POV-Ray : Newsgroups : povray.general : Rendering two sheets of paper Server Time
18 Nov 2025 08:59:40 EST (-0500)
  Rendering two sheets of paper (Message 1 to 9 of 9)
Subject: Rendering two sheets of paper
Date: 21 Mar 2016 02:20:01
Message: <web.56ef9248e12cd37f2cfb4b8e0@news.povray.org>
I want to render two sheets of paper (one on top of another).
See e.g. the following images:
http://3.bp.blogspot.com/-Z_xcZG_0OpM/T6QQOa_85RI/AAAAAAAAY2Y/SfjXLhylBc8/s1600/IMG_5882.JPG
https://t2.ftcdn.net/jpg/00/67/30/75/240_F_67307554_13kmP5SBUF36d3HrbcR6O0swgZcv3Hhu.jpg
I want to get this tiny shadow which is formed by the topmost sheet on the
bottom one.
Since the distance between the sheets is VERY small, I cannot just place two
meshes with different z-coordinates.
I thought of using some multilayered texture:
1. bottom sheet
2. some shadow layer (???)
3. top sheet
Subject: Re: Rendering two sheets of paper
Date: 21 Mar 2016 03:49:22
Message: <56efa782$1@news.povray.org>
> bottom one.
> 1. bottom sheet
> 3. top sheet
It seems to me that placing two meshes, slightly offset vertically, is
the best method and not difficult to build. A challenge would be if the
sheets were wrinkled but I guess that is not your intention. The layered
texture approach does not seem to me a very good solution. Personally, I
always used the first approach in the past.
Date: 21 Mar 2016 07:15:00
Message: <web.56efd76c58b90b635e7df57c0@news.povray.org>
> bottom one.
"Can't" ??
I would guess that given what POV-Ray is capable of, that you just need enough
separation and the proper camera angle to be able to see the shadow.
You could add a fake "shadow layer" which is just another "piece of paper" lying
directly on top of the lower sheet.
texture {pigment {rgbt <0, 0, 0, 0.4>}}
Maybe there's something you can do with bicubic_patches and texture /
interior_texture.
I think you can define "negative light sources" and negative pigment values -
maybe you could investigate that.
I'd probably just start googling "POV-Ray paper" or some such variant, because
there's GOT to be plenty of pieces of paper modeled in the past.  Look in the
old IRTC archives for scene files.   Scroll through the scene files sections of
this forum and see what's in there.
Date: 21 Mar 2016 08:45:00
Message: <web.56efec9d58b90b632cfb4b8e0@news.povray.org>
> > bottom one.
> > 1. bottom sheet
> > 3. top sheet
> Thomas
I will need to render dozens of such papers stacked on top of each other.
Besides, I am going to render a video file where the scene is rotating.
So, I believe, even small offset being multiplied by, say, 20 will look no so
good at some particular camera positions.
Date: 21 Mar 2016 08:57:28
Message: <56efefb8$1@news.povray.org>
>>> bottom one.
>>> 1. bottom sheet
>>> 3. top sheet
>> Thomas
Assuming you use flat meshes, stacking is trivial using a #while or a
#for loop with a very small vertical increment and a slight random
rotation around the vertical axis. Very basic, and I guess that,
whatever camera position, the scene will look good video or not.
Date: 21 Mar 2016 10:45:49
Message: <56f0091d$1@news.povray.org>
Thomas is right. I posted an image in p.b.i with 10 bicubic patches
stacked on top of each other. (It was easier for me to use patches
instead of meshes.)
Regards
Date: 21 Mar 2016 15:42:11
Message: <56f04e93$1@news.povray.org>
I would say it is the other way around: if you model the geometry
based on reality then chances are better that you still get good results
after changing camera or lighting compared to just faking the effect.
But of course, there may be other reasons to prefer a different
approach. Since you are doing animation performance may be a factor.
In that case using a simple box with marble pattern, black / white
color_map and slight turbulence might work.
Date: 21 Mar 2016 16:00:26
Message: <56f052da$1@news.povray.org>
>> look no so
Something like
     pigment
       marble scale <0.01,1,1> turbulence 0.2 color_map
         [0.15 rgb 0]
         [0.2 rgb 1]
although it needs high antialiasing so performance may not be great
after all. I needed at least +a0.0001 for closeup render.
Date: 21 Mar 2016 18:45:20
Message: <56f07980@news.povray.org>
>> bottom one.
Just add a very small Y offset to the top sheets.
Something like 0.001*y is probably enough.
> "Can't" ??
> interior_texture.
Can also be done with mesh provided that you add an inside_vector whitch
can point straight up in this case.
Both lights, pigments, diffuse, ambient, emission, phong, specular and
reflection can have negative values.
