POV-Ray : Newsgroups : povray.newusers : new to raytracing in general, is moray the way to go? Server Time
12 Jul 2026 10:43:54 EDT (-0400)
  new to raytracing in general, is moray the way to go? (Message 1 to 10 of 12)
Subject: new to raytracing in general, is moray the way to go?
Date: 11 Mar 2003 11:20:51
Message: <3e6e0ce3@news.povray.org>
I've just started playing around with POV-Ray by going through the tutorials
(and being overwhelmed), but I'm really not a big fan of the concept of
creating a scene using the SDL - is Moray a great way to use POV-Ray for
creating scenes of any complexity? Are there any drawbacks to using Moray
rather than POVRay by itself (apart from the shareware licence).
My current plan is to get the hang of everything in the "Beginning Tutorial"
section (basic shapes, CSG, lighting etc) and see if I'm still enjoying
myself!
cheers,
cheers,
neko_
Subject: Re: new to raytracing in general, is moray the way to go?
Date: 11 Mar 2003 11:26:12
Message: <3e6e0e23@news.povray.org>
  The only drawback is that you will be able to use the features Moray
supports, and Moray does not support everything POV-Ray can do.
  However, mostly this is not a problem. Great images have been using
Moray alone.
Date: 11 Mar 2003 13:20:11
Message: <3e6e28db$3@news.povray.org>
neko <nek### [at] swirvecom> wrote in message news:3e6e0ce3@news.povray.org...
> Hi,
tutorials
Tutorial"
> myself!
> cheers,
> cheers,
> neko_
you can do quite complex scenes in moray. its a pretty darn good modeller.
It's just hard to get any sort of organic looking objects with it alone. You
might want to look into Spatch or Hamapatch eventually for adding curvy non
primitive based objects. With Spatch you can easily export to moray usable
objects, i've never used Hamapatch though so I dont know for sure how they
work together.
the other great feature in moray for users of all levels is the texture
editor.
Eventually we'll assimilate you though, and you will eat, drink, and dream
pov SDL =) It happened to me.
its all a matter of preference though. I've recommended moray to 2 people
who were just getting into raytracing, and they loved the pov+moray
combination.
have fun,
ross
Date: 11 Mar 2003 16:14:06
Message: <MPG.18d7fb817f86414a989772@news.povray.org>
In article <3e6e0ce3@news.povray.org>, nek### [at] swirvecom says...
> Hi,
> myself!
> cheers,
> cheers,
> neko_
Moray is useful, but some tweaking 'may' be needed to the final SDL. Why?
Because Moray uses approximations of objects. Neither OpenGL or its
wireframe system give a 100% accurate positional match to where things go
in it. This is imho a drawback, since you still have to know exactly
where something needs to be in order for all of it to line up correctly.
Since all objects in Moray appear in a specific default alignment, things
like cylinders that you can normally create in the SDL by giving their
'exact' end points requires trying to rotate them in Moray. This
sometimes just won't work right, no matter how careful you are about
trying to rotate it into position. Personally I prefer the pure SDL in
most cases, since I end up doing as much work getting stuff right in
Moray as I do hand coding in some cases. However, it seems to have been
improved since the last version I tried, even if annoying quirks like the
cylinder issue has yet to be properly addressed imho.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 11 Mar 2003 16:40:19
Message: <3e6e57c3@news.povray.org>
Go for moray :)
PGP Public Key
Subject: RE: new to raytracing in general, is moray the way to go?
Date: 11 Mar 2003 17:09:57
Message: <3e6e5eb5$1@news.povray.org>
> Hi,
tutorials
If you find easier to work with a modeller than using the SDL directly,
I think the better option is moray.
It's the most complete pov modeller around the world (even though
it can't do "everything" that pov can), but it's expanding its
possibilities with plugins (animation plugin is a good example) and now
has a mesh editor with UV_mapping support.
It is a low cost application (sure it gives you more than you pay for it).
In combination with:
- hamapatch: freeware, organic modeller, exports to Moray .mdl file
http://www.geocities.com/hamapatch/program/index.html
- poseray: also freeware, takes an .obj file and exports it to UDO (moray),
INC (pov), with UV_mapping support.
http://user.txcyber.com/~sgalls/index.htm
you are able to make very complex scenes.
Just my opinion.
Txemi Jendrix
http://www.txemijendrix.com
Date: 11 Mar 2003 20:25:13
Message: <3e6e8c79$1@news.povray.org>
neko's furious key-hammering produced this:
That all depends on what you're looking for, really.
Moray is probably the best POV-Ray modeller around (I used to use it all the
time, actually) but it doesn't give the kind of power that a good ol' POV-SDL
script would (though many features commonly done in SDL such as the positioning
of a group of objects) can be done with other methods.
Creating a scene in SDL isn't that hard, really, but you have to really be able
to visualize the scene you're working on in your head.  However, if you're more
of a programmer type you'll probably like it more in the long run.  I've been
using Moray for years now and I don't regret the switch I made to pure SDL
recently.  I am the programmer type, though, so just keep in mind that your
mileage may vary. :)
> myself!
I'd do that.  That should give you a chance to get a feel for SDL.
I was somewhat uncomfortable with it when I tried it a few years ago but I'm
fine with it now.
/*^*/light_source{100*<-5,2,-5>2}#macro I(i,n)#while(strlen(i)>=n)#local A=asc(
substr(i,n,1));#local a=asc(substr(i,n+1,1));cylinder{<div(A,8)-12,mod(A,8)-4,4
><div(a,8)-12,mod(a,8)-4,4>,0.1pigment{rgb z}}#local n=n+2;#end#end I("ScUe[]"1
/*<*/)I("mkmtlttk"1)//@_$#!,:<"Thhis polysig brought to you by Ian Burgmyer :)"
Date: 12 Mar 2003 09:14:01
Message: <3e6f40a8@news.povray.org>
> tutorials (and being overwhelmed), but I'm really not a big fan of the
> concept of creating a scene using the SDL - is Moray a great way to
> use POV-Ray for creating scenes of any complexity? Are there any
> drawbacks to using Moray rather than POVRay by itself (apart from the
> shareware licence).
I'd say go for SDL, I've never needed Moray. (I've only tried it once,
didn't like it much). When I need complex or organice models, I use
Wings3D. A free solution :)
Just my opinion..
Now off to Germany and CeBit =)
Peter
http://hertel.no/peter
Date: 12 Mar 2003 12:15:45
Message: <3e6f6b41@news.povray.org>
i've never noticed this, and don't understand what you are saying. what is
wrong with giving moray the exact positions through its text entry areas of
the interface? are you talking about grabbing an object in one of the views
and moving it around?
Date: 12 Mar 2003 18:07:29
Message: <MPG.18d966f5602cfd5c989773@news.povray.org>
In article <3e6f6b41@news.povray.org>, lit### [at] osuedu says...
Exactly. And some things like cylinders, unless they changed them
recently only have position, rotation and scale. If they have since added
the ability to correctly define the actually end points, then it may be
time to check out the new version again (though maybe waiting until they
fix the beta bugs...). A lot of stuff I tried to use it for where
furniture and stuff where I needed to have a cylinder at an angle to
provide a smoothed edge. I could never get them right. And like I said,
why, if I already know the exactly locations, do I need a graphical
design interface? The only thing they are good for is designing when you
don't already have detailed plans for where each individual things will
go when you are finished. For the few things I tried to do with it, I got
quite irritated, but I must admit that the fact that I wasn't willing to
pay for it at the time and thus couldn't complete my intended model
anyway probably contributed to my annoyance. ;) lol
void main () {
  else
