POV-Ray : Newsgroups : povray.newusers : Need help with POV-Ray !! Server Time
14 Mar 2026 01:54:45 EDT (-0400)
  Need help with POV-Ray !! (Message 1 to 10 of 28)
Subject: Need help with POV-Ray !!
Date: 15 Aug 2007 06:55:00
Message: <web.46c2da8ebc1e6cbb99fead9e0@news.povray.org>
im very new to POV-Ray and I have an assignment which is due next month.
I want to make an image of a photo something like this,
http://www.dskendall.com/images/199812.jpg
Can anyone help me get started? Is it a difficult task to do?
Thanks!
Subject: Re: Need help with POV-Ray !!
Date: 15 Aug 2007 09:06:40
Message: <46c2fa60@news.povray.org>
>Thanks!
Well, it looks to me as though there are three main parts to the image:
the sky, the mountains, and the shrub-covered plain.  I would recommend
starting with a "quick and dirty" approach to each part and then adding
detail and realism as you go along (and as you learn more about using POV).
For example, you might start by making a sky_sphere that's about the
same color as the sky in the image. Then you could add a tan-colored
plane and make "placeholders" for the mountains (probably unevenly
scaled spheres to start with).  Get everything laid out so that the
objects and camera are positioned about the way you want them, THEN
start working on detail.  One advantage to this type of "top down"
approach is that, when the deadline arrives, you've got, at the very
least, a "sort of finished" project, instead of just bits and pieces. ;)
After you've got the scene laid out, you'll probably want to study up on
the height_field object for making the mountains.  There are include
files (and also third-party programs) available that are very useful for
making shrubbery, and also info on several ways of making a realistic sky.
Hope this helps a bit.
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 15 Aug 2007 11:15:00
Message: <web.46c3175d4683e64799fead9e0@news.povray.org>
Thanks for helping me, but I dont understand a few stuff :(
What do you mean by "placeholders" ? Is it making the spheres and shaping
them to mountains later on??
And what are height_field object ?
Date: 15 Aug 2007 12:01:16
Message: <46c3234c$1@news.povray.org>
My advice is to read the Povray intro here:
http://povray.org/documentation/view/3.6.1/13/
and here:
http://povray.org/documentation/view/3.6.1/58/
(The height field is explained in "Advanced Features", 1.3.3.2.)
William Tracy
afi### [at] gmailcom wtr### [at] calpolyedu
You know you've been raytracing too long when you see something in the
real world and you think, "Hey! How did they get that effect?"
Date: 15 Aug 2007 12:23:20
Message: <46c32878@news.povray.org>
web.46c3175d4683e64799fead9e0@news.povray.org...
Don't worry, you'll get help here :-)
Nope placeholders are object meant to be replaced later by more accurate
objects.
In this case, the rocks can be very roughly faked by unevenly scaled
spheres, then by a height_field.
Now the difficulty of making an image looking like the photo depends on how
accurate and realistic you want it to be.
Marc
Date: 15 Aug 2007 12:25:00
Message: <web.46c3285c4683e64739928d3a0@news.povray.org>
Hey k1s3k1-
What Sherry is suggesting is that you cant start from the roughest, most
"approximate" quality of this image and improve the realism from there.
So, for instance, the most basic way of drawing this scene is to use a blue
sky_sphere, a tan plane for the ground, and brown or red spheres for the
mountains. These "placeholders" can be used to adjust the position of the
camera and to make sure that you have these major elements arranges as you
want them. Then you can work to improve each element, and replace the
"placeholders" with the finished objects.
Height_fields are explained in the tutorial section 3.3.2. As a new user
myself (I've only been using POV for about 3 months) I would highly
recommend working through the tutorial document. It gives a good
introduction to the capabilities of POV and how to use them to produce
various things.
Good luck, hope that helped!
-OpalPlanet
Date: 15 Aug 2007 12:35:00
Message: <web.46c32af74683e64799fead9e0@news.povray.org>
so far, this is what i have made
http://img338.imageshack.us/img338/6116/testzm4.png
is that okay for the sky and plain?? or is it wrong??
please give me suggestions in order to improve on it :D
Date: 15 Aug 2007 12:50:00
Message: <web.46c32dc34683e64739928d3a0@news.povray.org>
Looks good to me! The ground seems to be a little too orange... maybe more
brown?
-OpPl
Date: 15 Aug 2007 12:52:02
Message: <46c32f32@news.povray.org>
> brown?
  It's not like orange ground doesn't exist...
http://www1.istockphoto.com/file_thumbview_approve/2265232/2/istockphoto_2265232_vineyard_rows_orange_ground_blue_skye.jpg
:P
Date: 15 Aug 2007 13:05:00
Message: <web.46c330fb4683e64739928d3a0@news.povray.org>
> > brown?
> :P
True, I was just comparing it with the image that k1s3k1 posted to begin
with... :-)
-OpPl
