POV-Ray : Newsgroups : povray.newusers : very strange... Server Time
18 Jan 2026 08:38:05 EST (-0500)
  very strange... (Message 1 to 8 of 8)
Subject: very strange...
Date: 31 Mar 2003 11:52:11
Message: <3e88723b@news.povray.org>
Hi!
I had a POV-Ray image with an height-field. It were smooth mountains which
looked quite good. After I have bought a new harddisk, I reinstalled POV-Ray
and I rendered the file again. The file and the tga-file were exactly the
same. Now I see very pixelated mountains. It's the same POV-Ray version.
Does anyone know a solution???
THANKS A LOT!!!
J T
Subject: Re: very strange...
Date: 31 Mar 2003 11:59:47
Message: <3E887403.A48CDA41@gmx.de>
J Tellings wrote:
> Hi!
Let me see if i understand this right:  You have a POV Scene that rendered
nicely (using a certain heightfield data file) and after reinstalling
POV-Ray (same version) and rendering (same scene with the same heightfield
file and with the same options at command line and in ini file) the result
is different?
Sorry, but the only solution would be to find out what's wrong in your
statement.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 31 Mar 2003 12:44:59
Message: <3e887e9b@news.povray.org>
news:3E887403.A48CDA41@gmx.de...
> J Tellings wrote:
> > Hi!
which
POV-Ray
the
> is different?
> statement.
I said it a bit wrong. I had a POV Scene that rendered nicely. A few months
later, I rendered it again but now the mountains were very 'pixelated'. I
haven't changed anything, as far as I know.
Date: 31 Mar 2003 12:55:47
Message: <3E88811F.A7F6ABD3@gmx.de>
J Tellings wrote:
> ... as far as I know.
This is exactly what i meant.  You should check what things you have
changed and then you will find the problem.
Date: 31 Mar 2003 13:15:09
Message: <web.3e888445a5ba7c7ec48bf360@news.povray.org>
I would be interested if you find a reason for this. I recently
experienced a similar problem. The file renders fine on my Mac,
but a height field is very noisy when the same file is rendered
on a unix machine. I assume it has something to do with the fact
that I do not have all the right versions of the image include
files (when I compiled the latest unix version), but it's odd
because I thought it had rendered them fine before, and the code
does compile (seemingly) okay.
Date: 31 Mar 2003 13:30:26
Message: <3E888942.845A64E@gmx.de>
> on a unix machine. [...]
Here applies the same (although there is of course the risk of some minor
differences due to different compilers, especially if you do something you
are not supposed to do).
You will have to check for the differences, most important of course if
scene and data files are the same (really *are* identical, not just look
like the same) and apart from that if the command line and ini file
options used are identical.
Date: 31 Mar 2003 14:28:05
Message: <3e8896c5@news.povray.org>
In article <3E8### [at] gmxde> , Christoph Hormann
Windows and Mac platforms statically link to the image support libraries for
PNG, JPEG and TIFF image support.  On any kind of Unix these libs are taken
from the operating system, and this may simply be an incompatible version...
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Mar 2003 14:39:46
Message: <3E889981.EF8BE28A@gmx.de>
Well, of course my suggestion solely referred to using the official
POV-Ray versions (which is statically linked in the linux version as
well).  What people do wrong when compiling and running their own versions
is completely their business (at least as far as povray.newusers is
concerned). :-)
