see if it intercepts the function. Either way
is fine as long as a sphere is produced from the above 'code'/function.
Subject: Re: Rendering voxel-style functions in Povray
Date: 6 Sep 2009 12:20:00
Message: <web.4aa3e10c19a8cf54958421d50@news.povray.org>
There are a couple options.  I would probably recommend isosurfaces if you don't
actually NEED the grid representation.  It just boils down to a root-finding
problem.  That means you can specify an arbitrarily complex function without
the need for grids.  I won't go into much detail since others have said it
better:
http://www.povray.org/documentation/view/3.6.0/73/
If you do need a voxel representation, then df3 is the way to go.  Again, the
following page gives an excellent description.  You can also use it to create
surfaces (i.e. not just volume-rendering), but unless you need more detail
here, I won't get carried away.
http://local.wasp.uwa.edu.au/~pbourke/miscellaneous/df3/
 - Ricky
Date: 6 Sep 2009 13:35:00
Message: <web.4aa3f1f519a8cf54813aa4820@news.povray.org>
> better:
Hi Ricky, thanks. That page has a sphere function which is very similar to mine
- great stuff.
My only concern is that an isosurface won't be able to support the colour of
each bit of the 3D object. With my function I originally posted, one may be
able to say that for each x/y/z 'voxel', to do some extra processing to
determine the colour for that bit of object (say based on how its y position or
something). Is that not possible with the isosurface approach?
Date: 6 Sep 2009 14:27:28
Message: <a0FMk$Bc5$oKFwC0@econym.demon.co.uk>
>>if you don't
>> better:
>- great stuff.
You can do that with any type of object, just use a pigment function.
http://www.econym.demon.co.uk/isotut/pigfun.htm
Mike Williams
Gentleman of Leisure
Date: 6 Sep 2009 15:20:00
Message: <web.4aa40a5719a8cf54813aa4820@news.povray.org>
Many thanks! I'm guessing other attributes such as variable
translucency or specularity throughout the surface of the material
can be set as well.
Date: 6 Sep 2009 16:10:32
Message: <uaPhP5AxcBpKFwOW@econym.demon.co.uk>
>can be set as well.
Specularity is tricky. The specular value of any individual texture is
constant, so if you want to vary the specularity you have to use more
than one texture combined in a texture map. See the recent "specular
texture" thread in this group but use a function instead of
image_pattern to blend them.
Mike Williams
Date: 9 Sep 2009 10:20:01
Message: <web.4aa7b81019a8cf54813aa4820@news.povray.org>
Cheers. I may have come across a hurdle or two. I'm going to quote someone from
an email - I'm sure they won't mind:
> The problem is there's no way to incorporate while loops and local
> variables into POV-Ray's isosurface functions. Basically, there are
> functions and there are macros in POV-Ray. Macros can incorporate
> while loops and local variables, but functions cannot. But,
> isosurfaces can only be created using functions.
Is this planned for a future version of POVray?
Date: 9 Sep 2009 12:07:39
Message: <4aa7d2cb@news.povray.org>
web.4aa7b81019a8cf54813aa4820@news.povray.org...
I am not an expert but I think it is not like you just had to want it :-/
Maybe one day if Santa joins the POV-team ... :-)
Marc
Date: 9 Sep 2009 12:34:51
Message: <4aa7d92b$1@news.povray.org>
The answer is a threefold "yes/no/maybe".
"Yes" because there has been some discussion whether POV-Ray 4.0 should
be equipped with a brand-new SDL, and in that case, whether it might be
some bytecode-based language that could be used for scene scripting and
functions alike.
"No" because isosurface functions would probably still be subject to
major restrictions, or they might screw up the intersection-finding
algorithm and/or totally kill performance.
"Maybe" because the people to actually have any say in it did not, to my
knowledge, participate in the discussion, so their opinion on this is
currently an unknown variable. There seems to be consensus that the SDL
should get a major overhaul, but to what degree is not yet clear.
Date: 13 Sep 2009 08:55:01
Message: <web.4aaceb7f19a8cf54813aa4820@news.povray.org>
> functions alike.
Thanks. Until then, is there another 3D renderer I can try out which allows
local vars and while loops inside functions like this?
