POV-Ray : Newsgroups : povray.general : Isofunctions and meshes Server Time
18 May 2024 07:07:14 EDT (-0400)
  Isofunctions and meshes (Message 21 to 24 of 24)
Subject: Re: Isofunctions and meshes
Date: 9 Dec 2016 06:25:01
Message: <web.584a9459b9cec73de15d43a80@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> > > Have you tried to set the recursion depth to 0 ?
> IIRC the resolution has to be raised considerable if you have no recursion.
> I think that using recursion may lead to unwanted holes.
This seems to work. With resolution = 50 and depth =0, the result was similar in
smoothness to resolution = 8 and depth =1 and the time taken was about the same.
And no sign of gaps so far.
Incidently, I see that the object is mesh and not mesh2. I thought I had seen
something about an improvement to this meshing programme that produced a mesh2
and was faster?
Thanks for the help.
John
Date: 9 Dec 2016 08:05:01
Message: <web.584aaaf9b9cec73d7b4f57df0@news.povray.org>
Good :)
> and was faster?
Warp once made a program that can compress triangle meshes, but I don't remember
exactly what it can do. The latest version I can find mentioned is v3.0. It is
mentioned here:
http://www.povcomp.com/entries/46.php
I've tried to search for it, but with no luck so far. Perhaps someone else in
here knows where to find it. If not, you can just ask Warp.
No problem.
Tor Olav
http://subcube.com
Date: 10 Dec 2016 11:45:01
Message: <web.584c300fb9cec73d7b4f57df0@news.povray.org>
It would be interesting to see that head rendered as a mesh without holes at
that resolution or higher. (I'm curious about how much "noise" there is around
the eyes and below the nose.)
Tor Olav
http://subcube.com
Date: 11 Dec 2016 06:25:00
Message: <web.584d3650b9cec73de15d43a80@news.povray.org>
I have posted an image at:
http://news.povray.org/web.584d34e77f9527eae15d43a80@news.povray.org
along with the source code. The noise around the eyes looks a bit like wrinkles!
John
