POV-Ray : Newsgroups : povray.newusers : Image maps Server Time
14 Jul 2026 01:46:16 EDT (-0400)
  Image maps (Message 1 to 6 of 6)
Subject: Image maps
Date: 15 Dec 2006 01:39:36
Message: <45824328@news.povray.org>
I am trying to apply an image to the surface of a box as so
box { <-2, -0.5, -2>, <2, 0.55, 2>
       pigment{image_map {sys "Test.bmp"} scale 1}
       rotate y*45
       translate<-25.5, 0, -25.5>
But I am getting a series of verticle bars. Thinking this was due to a
scaling problem I have added the scale and gone from 0.0001 to 10000. At
extremes I get a solid color that might be a corner of the image but nothing
else. Is there any way to work out how to scale the file to fit the box
surface or am I going about this completely the wrong way. I really only
want to place an image on the surface.
Thanks
Subject: Re: Image maps
Date: 15 Dec 2006 03:57:10
Message: <45826366$1@news.povray.org>
"David Instone" <d.i### [at] gmailcom> wrote in message
news:45824328@news.povray.org...
>       rotate y*45
> nothing
> Thanks
My guess is that you're projecting the image onto the edge of your box and
the lines are the continuation of the image through the box.
The image is projected onto an XY plane by default, so if you are looking at
the XZ plane of the box you would just get stripes.
If this is your problem, just try rotating the image:
  pigment{image_map {sys "Test.bmp"} scale 1 rotate x*90}
Which should place the image on the XZ plane, then you can rotate and
translate the box to wherever you want.
Chris B.
Date: 15 Dec 2006 04:01:30
Message: <4582646a$1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> wrote in message
news:45826366$1@news.povray.org...
>> Thanks
Oh yes, and the scaling bit - By default the image takes up one unit square
with it's bottom left corner at the origin. So to scale to a 4x4 surface and
centre it you'd need
pigment{image_map {sys "Test.bmp"} scale 4 translate <-2,0,-2> rotate x*90}
Chris B.
Date: 15 Dec 2006 05:00:09
Message: <45827229@news.povray.org>
news:4582646a$1@news.povray.org...
square
and
x*90}
> Regards,
> Chris B.
Thank you very much Chris. You hit the nail right on the head with that one
and it has been annoying me for too long. I did have to play with it a bit
to get it right though. Instead of your version I ended up with this.
pigment{image_map {sys "Test.bmp"} scale 4 rotate x*90 translate <-2,0,-2>}
I found that if you translate before you rotate you end up with two half
images tiled verticaly. Does that sound feasible or am I making it up as I
go along?
Regards David
Date: 15 Dec 2006 05:55:00
Message: <web.45827ef11ec1b08bf1cb1e660@news.povray.org>
> square
> and
> x*90}
> > Regards,
> > Chris B.
> go along?
> Regards David
pigment{image_map {sys "Test.bmp"} once scale 4 rotate x*90 translate
<-2,0,-2>}
Date: 15 Dec 2006 05:58:10
Message: <45827fc2@news.povray.org>
news:45827229@news.povray.org...
> <-2,0,-2>}
> go along?
Hi David,
Ah yes, of course you're perfectly correct. If you translate it first the
translation in the Z direction has no effect, because it's just effectively
pushing the image into itself.
So you could translate <-2,-2,0> and then rotate x*90, but I think that
doing the rotate first, as you've done it, is clearer.
Chris B.
