![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"M_a_r_c" <jac### [at] wanadoo fr> wrote:
> web.44b6e69ef8cbc39dc1709b0c0@news.povray.org...
> > You have some of the most AMAZING software available to use for graphics.
> > Well, enough of the hobbknobbing I have questions that need to be
> answered.
> > I am trying to put ambient light on an object that would appear as the
> Sun.
> > so far what I got is:
> > sphere
> > { <0,0,0>860
> > pigment { image_map
> > { gif "sun.gif"
> > map_type 1
> > translate <0,0,3000>
> > Now I do not know exactly what or where to insert any string data to do
> with
> > ambient light coming from this object named "sun.gif". Can anyone help,
> > Please.
> > Anytime I try to input ambiet_light I get an Error message.
> > Thank you Brian
> You could look at the texture section in the POVRay doc
> http://www.povray.org/documentation/view/3.6.1/331/
> to simplify you put a pigment, it is ok
> but ambient is a finish item.
> pigment determines the basic color of an object on its surface.
> finish determines how this surface reacts to light (diffuse, ambient,
> reflection, specular.....)
> pigment and finish are gathered in a texture block
> sphere
> { <0,0,0>860
> texture{
> pigment { image_map { gif "sun.gif" map_type 1 }
> finish { ambient 1 diffuse 0}
> // ambient 1 makes object "shine" (not lighting the scene but visible)
> //and diffuse 0 make it not interacting with lights
> Marc
I appreciate your help, but I have a problem with your solution. Anytime I
use a 'finish' at all I get an error message. I must not know how to use
'finish' correctly.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
web.44b77e02bc7d6ebc1709b0c0@news.povray.org...
This is the purpose of these groups, you're welcome ;-)
> 'finish' correctly.
Please, could you paste your texture here, so we could help you
Which message do you get?
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> sphere
> { <0,0,0>860
> texture{
> Marc
And don't forget that ambient is not limited to 1. Seeing this is a bright
sun, you may want to go higher.
-tgq
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > 'finish' correctly.
> Marc
The texture is a gif of the Sun I named 'sun.gif' it is 1000 x 2000 pixels.
I got the image from a JPEG that was dubbed suncyl1.jpg from a website that
had a good picture. http://www.solarviews.com/cap/sun/suncyl1.htm Its not
much to look at until you wrap it around a sphere. then it looks great, but
I also have a sphere of Earth close to it that casts a shadow on it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > 'finish' correctly.
> Marc
I've recently revised the image I will show what it looks like; it is not
much because I am new at this stuff.
global_settings {
assumed_gamma 1.0
max_trace_level 5
location <0.0, 0.0, 0.0>
direction 1.5*z
look_at <0.0, 0.0, 0.1>
sky_sphere {
gradient y
color_map {
[0.0 rgb <0,0,0>]
sphere
{ <0,0,0>860
pigment { image_map
{ gif "Sunny.gif"
map_type 1
translate <0,0,1000>
sphere
{ <20,0,10> 10
pigment { image_map
{ gif "moon.gif"
map_type 1
light_source {
<0, 0, 0> // light's position (translated below)
color rgb <1, 1, 1> // light's color
translate <-2, 0.01, 80>
sphere
{ <13,0.01,100> 7.6
pigment { image_map
{ gif "mapaS.gif"
map_type 1
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I appologize. I forgot that the 'Sunny.gif' is only on my computer. I do not
know what you are refering to when you say texture. I'm trying to learn this
program so that I may make realistic animations.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > > 'finish' correctly.
> sphere
> { <0,0,0>860
> pigment { image_map
> { gif "Sunny.gif"
> map_type 1
Make sure you nest the brackets proiperly when adding finish. I find it
easier if the brackets following a scope indentation.
sphere{
<0,0,0> 860
pigment{
image_map{
gif "Sunny.gif"
map_type 1
to add a finish just add it after the pigment block (outside its brackets).
It is also usually good protocol to wrap them inside a texture block:
sphere{
<0,0,0> 860
texture{ //texture start
pigment{ //pigment start
image_map{
gif "Sunny.gif"
map_type 1
} //pigment end
finish{ //finish start
ambient 1
diffuse0
} //finish end
} //texture end
-tgq
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
web.44b7baa9bc7d6ebc1709b0c0@news.povray.org...
not
this
I explained you in a former post what is a texture in POV
I paste it again
sphere
{ <0,0,0>860
texture{
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> -tgq
Wow, tgq, I owe you my first and last born. I hope you do not sell them into
slavery.It worked the sun can shine on its own again, you have saved
humanity and all life on Earth. Thank you very much.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > -tgq
Thanks, but my own first born is all I can handle at the moment (and if he
doesn't settle down a bit, my says he may be my last born as well...)
Sometimes when you have problems, it is best to look at the simple things
first. Establishing a good scene language protocol for yourself is good to
do, then it becomes easier to track down simple problems like this one or
identify if it is indeed something more complex.
-tgq
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
