POV-Ray : Newsgroups : povray.newusers : Memory parse error Server Time
27 Mar 2026 12:17:25 EDT (-0400)
  Memory parse error (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Memory parse error
Date: 13 Aug 2006 00:10:00
Message: <web.44dea5293fb029be524472e50@news.povray.org>
How do I make the'tweaks' to the system's virtual memory?
> Personaly, I don't know, other than setting it's total volume. Other peoples
> have mentioned it.
I created the model in a 3D CAD program called MLCad and converted it to POV
format with another called L3P. This works very well on smaller files, but I
have hit a celing at 4.5MB. So I don't know very much about the code
contained within the file itself, only that the 4.5MB file has over 10,000
lines of code, many of which seem to repeat themselves. This would be a
mess to streamline, so fixing my memory capacity is the only practical
solution I can think of. Any more advice you may have would be greatly
appreciated!
Thanks,
  Michael
Date: 13 Aug 2006 12:26:20
Message: <44df52ac@news.povray.org>
"Mike8" <nomail@nomail> wrote in message
news:web.44dba7fbd8ca351dbca05e450@news.povray.org...
> Hello,
>  I haven't posted before, so please bear with me. I've been using pov-ray
> for several months, and I have encountered a recurring problem. When I try
> to render any file larger than 6 Megabytes the renderer says 'parse error
> could not allocate 256 bytes for transform' and the render aborts. The
> largest file I need to render is 20MB. I am running POV-Ray 3.6 on Windows
> XP pro, with 1 Gigabyte of RAM, and I increased my virtual memory to 20GB,
> with no effect. Is there anything I can do or am doing wrong?
   Hi Michael
     I may be wrong here, (it's a long shot), so please forgive me if I am,
but it's worth a try as I too have had problems with a 1 gig system whereby
I can't open one of my favourite image editing programs unless I do this.
When you go into your VM dialogue box in Control Panel, use the 'Custom
size' option and enter in the 'Initial size' field: 2024.
   In the 'Maximum size' field, enter: 4048 and restart your comp.
   Again, not sure if it will work, but anyway, good luck.
    ~Steve~
>  Michael
Date: 13 Aug 2006 14:45:01
Message: <web.44df727e3fb029bebca05e450@news.povray.org>
>    Hi Michael
>     ~Steve~
No effect. Thanks anyway, it was worth a shot. I wish to correct an
inaccurate statement that I made earlier: the file I'm having trouble with
isn't 10,000 lines of code, it's 235,225 lines. That might make a slight
difference.
Thanks again,
   Michael
Date: 13 Aug 2006 16:10:51
Message: <44df874b@news.povray.org>
news:web.44df727e3fb029bebca05e450@news.povray.org...
> "St." <dot### [at] dotcom> wrote:
>>    Hi Michael
>> am,
>> whereby
>>     ~Steve~
> difference.
      Gah, sorry. It works for me with my editing prog. but then I have to
change it back again to play Oblivion...  :(
   As an aside, I remember asking if PoV could handle large files some
four/five years ago, (3.1g?), and I received the answer that, yes, PoV could
easily handle a 100Mb's file. Back then, I was using sPatch frequently, and
a 'heavy' sPatch file (for me) could easily have been over 4.5Mb's. I think,
(back then), that I only had 256Mb memory, and I could still render an
image. So, I'm thinking that maybe something is wrong with the way that one
(or maybe two), of the programs that you've used are at fault?
     Have you tried to start from the beginning again?
    I'm intrigued and fascinated at what you are trying to achieve with
235,000 lines of code and want to see the result/s!  ;o)
     Again, good luck.
     ~Steve~
Date: 13 Aug 2006 23:45:00
Message: <web.44dff11e3fb029beb996bf760@news.povray.org>
I tried this render on three different computers with POV-Ray version 3.1
and 3.6 several times. None of them has ever managed it, though, my most
powerful computer did render a 7MB file today, barely. (4.5 MB is the
largest file I've been able to render thus far, the file I'm trying for is
about 8.5 MB.) I even stripped away some elements of the model to reduce
it's size with no effect. I think it's because the file was created by
another program from a CAD program model.
>      Again, good luck.
>      ~Steve~
If I get this thing working I'd be happy to send a pic, though I doubt it's
nearly as impressive as you think.
Thanks again,
   Michael
Date: 14 Aug 2006 09:42:24
Message: <44e07dc0@news.povray.org>
> difference.
  Note that the size of the .pov (or .inc) file isn't necessarily related
to how much memory POV-Ray will need to render the scene. It isn't even
related to how much memory POV-Ray will need to parse the file.
  The only case where a big file will consume memory is if you open it
in the winpov editor (in which case the editor will consume the memory.
naturally). If you don't open it in the winpov editor then the file by
itself doesn't consume memory.
  If the file has been automatically generated by some program then it
probably contains almost as many primitives as lines of code (or at least
a number of primitives directly proportional to the lines of code), in
which case the file size is somewhat indicative of how much memory
  But take into account that file size is not *always* such an indicator.
It's perfectly possible to make a 500 bytes .pov file which will require
gigabytes of memory to render, as well as a 500MB .pov file which requires
just some kilobytes of memory to render.
Date: 14 Aug 2006 19:25:01
Message: <web.44e105283fb029be6e4d99c0@news.povray.org>
That is good to know, thanks. Still how can I render this file without
converting to a 64bit OS and motherboard??
Michael
Date: 15 Aug 2006 07:36:22
Message: <44e1b1b6@news.povray.org>
  I wonder if the linux version could render it...
Date: 19 Aug 2006 01:45:00
Message: <web.44e6a4f73fb029bee8eab8b00@news.povray.org>
Is there ANY way that I can render this file without changing OS or
architecture? I just got a new computer, I can't afford another one just to
render images. What adjustments can I make to my system, or software should
I download, to increase the amount of virtual memory the OS allocates to
individual programs? I looked at Microsoft, but I couldn't find anything
that specifically addresses the virtual memory problem.
I really appreciate your help everyone, thanks for trying.
   Michael
Date: 19 Aug 2006 06:21:46
Message: <44e6e63a@news.povray.org>
news:web.44e6a4f73fb029bee8eab8b00@news.povray.org...
>>                                                           - Warp
> to
> should
>   Michael
   Michael, is it possible that you could upload the 8+Mb file somewhere,
and I'll see if it runs on my machine? I believe that I may have a similar
system to yours, (at least, I hope so, (apart from XP Home)):
    Windows XP Home (5.1, Build 2600) SP2
    AMD Sempron(tm) Processor 2800+, 1.6GHz
     1024MB RAM
     Page File: 214MB used, 2734MB available
   Other than the above, I can only suggest a couple more things that you
can try:
     Faulty memory? You could try Memtest: http://www.memtest86.com/
     Have you tried disabling all background services? (Although, this
shouldn't really be a problem as I run fairly heavy files with all services
running).
     Anyway, let me know if you upload the file and we'll see if it throws
any errors here.
     ~Steve~
