POV-Ray : Newsgroups : povray.newusers : text on a object Server Time
10 Apr 2026 10:54:04 EDT (-0400)
  text on a object (Message 1 to 8 of 8)
Subject: text on a object
Date: 1 Jan 2003 01:47:58
Message: <3e12900d.824764@news.povray.org>
Happy newyear everybody
Is it possible to put povray-text on the surface of an object like a
sphere or to make it more complicated the surface of an SOR?
Thakns for any reply
Subject: Re: text on a object
Date: 1 Jan 2003 09:51:16
Message: <cjameshuff-1A8986.09470301012003@netplex.aussie.org>
In article <3e12900d.824764@news.povray.org>,
The object pattern was created just for this. It is a block pattern,
like checkers: it takes two textures and an object, and uses one for any
areas within the pattern object, and the other for areas outside.
There's an example of using it in the demo scenes.
http://tag.povray.org/
Date: 2 Jan 2003 01:54:00
Message: <3e13e282.1402309@news.povray.org>
On Wed, 01 Jan 2003 09:47:03 -0500, Christopher James Huff
Thanks Christopher for the quick reply but I will try to explain what
I want. In the object_pattern scene file the text is placed
horizontally on the object. But I want to place the text vertically
(sitting or standing on the object surface)
Greetings from Belgium
Date: 2 Jan 2003 05:37:17
Message: <3e14165d@news.povray.org>
"Roland Vansteenkiste" <rol### [at] pibe> wrote in message
news:3e13e282.1402309@news.povray.org...
Jumping in.
I am confused about your goal, however you can try using a vector for the
final parameter of the text object if your font is fixed width (maybe).
Such as:
text {
        ttf "arial.ttf", "abcdabcd", 0.1, < -1/2, -1, 0 >
                pigment { color rgb 1 }
Reason I'm confused... I saw previous messages and wondered if you wanted
something like uv mapping. For instance, taking a image map of text and
applying in a way that conforms to every curvature of a object.
Date: 2 Jan 2003 09:13:00
Message: <cjameshuff-5B6D54.09085202012003@netplex.aussie.org>
In article <3e13e282.1402309@news.povray.org>,
This has nothing to do with the object pattern, just the text object.
You could use a union of separate characters positioned however you
want, or the text object might have a parameter that allows it...I've
never done much with that object.
Date: 3 Jan 2003 02:37:50
Message: <3e153de6.685399@news.povray.org>
>Such as:
>text {
My goal is  placing a text object on a predifined curve (or object)
and I want POV to do all the calculations needed to do that. I've
posted a gif file FLEXICYBER.GIF in the images group to show wath i'm
trying to do. Each letter is one text object and placed (and
calculated) manually. My goal is to make the word one object and to
let POV do all the calculations and placement.
Roland
Date: 3 Jan 2003 03:23:43
Message: <Xns92F85FD71F68seed7@povray.org>
Have a look at "shapes.inc - circle_text". It does not exactly do what you
want, but you may be able to adapt it to your needs.
Ingo
Date: 3 Jan 2003 16:01:26
Message: <cjameshuff-236AB8.15572203012003@netplex.aussie.org>
In article <3e153de6.685399@news.povray.org>,
Well, the best way would be to use a macro that takes a text string and
lines the characters up on a spline. You could then do something like:
object {SplineText(MySpline, Size, Spacing, "myfont.ttf", "Hello")}
There is no existing macro that I know of which does this, but it would
not be too difficult to write. The reorientation transformation in
transforms.inc would come in useful. I'll try to cook one up if I have
time.
