POV-Ray : Newsgroups : povray.newusers : specular color ? Server Time
23 Feb 2025 12:55:18 EST (-0500)
  specular color ? (Message 1 to 10 of 12)
Subject: specular color ?
Date: 7 Aug 2009 12:05:01
Message: <web.4a7c501250c3f6d968fad440@news.povray.org>
Is there a way to color the highlights of an object in Povray except the metalic
keyword? be it by feeding a simple color vector or a color map? (if some one
knows blender or max it's the same as putting a single specular color or a ramp
in the specular texture channel)
Subject: Re: specular color ?
Date: 7 Aug 2009 12:41:55
Message: <4a7c5953$1@news.povray.org>
A multi-layered texture should to the trick I guess, with the top layer
defined with the desired highlight color, tramsit 1 and metallic, and
the lower layer defined without specular highlights.
Didn't test it though.
(Of course this uses the metallic keyword as well, but I reckon your
question wasn't strictly about avoiding that keyword, but having a
highlight color different from the diffuse color.)
Date: 7 Aug 2009 12:42:13
Message: <4a7c5965$1@news.povray.org>
> keyword?
Yes, with a non-white (local, if needed) light source.
Date: 7 Aug 2009 12:53:59
Message: <4a7c5c27$1@news.povray.org>
Thorsten Froehlich schrieb:
>> the metalic
>> keyword?
That also affects the diffuse color.
Date: 7 Aug 2009 13:30:01
Message: <web.4a7c644db6985f655a057ffa0@news.povray.org>
Unfortunately not.  For a while I was trying to simulate it with the aoi
pattern, but I couldn't quite get the maths right for making the pattern match
the light.  This is something I wouldn't mind seeing, along with the ambient
keyword accepting a full rgbft vector.
-Reactor
Date: 7 Aug 2009 13:43:34
Message: <4a7c67c6$1@news.povray.org>
What good would *that* do?
Date: 7 Aug 2009 14:50:00
Message: <web.4a7c7645b6985f655a057ffa0@news.povray.org>
If you wanted a ghostly object that was only visible when out of direct light,
or a distant moon-like object that has transparent unlit parts, or something
similar.
-Reactor
Date: 7 Aug 2009 15:20:57
Message: <4a7c7e99@news.povray.org>
> similar.
> -Reactor
You mean something like this?
     pigment { color red 0 green 1 blue 0 transmit 0.999 }
     finish { diffuse 0 ambient 1000 }
If that doesn't do what you're thinking of, then a "full rgbtf vector"
ambient wouldn't help you either.
Also note that the construction you're thinking of would require special
parsing of the parameter following the "ambient" keyword (or break
compatibility): As of now, ambient *always* applies filter and transmit,
but it's taken from the pigment, while what you want would be an
independent filter and transmit parameter specifically for ambient. As
from the parser's point of view, "rgb <1,1,1>" is perfectly equal to
"rgbft <1,1,1,0,0>", this would conflict with the standard use case.
Date: 7 Aug 2009 16:10:00
Message: <web.4a7c8995b6985f65abe8d88c0@news.povray.org>
Yes exactly what I need (I'll have to test it later), and if I want a specular
gradient I can also put other such specular layers with different colors and
roughness/Phong_Size I hope too much of this won't slow down the material too
much, but I guess not since it's only specular, not reflection... I was only
surprised that indenting a color_map under phong or specular wasn't built-in :)
I don't mind such workarounds, they're a really good mind training for me!
You're teaching me a lot these days clipka, thanks. and to the others too very
responsive group. I'll continue stealing your time a little.
Date: 7 Aug 2009 18:25:00
Message: <web.4a7ca96eb6985f654646012a0@news.povray.org>
No, and judging from that code sample, I've done a poor job of describing the
effect.
That doesn't sound good, but I made an image that shows more of what I had in
mind.  I posted it in p.b.i here:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4a7ca1d884f249fd4646012a0@news.povray.org%3E
 The way I understood things, the diffuse keyword controls the texture's amount
of response to light sources.  When checking to see whether or not an object is
lit, the surface normal is checked (to see if the object is facing the light
source).  From my understanding, if we thought of the normal direction as
compared to the light source as returning a percentage of illumination, then
the diffuse would multiplied by that percentage, and the ambient value would be
added (on an rgb component basis).  Assuming this is correct, I was wondering
whether or not the diffuse or ambient component could be full rgb vectors, and
have a filter and transmit value that is taken into account as well.  I'm
probably doing a mediocre job of describing an idea that is based on a poor
understanding of the lighting computations, so hopefully the image will clear
things up.
Anyway, I didn't mean to thread hijack - this started as a well intentioned
gripe about either limitations in controlling the way an object responds to
light, or my limitations in understanding how to control the way an object
responds to light.
-Reactor
