POV-Ray : Newsgroups : povray.newusers : Wavelength to RGB converter? Server Time
22 Dec 2025 23:09:19 EST (-0500)
  Wavelength to RGB converter? (Message 1 to 10 of 38)
Subject: Wavelength to RGB converter?
Date: 28 Feb 2003 19:49:37
Message: <1fr4a7h.44sdcb1jqm0yuN%kaveh@delete_this.focalimage.com>
Is there an .inc file that converts a wavelength to the approximate
equivalent RGB components? I am looking for perfect accuracy. An
approximate look-up table will do.
Kaveh
Subject: Re: Wavelength to RGB converter?
Date: 28 Feb 2003 20:49:14
Message: <cjameshuff-6A6C5B.20444028022003@netplex.aussie.org>
In article <1fr4a7h.44sdcb1jqm0yuN%kaveh@delete_this.focalimage.com>,
You contradict yourself. Perfection or approximation, pick one...only an
approximation is possible though.
You want to find the RGB values that would mimic monochrome light of a
specific wavelength? There are no includes that do this that I know of.
You could find the sensitivity curves of typical human eyes, and work up
a macro that uses a spline generated from these curves.
Some sites which might be useful:
http://www.adobe.com/support/techguides/color/colortheory/vision.html
http://www.yorku.ca/eye/specsens.htm
BTW, what do you want this for? I can't think of many uses for this,
except as a part of a system for converting spectral data to RGB.
http://tag.povray.org/
Date: 28 Feb 2003 21:44:40
Message: <3e601e98$1@news.povray.org>
For the records.
Jaime Vives Piqueres' lightsys (a set of include files to generate realistic lighting)
is able to do this.
http://www.ignorancia.org/t_lightsys.php
-Ive
Date: 1 Mar 2003 06:01:42
Message: <1fr524g.eym5jvaqbxdsN%kaveh@delete_this.focalimage.com>
Oops. A bad typo to make. I meant to say "I am *not* looking for perfect
accuracy"!!
I am writing a program to mimic the reconstruction of holographic
images. When a hologram (of a point object, say) is made with one
wavelength, and replayed with another wavelenth, the image is displaced,
and distorted, as a function of the wavelength. (This is because of the
dispersion of light, which in diffractive optics is some 40 time greater
than in refractive optics.)
I want the old image to be shown in the original wavelength colour, and
the new one in the colour of the new wavelength, as closely as
practical. So for each wavelength there would be a value in a lookup
table for the RGB to use.
When we use a large number of wavelengths, as in white light, I want to
see a more or less continuous spectrum of light, with each spectral
image in its correct position.
Thanks for your help. I will check the sites you mentioned.
Kaveh
Date: 1 Mar 2003 07:53:25
Message: <20030301135324.6a16c4c3.jaimevives@ignorancia.org>
On Sat, 1 Mar 2003 11:01:42 +0000
> and the new one in the colour of the new wavelength, as closely as
> to see a more or less continuous spectrum of light, with each spectral
  Check CIE.inc conained on my lightsys package (Ive posted the URL on
a previous reply). It has some macros to convert wavelength to several
RGB color systems, based on the CIE XYZ color space tranformations. Ive
done all this job alone, as a replacement for my lightsys color macros,
which used a poor aproximation at first based on Dan Bruton algorithm.
  Using CIE.inc, you sould be done with the Wavelength(W) macro, where
W is the wavelength in nm.( the default color system is sRGB). Have fun!
Date: 1 Mar 2003 10:49:26
Message: <1fr5fsj.1beeuyb1xw7s8mN%kaveh@delete_this.focalimage.com>
I just downloaded all those and saw that. It is *exactly* what I need.
And congratulations for doing so much work on color. It's not an easy
field!
I am probably doing something silly here, but when I run your test file:
    #include "lightsys.inc"            // main include
    #include "lightsys_CIE-sRGB"       // saved rgb values for common
colors
    // global variables
    #declare BRIGTHNESS=1.25;              // a little "overexposed"
    #declare WHITE_POINT=Wp_Daylight_Film; // translate white point to
5500K
    #declare COLOR_FILTER=CC05R;           // 5% CC red filter
    // obtain a light_source
    object{
     Light(Cl_Cool_White_Fluor,Lm_Fluorescent_15w,9*x,9*z,4,4,0)
I get an error:
Parsing...File: rgbtest.pov  Line: 1
    #declare WHITE_POINT=Wp_Daylight_F     // a little "overexposed"
ilm <----ERROR
Parse Error: Cannot assign uninitialized identifier.
It complains that Wp_Daylight_Film is not initialized, but it is, in
lightsys_CIE-sRGB. Can you see what I am doing wrong?
Kaveh
Date: 1 Mar 2003 11:22:41
Message: <20030301172241.0b6e3890.jaimevives@ignorancia.org>
On Sat, 1 Mar 2003 15:49:27 +0000
  Nice! And don't forget to show us the results!
> field!
  Yeah... but here all the merit goes to Ive, who done the hard work
researching and implementing color transformations. I'm still learning
and trying to understand it all, but I know already enough to see that
there are plenty of potential applications for CIE.inc.
> file:
  Oh! No! You used the non-tested example on the readme! :)
> I get an error:
  Hmmmm... line 1 ????
  Sorry, I've not tested this example, and it is not functional as it
does not contains any scenery. Better try any of the demo files
included, for example demo_basic.pov.
Date: 1 Mar 2003 13:40:50
Message: <3E60FEB3.EB7D364B@attglobal.net>
Jamie,
I want to interject that the page http://www.ignorancia.org/t_lightsys.php shows
up blank for me when I access it using netscape from a PC or from an unix box.
However, I can view the page source from within netscape and Internet Explorer
works fine. I am not sure what is amiss. Does anyone else get the blank page
with netscape? Oh, and pages on your site other than the techniques page display
as expected.
Bill P.
Date: 1 Mar 2003 14:45:57
Message: <3e610df5$1@news.povray.org>
William F. Pokorny <pok### [at] attglobalnet> wrote in message
news:3E60FEB3.EB7D364B@attglobal.net...
> Jamie,
shows
box.
Explorer
page
> with netscape?
Yes, I had the same thing. Only that page, all other pages work fine.  I
could view source to get the link to download.
RG
Date: 1 Mar 2003 15:21:07
Message: <20030301212106.1bf42fe3.jaimevives@ignorancia.org>
On Sat, 01 Mar 2003 13:40:51 -0500
"William F. Pokorny" <pok### [at] attglobalnet> wrote:
  Oops! Sorry, a table was not properly closed.... thanks for pointing
it out. Next time I will check also with netscape for any major change.
