POV-Ray : Newsgroups : povray.newusers : Strangeness with Parallel Lights Server Time
30 Sep 2024 20:12:12 EDT (-0400)
  Strangeness with Parallel Lights (Message 1 to 10 of 12)
Subject: Strangeness with Parallel Lights
Date: 10 Feb 2004 10:12:15
Message: <opr25twbswp4ukzs@news.povray.org>
I've hacked away at a much larger script to isolate the error which
produce the code below; and still it refuses to behave.
The camera is inside a hollowed out box, there are no openings to the
outside world. I'm pointing a set of parallel lights from outside the box
to a point inside.
So. where's the light coming from?
Am I doing something fundementally wrong (most likely) or is this some
property of parallel light's I don't know about showing up?
Please save my sanity and allow me to get back to my project.
Phil
<code>
#declare WindowGap=16;
#declare NumberOfWindows=5;
camera{
location <6,15,2>
look_at <6,15,30>
#declare OuterWall=
difference{
box{0,<20,20,100>}
box{0,<18,18,98>  translate <1,1,1>}
pigment{rgb <1,0,1>} finish{ambient 0.2}
hollow
#declare WindowCount=1;
#while(WindowCount<NumberOfWindows)
light_source{<-5,6,WindowGap*WindowCount> rgb 1 parallel point_at
<1,0,WindowGap*WindowCount>}
#declare WindowCount=WindowCount+1;
object{OuterWall}
</code>
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Subject: Re: Strangeness with Parallel Lights
Date: 10 Feb 2004 10:59:45
Message: <4028fff1$1@news.povray.org>
> box to a point inside.
Read this section in the manual:
6.5.7.4  Parallel Lights
Severi Salminen
Date: 10 Feb 2004 11:26:55
Message: <4029064f$1@news.povray.org>
"Severi Salminen" <sev### [at] NOT_THISsibafi> wrote in message
news:4028fff1$1@news.povray.org...
Hopefully Phil will see that you are probably referring to the plane of
light projection. So, Phil, you'll need to watch out for that plane of light
and any intersecting with objects it might do. I realize the doc says this,
basically, but perhaps not in a way everyone will understand-- which is
pictures like Phil's.  :-)
Bob H.
http://www.3digitaleyes.com
Date: 10 Feb 2004 11:52:39
Message: <opr25yj0lyp4ukzs@news.povray.org>
On Tue, 10 Feb 2004 10:26:46 -0600, Hughes, B. <omn### [at] charternet>
> light
> this,
You caught me in the middle of replying to Severi; so I'll start again
here. Yep I guessed it had something to do with the light plane, but can't
figure out how it works. I'm producing a plane presumely based at location
perpendicular to the point_at so if my location was at 0 and point_at y
then then it would be equivalent a plane{0,y} I assume?
I've just read what I wrote and worked it out: the plane I'm producing is
passing through the box; as the light is taken from the closet point of
the plane I'm getting the equivalent of an internal light source. Sheesh
Thanks for all the help
Phil
Date: 10 Feb 2004 12:44:00
Message: <cjameshuff-9C1A31.12442110022004@news.povray.org>
In article <opr25yj0lyp4ukzs@news.povray.org>,
No. The point_at vector is a location, the plane vector is a direction
(the plane normal). Thought the two are the same when the location is <
0, 0, 0>, as in your example.
Right.
http://tag.povray.org/
Date: 11 Feb 2004 05:10:05
Message: <opr27akwh2p4ukzs@news.povray.org>
On Tue, 10 Feb 2004 12:44:21 -0500, Christopher James Huff
>> can't
>> location
Errr. If light-source{0 rgb 1 parallel point_at y} then surely if I
connect a line between location and point_at than a plane perpendicular to
this would be lying at 0 in the XZ plane ie. plane {0,y} and not
plane{y,y} or even plane{y,-y}; in the same way that light_source{y rgb 1
parallel point_at <1,1,0>} would produce the equivalent of a plane{0,x} or
plane{y,x} to be more precise: otherwise the scene I've just produced
wouldn't work; unless I'm just lucky :)
>> is
> Right.
So I moved the light location to:
light_source{<-5,20,WindowGap*WindowCount> rgb 1 parallel point_at
<10,0,WindowGap*WindowCount>} which produces just the right results. Now
I've figured it out I assume that I don't need to reproduce the lights at
multiple points as the light plane will cover the entire scene. Though
just doing a quick render I prefer the extra amount of light; I'll just
hike the rgb up. Hmm much faster.
Phil
Date: 11 Feb 2004 08:05:59
Message: <cjameshuff-67786F.08062211022004@news.povray.org>
In article <opr27akwh2p4ukzs@news.povray.org>,
Right. The surface normal direction and the point_at location match up,
because the light location is < 0, 0, 0>. You could use a non-normalized
vector as well, it doesn't matter as long as they point in the same
direction.
> plane {0,y} and not plane{y,y} or even plane{y,-y};
Er, no. It would be "plane {y, 0}". The last two aren't even valid
planes...the POV primitive takes a normal vector and displacement
distance.
A location of < 0, 1, 0> (y) and point_at of < 1, 1, 0> would lead to a
direction of < 1, 0, 0>, or x. The equivalent plane would be "plane {x,
0}". Again, "plane {y, x}" isn't even a valid plane.
Date: 11 Feb 2004 09:18:52
Message: <402a39cc$1@news.povray.org>
You guys are starting to confuse me... Only joking.
I had forgotten how parallel lights treat fading so I gave it a look in a
few renders by building on Phil's example scene (see image). Maybe this will
help a few people understand parallel lights a little better.
http://www.3digitaleyes.com/parallel_light.jpg
Maybe this picture is worth a thousand words-- or at least a paragraph.  :-)
I know the documention tells how fading (attenuation) is same as for
ordinary point lights but I wanted to be sure if that meant for all
directions and not just the point_at one. I probably knew already but
couldn't remember. The blue cones are where the light sources are and where
they point. Inside the box is a yellow cone to show that 'parallel'
direction and shadow; no shadow in opposite direction, as per the
documentation (unidirectional).
Bob H.
Date: 11 Feb 2004 11:26:50
Message: <opr27r0zp4p4ukzs@news.povray.org>
On Wed, 11 Feb 2004 08:06:22 -0500, Christopher James Huff
>> to
> direction.
> distance.
>> or
Sorry my bad I don't use planes that often and was confusing my terms;
again sorry, of course plane{y,y} should have been plane{y,1} etc. Odd
that when I code I don't tend to get it wrong but do when I try to post it
in a newsgroup for the whole world to see :)
Phil
Date: 11 Feb 2004 11:47:06
Message: <opr27syqj0p4ukzs@news.povray.org>
On Wed, 11 Feb 2004 08:18:51 -0600, Hughes, B. <omn### [at] charternet>
> will
> where
Thanks that's interesting, and I'm sure will come in useful for some
interesting lighting techniques. Out of curiosity as parallel can be used
with any light_source do you know the effects of combining it with area
lights I'm imagining an area light in the XY plane with a 45 degree
point_at would a plane be created for each light?
Phil
