POV-Ray : Newsgroups : povray.general : rounded_objects: a new feature? Server Time
19 May 2024 08:12:35 EDT (-0400)
  rounded_objects: a new feature? (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: rounded_objects: a new feature?
Date: 18 Sep 2016 07:00:01
Message: <web.57de7375696ad3a7cafab50@news.povray.org>
"John Greenwood" <nomail@nomail> wrote:
> And here it is:
> // Demonstration of plane elements for rounded objects
And now spheres:
// This work is licensed under the Creative Commons Attribution 3.0 Unported
License.
// To view a copy of this license, visit
http://creativecommons.org/licenses/by/3.0/
// or send a letter to Creative Commons, 444 Castro Street, Suite 900, Mountain
View,
// California, 94041, USA.
// Demonstration of Sphere elements for rounded objects
// Vers: 1.00
// Date: 18 Sept 2016
// Auth: John Greenwood
#version 3.7 ;
camera {location <0,0,22> angle 30 look_at <0,0,0> }
  background { color rgb<0.2, 0.4, 0.8>  }
  light_source {<5,20,10> color White}
  global_settings {assumed_gamma 1.0 }
  #declare R_function = function( F,q,s){
select((F>q)-(F<-q),2*(q<0)-1,s*pow(F/q,5)-(2*s+.5)*pow(F/q,3)+(1.5+s)*F/q,1-2*(q<0))
  isosurface {
     function    {
               R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-1,0)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1 ,-.5,0)
     threshold  1
      max_gradient 4
     contained_by { box { -2, 2 } }
  texture {pigment {color rgb < 1, 0.9, 0.65>}}
            translate < 3,3,0>  }
  isosurface {
     function    {
               R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-.5,.3)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1 ,-.5,-.4)
     threshold  1
      max_gradient 3
  texture {pigment {color rgb < 1, 0.9, 0.65>}  }
      translate <-3,3,0>        }
  isosurface {
     function     {
R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,min(-.3,-.5-.4*-y),0)
+R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,min(-.3,-.5-.4*+y),0)
     threshold  1
      max_gradient 5
     translate <3,-0,0>         }
  isosurface {
     function    {
                R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-.5,y)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,-.5,-y)
     threshold  1
      max_gradient 4
      translate <-3,-0,0>        }
  isosurface {
     function     {
                R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+.5,-2,-.5)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,-1,0)
     threshold  1
      max_gradient 3
     translate <3,-3,0>         }
  isosurface {
     function    {
                R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+.5,-1,0)
               +R_function(-sqrt(pow(x+1,2)+pow(y,2)+pow(z,2))+1,-1.5,0)
     threshold  1
      max_gradient 4
      translate <-3,-3,0>        }
Date: 19 Sep 2016 03:20:15
Message: <57df91af$1@news.povray.org>
>>> If you're on to something then some working
>>> example code will go *far* further than just a text description.
>> Totally agree, I am working on it.
> And here it is:
A good start!
How would you go about doing the union (or difference) of two rounded
cubes? I tried to modify the code to do this but couldn't get it to
work. If that works nicely then I think you're on to something...
BTW you could always use a macro for each element, that depending on
some global switch, either used the standard POV non-rounded primitive
(for speed of setting up the scene) or the isosurface variant (for final
render).
Date: 19 Sep 2016 05:05:01
Message: <web.57dfaa2e696ad3a7cafab50@news.povray.org>
> > And here it is:
> A good start!
> render).
I think I have a plan!
Meanwhile here are some cylinders:
License.
View,
// Demonstration of Cylinder elements for rounded objects
// Vers: 1.00
#version 3.7 ;
camera {location <0,0,17> angle 25 look_at <0,-.30,0> }
  light_source {<5,10,20> color White}
  #declare R_function = function( F,q,p,n){
select((F>q)-(F<-q),2*(q<0)-1,p*pow(F/q,5)-(2*p+.5)*pow(F/q,3)+(1.5+p)*F/q,1-2*(q<0))+n
  isosurface {
     function    {
               R_function(-sqrt(pow(y-1,2)+pow(z,2))+.4-.1*x,-.5,0,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.3,0,-1)
              +R_function(x+1.5,-.3,0,1)
              +R_function(x-1.5,+.3,0,1)
              +R_function(y,-.3,0,1)
     threshold -1
      max_gradient 6
            translate < 0,.7,0>  }
  isosurface {
     function    {
               R_function(-sqrt(pow(y-1,  2)+pow(z,2))+ .5,-.3,.2+.5*x,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.3,.2+.5*x,-1)
              +R_function(y    ,-.5,0,1)
     threshold -1
      max_gradient 6
            translate < 0,-1,0>  }
  isosurface {
     function    {
               R_function(-sqrt(pow(y-1  ,2)+pow(z,2))+ .4,-.5+.2*x,0,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.5+.2*x,0,-1)
              +R_function(y+1    ,-.5,0,1)
     threshold -1
      max_gradient 6
            translate < 0,-2.7,0>  }
Date: 19 Sep 2016 07:15:00
Message: <web.57dfc85c696ad3a7cafab50@news.povray.org>
> > render).
And, more exciting, bendy cylinders!
License.
View,
// Demonstration of Bendy Cylinder elements for rounded objects
// Vers: 1.00
// Date: 19 Sept 2016
#version 3.7 ;
camera {location <5,10,17> angle 10 look_at <0,0,0> }
  isosurface {
     function    {
               R_function(-sqrt(pow(y-.6+.1*x-.1*pow(x,3),  2)+pow(z,2))+
..2,-.1,0,-1)
              +R_function(-sqrt(pow(y+1.5,2)+pow(z,2))+1.9,-.1,0,-1)
              +R_function(x+1.5,-.1,0,1)
              +R_function(x-1.5,+.1,0,1)
     threshold -1
      max_gradient 20
            translate < 0,-.5,0>  }
// note that the cross section is a vertical circle, which means that it will be
elliptical on a plane perpendicular to the cuved axis.
// I think this can be compensated for by taking the slope of the curve into
account.
// I have not worked out the details but I think this is a route to sphere
sweeps.
Date: 19 Sep 2016 12:40:01
Message: <web.57e013ea696ad3b488d9aa0@news.povray.org>
These are very good  :)
I was unsure this would get any farther than speculation, but these scenes are a
very nice prototypical realization of your ideas.
I have to ask:
Could you explain some of the notation that you have in your select() directive?
For example: 2*(q<0)-1   ....   I had no idea one could do this type of thing
:O
Hardly a day goes by that I learn something new here!
Date: 20 Sep 2016 04:15:00
Message: <web.57e0ee71696ad3a7cafab50@news.povray.org>
Thanks
f your ideas.
> I have to ask:
> :O
In words this select directive says:
If F is more than q return a value of 1 but with the same sign as q
If F is less than -q return a value of 1 but with the opposite sign to q
In between return a value according to the polynomial which has turning points
at +/- q
The parameter p (profile) controls the contribution of the 5th power term in the
polynomial and changes the coefficients of the the two terms so as make the
turning points stay in the same position.
I am farly sure that, if a sine curve were to be used, the corner would be a
true circle. With a cubic, ie p = 0, it is within 2% of a circle.
Date: 20 Sep 2016 05:10:01
Message: <web.57e0fbb0696ad3a7cafab50@news.povray.org>
> > And here it is:
> A good start!
> render).
Excellent idea.
And here are unions:
License.
View,
// Demonstration of nion for rounded objects
// Vers: 1.00
// Date: 20 Sept 2016
#version 3.7 ;
camera {location <10,7,30> angle 12 look_at <0,0,0> }
  light_source {<10,5,10> color White}
  #declare Vo =1;
    #declare R_limit = function(V){select((V+1>Vo)-(V+1<-Vo),
-1,-.5*pow((V+1)/Vo,3)+1.5*(V+1)/Vo,+1)-1}
  #declare Corner_Profile = -0;   // -.5 gives rounded bevel, 0 almost round,
+.5 Not noticebly sharper
  #declare Corner_round = .3;
  isosurface {
     function    {
               R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1,-1,0,-1)
  +R_limit(
                 R_function(x+1.5,-Corner_round,Corner_Profile,1)
              +R_function(x-.5,+Corner_round,Corner_Profile,1)
              +R_function(y-.5, Corner_round,Corner_Profile,1)
              +R_function(y+1.5,-Corner_round,Corner_Profile,1)
              +R_function(z-1.5,+Corner_round,Corner_Profile,1)
              +R_function(z+.5,-Corner_round,Corner_Profile,1)-2 )
             +1
     threshold 0
      max_gradient 20
      translate < 0,1.4,0>
  isosurface {
     function    {
         R_limit( R_function(-sqrt(pow(y-.5,2)+pow(z,2))+.5,-.3,0,-1)
                 +R_function(x+.5 ,-.3,0,1)
                 +R_function(x-1.5,+.3,0,1))
       +R_limit( R_function(-sqrt(pow(y+.5,2)+pow(z,2))+.5,-.3,0,-1)
                +R_function(x-.5,+.3,0,1))
                +1
     threshold 0
      max_gradient 20
      translate < 0,-1.5,0>
Date: 20 Sep 2016 06:25:01
Message: <web.57e10dd0696ad3a7cafab50@news.povray.org>
> > And here it is:
> A good start!
Like this:
License.
View,
// Demonstration of subtraction for rounded objects
// Vers: 1.00
#version 3.7 ;
camera {location <10,7,30> angle 15 look_at <0,0,0> }
  #declare Vo =1;
  isosurface {
     function    {
            +   R_function(-sqrt(pow(x-1,2)+pow(y,2)+pow(z,2))+1.5,-.3,0,-1)
  +R_limit(
                 R_function(x-1,+Corner_round,Corner_Profile,1)
              +R_function(x+1,-Corner_round,Corner_Profile,1)
              +R_function(y-1, Corner_round,Corner_Profile,1)
              +R_function(y+1,-Corner_round,Corner_Profile,1)
              +R_function(z-1,+Corner_round,Corner_Profile,1)
              +R_function(z+1,-Corner_round,Corner_Profile,1)-2 )
             +3      //Increasing this by two gives the intersection
     threshold 0
      max_gradient 20
      translate < -2.5,1.5,0>
  isosurface {
     function    {
R_function(-sqrt(pow(x+.8,2)+pow(y+.5,2)+pow(z+1,2))+1.5,-.3,0,-1)
  -R_limit(
                 R_function(x-1.5,+Corner_round,Corner_Profile,1)
              +R_function(y-1.5, Corner_round,Corner_Profile,1)
             +1
     threshold 0
      max_gradient 20
      translate < 2.5,-1.5,0>
  isosurface {
     function    {
            -   R_function(-sqrt(pow(x-1,2)+pow(y-.5,2)+pow(z-1,2))+1,-.3,0,-1)
  +R_limit(
              +R_function(x-1,+Corner_round,Corner_Profile,1)
             +1
     threshold 0
      max_gradient 20
      translate < 2.5,1.3,0>
  isosurface {
     function    {
        - R_limit(
                 R_function(-sqrt(pow(x-.5,2)+pow(z,2))+1,-.3,0,-1)
                +R_function(y-1 ,+.3,0,1)
                +R_function(y+1,-.3,0,1))
       +R_limit( R_function(-sqrt(pow(x+.5,2)+pow(z,2))+1,-.3,0,-1)
                +R_function(y-1.5,+.3,0,1)
                +R_function(y+1.5,-.3,0,1))
                +1
     threshold 0
      max_gradient 20
      translate < -2.5,-1.5,0>
Date: 20 Sep 2016 06:27:17
Message: <57e10f05$1@news.povray.org>
>>> And here it is:
>> A good start!
>> render).
> Excellent idea.
Looks good.
Just one small thing though, it looks like something odd is going on
with the top (+y) face of the cube and also the join with that face and
the sphere (maybe related). There is a "ridge" of some kind along the
join, and the entire top face of the cube bends upwards way before the
round should start (see attached).
Download 'union.png' (37 KB)
Preview of image 'union.png'
Date: 20 Sep 2016 08:15:01
Message: <web.57e12820696ad3a7cafab50@news.povray.org>
> Looks good.
The radius of the round at the junction between the two objects is a function of
the radii of the two contributing faces and will be sharper. I think what you
are seeing is just a very sharp corner. The rising of the top face of the cube
is due to the field from the sphere.
There are going to be limitations!
I am looking at a way to specify a larger radius at the intersection of the two
objects.
