POV-Ray : Newsgroups : povray.general : fabric simulation Server Time
25 Feb 2026 11:31:20 EST (-0500)
  fabric simulation (Message 1 to 10 of 53)
Subject: fabric simulation
Date: 7 Jan 2015 18:10:00
Message: <web.54adbc6a13c841a3bd92286f0@news.povray.org>
it would be awesome if povray had this:
http://www.cs.cornell.edu/projects/ctcloth/
unfortunately, it would require a database of df3 files -- micron-resolution MRI
scans of cloth swatches...
but the results are just fantastic.
A.D.B.
Subject: Re: fabric simulation
Date: 7 Jan 2015 22:55:01
Message: <web.54adff24d1f9e5adbd92286f0@news.povray.org>
> Regards,
> A.D.B.
Er.. sorry.. CT scans...
A.D.B.
Date: 7 Jan 2015 23:30:00
Message: <web.54ae071dd1f9e5add19b0ec40@news.povray.org>
> Regards,
> A.D.B.
Meh, easier to just use Blender's cloth simulator. Come to think of it, I think
the old Megapov had some sort of cloth simulating thing.
Date: 8 Jan 2015 00:05:00
Message: <web.54ae0feed1f9e5adbd92286f0@news.povray.org>
> > Regards,
> > A.D.B.
I find Blender to be a massive pain to use.  I can't import my models into it
from povray, which is the only place I ever create models, and the interface is
a clunky mass of mystery meat.
Aside from that, you're left trying to find a triangle resolution that doesn't
leave the surface looking patchy.
I tried using Megapov's cloth simulator, once, and felt that there were way too
many parameters.
And lastly, sometimes it's more fun to do things the hard way, and sometimes,
the hard way is actually better than the easy way.
but, as you will.
I posted the link because I found the article interesting.
A.D.B.
Date: 8 Jan 2015 01:00:00
Message: <web.54ae1bf2d1f9e5add19b0ec40@news.povray.org>
It's a clunky mess because you're not used to it. That will be the same no
matter what program you use (AutoCAD, Maya, 3D Studio Max, etc.).
You can use smooth shading. This gives good results even at low mesh
resolutions.
> many parameters.
Cloth is pretty complex. If Povray were to integrate what you linked, there will
unlikely be less parameters.
Date: 8 Jan 2015 01:15:01
Message: <web.54ae1fe0d1f9e5add19b0ec40@news.povray.org>
Take a look at what I whipped up in < 5 minutes (cloth simulation + export to
Povray + render in Povray).
http://news.povray.org/povray.binaries.images/thread/%3Cweb.54ae1f35e1e1e369d19b0ec40%40news.povray.org%3E/
Date: 8 Jan 2015 02:17:31
Message: <54ae2f0b@news.povray.org>
On 08/01/2015 05:04, Anthony D. Baye wrote:
> I find Blender to be a massive pain to use.I can't import my models into it
The interface is a lot better than it was.
Bishop3D can import a subset of SDL. But it only works with version 3.6
It is now freeware.
> many parameters.
You really need a lot of parameters. I use Poser's Cloth room and that
has a score or more.
There we differ. :-)
> but, as you will.
I thought it was interesting and the results outstanding.
You could, with a lot of work, create your own "CT" scan as a df3. Using
PovRay.
Regards
Date: 8 Jan 2015 03:00:01
Message: <web.54ae37f2d1f9e5ad16086ed00@news.povray.org>
> > > Regards,
> > > A.D.B.
> many parameters.
> but, as you will.
> Regards,
> A.D.B.
Did you know that you can mix existing POV code with your blender scene? just
copy and paste it in the Blender text editor with view properties enabled and
check the "add as POV code" box. It will be integrated with Blender POV Code
seamlessly at render time. It's all explained and demonstrated in the WIKI.
About smooth geometry, the integration of Pixar's opensubdiv is planned for one
of next blender realease, so this should improve it.
jhu, thanks for proving the exporter works. more images are needed to motivate a
community.
Date: 8 Jan 2015 03:21:10
Message: <54ae3df6$1@news.povray.org>
From the initial post I got the impression that it was more the cloth
/texture/ that was the subject than the positioning of same. The later
can be achieved without too much work using e.g. Blender or Poser; the
former is - in my view - something much more difficult to achieve,
especially considering the fine details shown in the zoom images of the
fabrics presented in the video. It is not a /simple/ layered texture
using pigment patterns or image patterns. It is something much more
elaborate.
Date: 8 Jan 2015 04:15:18
Message: <54ae4aa6@news.povray.org>
> elaborate.
That's what I thought.
Regards
