Le 2023-12-21 à 15:42, Bald Eagle a écrit :
> Does anyone know how to implement the irid {} feature in the finish {} block of
> a texture?
> Or to be more accurate, how do I get iridescence to be visible on a clear
> surface?
> clipka posted some beautiful bubbles, and I can't seem to achieve anything close
> to the transparent but well-defined iridescent pattern that he gets.
> I tried adding interior {ior 1.4} but that didn't work (and I get weird
> artefacts}
> http://news.povray.org/povray.binaries.images/thread/%3C4ed6f24c@news.povray.org%3E/
> I looked in the distro, and it appears that we're missing an example scene for
> this feature.
> - BW
You just need to remember that iridescence acts pretty much the same way
as emissive media : It adds to whatever is behind it. So, it tend to not
show on white surfaces.
> a texture?
> surface?
> artefacts}
> this feature.
> - BW
there is an example in the Povray documentation:
scenes\textures\pigments\irid.pov.
I 'misused' it and added some finish_items.
Maybe it helps a bit.
Cheers Droj
Download 'irid_clear.pov.txt' (4 KB)
> a texture?
> surface?
> artefacts}
> this feature.
> - BW
Here's a bubble material that I came up with back in 2012, after clipka did a
bug fix on the old irid code:
#declare M_Bubble = material {
pigment { rgbt 0.99 }
finish {
diffuse 0
reflection { 0.05, 1 fresnel on }
specular 0.99 roughness 0.001
conserve_energy
irid { 0.25
thickness 0.25
turbulence 1.2
interior { ior 1.001 }
Download 'lucy_bubble2012.png' (2280 KB)
Preview of image 'lucy_bubble2012.png'
Yes, I remember that scene.
It's amazing how one can completely transform the feel and perceived complexity
of an object with the proper texture.
Thanks for posting that as a reminder and providing the texture.
Is that an HDRI light probe you're using? Radiosity?
Droj just posted his version, and with just a black background, it looked ---
like poop.
But then I just pasted in the simple ground & sky code, and it magically
transformed the exact same texture into beautiful shimmering bubbles!
It truly is an amazing transformation.
I'm betting that if I take your beautiful texture and render with a poor
environment, I would make that look like oil on mud too. The environment is what
gives it life.
- BW
> artefacts}
Do the artifacts look like refraction distortions? Bubbles are not solid
spheres, but hollow thin shells, so if you put an IOR on bubbles, you would have
to model them accordingly.
Just posting this here as a reference showing the effect of the 2 major values
for the irid {} finish.
turbulence was held at a constant 0.75, but anything between 0.25-1 works well,
and higher values might be useful for other effects.
Again, it's the environment that really lets you see the characteristic bubble
texture.
- BW
Download 'iridescencetests.png' (623 KB)
Preview of image 'iridescencetests.png'
I had the idea to render a similar scene showing the effect of varying the rgb
components of the irid_wavelength global setting.
https://wiki.povray.org/content/Reference:Global_Settings#Irid_Wavelength
Even though "You may have multiple global_settings statements in a scene."
Apparently, "Whatever values were specified in the last global_settings
statement override any previous settings." and this affects all the irid{}
statements, you can't sequentially assign different global settings to objects
in the same scene.
Kinda obvious, but I did it just to check. Bummer.
I'm voting for irid_wavelength to be moved into the irid {} code of the finish
{} block in future versions.
- BW
> like poop.
> - BW
Yes BE, it looks like poop but it wasn't meant to show my artistic capabilities.
It was just a reminder for you that there is a example file for iridescence
coming with Povray.
I simply changed the pigment from white to clear using your data.
So put the blame on the author of the original file for not providing a nice
background.
- Droj
> coming with Povray.
Yes, yes, I understand completely, and I knew I was flirting with disaster
trying to explain things.
> background.
No blame was being assigned, the point was that your texture is _beautiful_, but
if the user rendering a scene with it doesn't know the behaviour and limitations
of the irid {} feature, then a plain background will completely destroy it, and
beautiful as the texture might be - the end result is unfortunately....
I beg your humble pardon for any unintended offense.
- B "the ineloquent" E
> > coming with Povray.
> > background.
BE,
Honestly, no offense taken.
And it was not 'my texture' - the original is a Povray 3.7 scene file which I
'misused' in my strong belief to put you on the 'right track' when I saw your
first post. So no time for a neat background with tangerine trees and
marshmellow skies and a couple of fairies flying around.
And I am sure that you know what the coder gurus always used to say : RTFM! :))
- Droj
