POV-Ray : Newsgroups : povray.newusers : Light Source Maximum Brightness? Server Time
28 Sep 2024 18:13:07 EDT (-0400)
  Light Source Maximum Brightness? (Message 1 to 7 of 7)
Subject: Light Source Maximum Brightness?
Date: 14 Feb 2009 17:55:01
Message: <web.49974bb74c68a7e7b148ecf60@news.povray.org>
Hello,
I have two light_sources for each floor in a 2-story building.
I want to set a maximum illumination number (so an area that receives amount of
light past this number will not be brighter than this number) so that
the area of the building that receives light from both light_sources will not be
so bright compared to rest of the building.
Here's the code:
light_source {<30,96,50> White}
light_source {<30,49,50> White}
camera {location <50,90,-100> look_at <50,50,20>}
background {White}
//////////////// radiosity ////////////////////
  global_settings {
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.01
      count 100
      nearest_count 5
      error_bound 1
      recursion_limit 1
      low_error_factor 0.5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness .5
      adc_bailout 0.01/2
////////////////////////////////////////// two - floor Building
               /// main frame///
#declare Main_Frame =
difference{
box {<0,0,0><100,100,100>}
box {<3,3,3><97,97,97>}
            /// floor separator  or just 2nd floor///
#declare Second =
difference {
box {<0,50,0><100,53,100>}
box {<50,49,100/3><90,54,90>}
          ///////// Main Frame + 2nd Floor /////////
#declare Building =
merge {object{Main_Frame} object{Second}}
          ////////// Cross Section of the Building ///////////
difference {
object{Building}
box {<-1,-1,-1><101,101,4>}
texture { finish {ambient .5}
pigment {color Gray75} }
Subject: Re: Light Source Maximum Brightness?
Date: 14 Feb 2009 18:30:01
Message: <web.499753af90d0d596ef2b9ba40@news.povray.org>
The standard model for lights is not physical since it does not take into
account that light intensity fades with the square of distance.  To fix the
problem, I changed it to:
light_source {<30,96,50> White fade_power 2 fade_distance 30}
light_source {<30,49,50> White fade_power 2 fade_distance 30}
although you can certainly change the distance.  By the time the light gets to
the lower floor it has faded, but still illuminates the top floor.
 - Ricky
Date: 15 Feb 2009 00:30:00
Message: <web.4997a84190d0d5967c859cee0@news.povray.org>
>  - Ricky
This certainly does the job I wanted to darken the part where both light sources
illuminate.
But do you know the answer to my second question?
Is there a way to define maximum amount of brightness of an object?
I guess I'll just have to use diffuse, but I was wondering if I can just
set a cap instead of using things that'll make it darker at a rate.
Thanks for the solution by the way.
Date: 15 Feb 2009 01:05:00
Message: <web.4997afe790d0d596ef2b9ba40@news.povray.org>
> illuminate.
I do not know.  Two alternatives would be to add an ambient finish to brighten
the shadows and require less light, or use radiosity to bleed the colors
together a little.  You could also just move the lights a little farther from
the wall so you don't get such a spike in brightness.  As I said though, I
don't happen to know that it's not possible, but neither am I aware that it is.
 - Ricky
Date: 15 Feb 2009 14:35:21
Message: <49986e79$1@news.povray.org>
Actually you didn't ask two questions, you said you wanted to cap
the brightness "so that" you could get rid of the problem with the
doubly illuminated area. triple_r gave you the physically correct
way to solve that problem instead. So, is there another reason
you want to cap the brightness to some absolute value? Likely
there is a better solution for whatever you wish to achieve.
Date: 15 Feb 2009 22:55:00
Message: <web.4998e31390d0d5967c859cee0@news.povray.org>
Well there was one question literally.
Triple_r's answer was sufficient, but I am still curious
if there's a way to define it. I guess not..
Date: 16 Feb 2009 13:40:10
Message: <4999b30a$1@news.povray.org>
sam kim nous illumina en ce 2009-02-14 17:54 -->
> Hello,
> Here's the code:
> background {White}
>   global_settings {
>     radiosity {
>       pretrace_start 0.08
>       pretrace_end   0.01
>       count 100
>       nearest_count 5
>       error_bound 1
>       recursion_limit 1
>       gray_threshold 0.0
>       minimum_reuse 0.015
>       brightness .5
>       adc_bailout 0.01/2
>                /// main frame///
> difference{
> #declare Second =
> difference {
> #declare Building =
> difference {
> object{Building}
As you use radiosity, you should set ambient to zero UNLESS you want that part
of the scene to actualy emit light.
Use fade_distance <some distance> and fade_power 2 to get realistic light fading
acording to the distance. By default, ther is no fading.
As this is a radiosity scene, you can limit the maximum contribution to
radiosity effects.
For that, you use the "max_sample" key word. Objects that are brighter than the
specified value get ther brightness reduced to the provided value keeping the
original hue. Please read the radiosity section in the documentation.
You know you've been raytracing too long when you've ever "lost" a Julia fractal
because you're not quite sure how to align things in four dimensions.
Dylan Beattie
